The Fifth Element REMASTERED edition*PIX* + review - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 07-10-2007, 07:52 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
Originally Posted by JaylisJayP View Post
if these new pictures are an accurate representation of what the new version looks like, I'll definitely pass on buying it. It still looks like garbage.
We all thank you for the insightful post. I'll make sure to refer to you in the future when I want to know how any given movie should look.
MSmith83 is offline
Old 07-10-2007, 08:16 PM
Hunter67's Avatar
Originally Posted by Rob Tomlin View Post
Does it really default to the TrueHD track?!?!?
If so, I think that is great. I think these HD titles that default to the legacy tracks will remind us of the first DVD's that defaulted to the 2 channel or dolby pro-logic track instead of the 5.1 track (ironically the first DVD release of TFE did exactly that)!
Yep, I was all ready to select the TrueHD track when the audio menu came up it was selected by default...nice going Sony, hope they keep this up.
Another note, there is no native English Dolby Digital track on this, just TrueHD and PCM. I'm not sure how this works if your only using optical.
paidgeek does this TrueHD track contain a core Dolby Digital track?
I do remeber the first DVD releases, I still have some of the original ones with 2 channel selected by default. I think Sony Pictures and Paramount released a lot like this for the first year or so. I also remember a lot of releases that were just letterbox (non-anaphormic) and not formatted for widescreen televisions.
Hunter67 is online now
Old 07-10-2007, 08:22 PM
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Did they start shipping replacements
zoro is offline
Old 07-10-2007, 08:24 PM
Hunter67's Avatar
Any reviews on the remastered version yet?
Old 07-11-2007, 10:25 AM
Kris Deering's Avatar
Quoted: 1613 Post(s)
Liked: 2560
Review copies have not been shipped out to my knowledge. I have all of the Sony releases up to that date already but have not received it.
My Home Theater
Kris Deering is offline
Old 07-11-2007, 10:37 AM
JE3146's Avatar
I thought Tru-HD had a DD core track?
59 Blu-rays and counting...
JE3146 is offline
Old 07-11-2007, 12:13 PM
Caurus's Avatar
There is no DD core in Dolby True HD. But I thought it is in the bluray specs that a Dolby True HD track must be accompanied by a DD track.
My PS3 is linked with my AV amp using optical out. This would suck big time if I would get only 2 channel sound from the new TFE bluray.
Can anybody check this? Can the PS3 convert 5.1 DD THD into 5.1 DD (for the optical out)? I think I would cancel my pre-order an stick with the DVD, if I would get only stereo from the bluray. The sound of the remastered DVD version really kicks a**.
Format neutral! (prefering HD DVD which is build on quality while blu-ray is build on marketing)
CETERUM CENSEO BLU-RAYEM ESSE DELENDAM!
Caurus is offline
Old 07-11-2007, 12:20 PM
DaViD Boulet's Avatar
Liked: 41
Blu-ray specs require that any TrueHD track be accompanied by a legacy Dolby Digital track (usually 640 kbps in practice) for backwards compatibility. However, even though technically it's a separate DD track, the BD spec causes it to *act* like a "core" stream. For instance, the disc-packaging might only mention the Dolby TrueHD soundtrack and not the standard Dolby. Also, I'm not sure if the standard Dolby is made available as an option in the menu.... I think you might only see the TrueHD soundtrack option in the audio setup choices.
HOWEVER:
ALL BD players will stream the Standard Dolby "core" (core in quotes here) out the traditional coax/optical digital output for those with standard receivers. This is true even if your BD player can decode TrueHD and/or has HDMI 1.3. In other words, if you select the Dolby TrueHD soundtrack, you'll be able to hear the 5.1 Dolby Digital (probably at 640) out the SPDIF digital ouptut. That's automatic because the player knows you can't put TrueHD on an old-fashioned SPDIF digital cable.
If you have a built-in TrueHD decoder (like in the PS3) you should also be able to hear the Lossless TrueHD converted to 2.0 PCM via the SPDIF output, depending on your player settings.
1080p and lossless audio. EVERY BD should have them both.
DaViD Boulet is offline
Old 07-11-2007, 02:43 PM
solo88's Avatar
Originally Posted by ryoohki View Post
For a reason unknow, people tought that it was going to be better than King Kong .. witch is technically impossible in this case since most SFX Shot in 5th Element seems to have been transfered to film, where King Kong , film was scanned digitally and incorporated into the digital world then transfered on the HD DVD ...
Waiting for someone to say that the frame screenshot are not the same in 5,4,3,2,1...
The detail in the BD makes the "detail" in the DVD look like mosquito noise.
Looks pretty good to me for being struck from a Super 35 print. Now if this had been 70mm....
Can't wait till MTV ships mine. It ought to look phenomenal.
My midis bring all the Force to the yard; my midis are better than yours!
solo88 is offline
Old 07-11-2007, 04:08 PM
Brad1963's Avatar
I got notification that my copy shipped. Hope I get it for the weekend.
Brad1963 is offline
Old 07-11-2007, 04:53 PM
John Kotches's Avatar
Originally Posted by PeterTHX View Post
Puzzling isn't it. 16 bit TrueHD encodes hover between 1-3Mbps. Perhaps the resolution of the master was higher than they thought.
It's an all new transfer, I've also noticed for the first time in the original transfer there was a red push that's gone now. Much more accurate colors.
No, a higher bit rate indicates that it is difficult to compress. Given the era (1997) it's (at best) a 20-bit resolution masater but more likely 16.
There are a number of potential reasons for the high bit rate, here are some:
1) Audio data represents a near pathologic case with high degrees of randomization.
2) Channel content is highly scattered making the encoder work harder to get the compression.
