Any easier way to skip Disney trailers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-19-2007, 12:54 PM - Thread Starter
geaux-tigers's Avatar
I went to watch King Arthur last night, and I was forced to skip through about five trailers and an anti-piracy video before finally getting to the main menu. I know that others have probably noticed this; however, I have not seen a lot of complaining about it. Does this bother anyone else? Is there an easier way to bypass all of this? I don't mind hitting chapter skip once, but this is quite excessive. If Disney ever goes HD DVD, they could probably cut 20GB by just removing the Disney propaganda. I don't mind this being included on the disc as long as the movie quality isn't effected (Disney Blu-ray discs usually look great), but I wish that they could bury these under the special features so that it wouldn't take five minutes to get to the main menu every time.
geaux-tigers is offline
post #2 of 7 Old 04-19-2007, 12:57 PM
patrick99's Avatar
It would certainly be more user friendly if the menu button worked here.
patrick99 is offline
post #3 of 7 Old 04-19-2007, 01:04 PM
Jiffylush's Avatar
I haven't watched this title, but sometimes using the other menu button works for skipping this stuff (pop-up menu instead of top menu I think)
Jiffylush is offline
post #4 of 7 Old 04-19-2007, 01:08 PM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 157
None that I have found.
Yes, all I want to do is watch the d*?# movie. I do not need extras, trailers, warnings, games, etc., for other readers YMMV.
Wendell R. Breland is offline
post #5 of 7 Old 04-19-2007, 01:40 PM
cjr1's Avatar
Yes BV is definitely excessive in this department. What makes it even worse is that they go from previews to anti-copy BS, then they tell you that your movie will be starting shortly and you have to wait that screen out. I really don't understand their logic.
cjr1 is offline
post #6 of 7 Old 04-19-2007, 01:45 PM - Thread Starter
I am using a PS3, and I tried both menu buttons without success. You just get the message about operation not supported or menu not available. I thought that since no one else was complaining that maybe it was a PS3 issue or there was a trick that I didn't know about.
post #7 of 7 Old 04-19-2007, 02:04 PM
Rick_R's Avatar
Thanks for the warning. I will only buy Disney movies if the title is REALLY compelling.
Rick R
Rick_R is offline
Reply Blu-ray Software