3) The title has significant dynamic range compression in the master. The more DRC you apply, the less the audio data will compress.
Cheers,
Contributing Editor & Surround Music Reviewer Widescreen Review
Opinions are mine, not the publication I write for.
John Kotches is offline
Old 07-11-2007, 05:23 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
I want a perfect transfer as well, and don't forget to throw in the best audio codec to boot, but saying this transfer is garbage certainly has no merit. I will gladly take this new release, and kudos to Sony for replacing customers originals free of charge.
If you want the perfect transfer than go buy yourself a movie theater.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
Old 07-11-2007, 05:31 PM
Supermans's Avatar
Liked: 34
Call the number below and give them your reference number to ask if they have recieved your mail. Nobody has had their order shipped yet since they all will ship the 17th...
Phone: 800-860-2878
Email: consumer@sphecustomersupport.sony.com
Supermans is offline
Old 07-11-2007, 05:36 PM
Supermans's Avatar
Liked: 34
Hmmm, is it just me...or is it that even though there's a noticeable difference, the remaster still looks below average?
It's just you ....
Hunter67's Avatar
Great, can't wait until your review Kris
Old 07-11-2007, 05:38 PM
Hunter67's Avatar
Found this response from paidgeek in the Industry Insiders thread concerning the TrueHD track and Dolby Digital.
Originally Posted by paidgeek View Post
Whenever Dolby THD is used, there is a legacy DD stream that shadows it. Although you do not see it as a menu selection, it will be output from your optical/coaxial connector if you have made the appropriate player system settings.
Given the virtues of lossless/uncompressed audio, it is well worth putting a new receiver on your Christmas list.
Old 07-11-2007, 05:50 PM
Supermans's Avatar
Liked: 34
Originally Posted by msv View Post
here are Xylon's screenshots as mouseover images for easy comparison
» http://www.mbmg.de/hd-discs/thefifth...stered/01.html
This is a great service you are doing for all of us along with Xylon.. My thanks and appreciation go out to you two. Keep up the great work on here
Old 07-11-2007, 06:04 PM
MEC2's Avatar
Boy that looks LOADS better than the upscale. It's got what I love about HD - texture. That looks like pocked stone now, the additional resolution gives slight detail the depth that looks real. Definitely worth upgrading over the SD DVD...
MEC2
MEC2 is offline
Old 07-11-2007, 06:17 PM
Supermans's Avatar
Liked: 34
MEC2
It is worth upgrading over the Mpeg2 Blu-Ray as well... The new transfer makes the MPEG2 BD look fuzzy in comparison...
Old 07-11-2007, 07:41 PM
dark buckshot's Avatar
i can't wait for this.........i check my mailbox everyday hoping they send them out early like a preorder from amazon........still hasn't arrived....... how much longer
devil's bard
dark buckshot is offline
Old 07-11-2007, 08:00 PM
TheMoose's Avatar
Just take a chill pill man!!
The email states the replacement discs will shipped After July 17th, so you got about a week & a half left depending on where they are shipped from.
I just boxed mine up tonight & will be sending it out tomorrow.
Remember, "good things come to those who wait".
"Racing is........Life.......Everything before & after is just waiting"
TheMoose is offline
Old 07-11-2007, 09:08 PM
Jedi2016's Avatar
Quoted: 37 Post(s)
Liked: 58
Well, nice to know about the TrueHD and DD tracks. I'm in the same boat as many folks, running through optical to a receiver. My problem is that I don't like buying new stuff until the old stuff breaks, and my receiver is only a couple years old, from just before they put HDMI into 'em. I'll upgrade eventually, to be sure, and when I do, I'll make damn sure I'm able to take full advantage of all the audio that Blu-ray has to offer.
Welcome to Rivendell, Mister Anderson.
Jedi2016 is offline
Old 07-12-2007, 03:39 AM
hdblu's Avatar
pcm 5.1 is better that truehd I have a HDMI receiver and i test it both pcm run at 28.76mbps truehd run at 24.87mbps DOLBY TRUE IS A LOSSLESS AUDIO TO
hdblu is offline
Old 07-12-2007, 06:09 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 491
The 17th is right around the corner!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
Old 07-12-2007, 08:59 AM
jkcheng122's Avatar
Quoted: 83 Post(s)
Liked: 92
um... those are video bitrate, not audio.
jkcheng122 is offline
Old 07-12-2007, 01:12 PM
Dave Mack's Avatar
relax, everyone. People can't wait, what another week...?!?!?
Dave Mack is offline
Old 07-12-2007, 04:07 PM
JeffDM's Avatar
Damn, how are so many people getting their hands on this disc so early?!
As it's been noted, some Walmarts are breaking street date. They can do that, mainly because the studio can't afford to penalize them.
JeffDM is offline
Old 07-12-2007, 04:40 PM
Dave Mack's Avatar
exactly. You piss off Walmart, you're effed....
Old 07-12-2007, 05:11 PM
jkcheng122's Avatar
Quoted: 83 Post(s)
Liked: 92
when do you suppose they'll have 300 on BD available
Old 07-12-2007, 05:36 PM
eightninesuited's Avatar
Quoted: 26 Post(s)
Liked: 29
I just saw it at Future Shop. They have copies of both versions and it's pretty easy to tell them apart. Not only does the new one have the foil "Experience High Definition", but the cover itself is kind of a foil, and the colors are vastly different from from the old "yellowish" look.
My Dad once said to me: "Son, quality over quantity - always"
Of course he was referring to girlfriends after high school, but the same applies to subs - which, if you are in this forum is the girlfriend we have an affair with for a running time of 2 hours in one session.
eightninesuited is online now
