BD9 burning? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-23-2007, 01:16 PM - Thread Starter
Sebaz's Avatar
I want to burn some HD material to BD9s, which is Blu-Ray on regular DVDs for those who don't know. Can anybody point me to the right software and tutorials? I'm having a hard time finding anything on Google, specialized web sites, forums, etc. I did burn some stuff using DVD Studio Pro 4 on DVD using HD-DVD format that I was able to play on a player of that format, however I now have a Panasonic BD30 Blu-ray player which I intend to keep, so I would like to author in that format, without having to spend ridiculous amounts of money on a Blu-ray burner and blank media. Basically what I want to put in there are transport streams that I transfer from my cable DVR to the computer, which are at low bitrate so I can fit about one hour of content on a single layer DVD, and also some home videos shot with a Panasonic AVCHD camcorder. I just need the basic menues, no Javascript or anything fancy.
I came across TSRemux, which allows to create some kind of Blu-Ray structure, but when I put the resulting DVD on my player it doesn't play. Plus it doesn't allow me to create menues.
Sebaz is offline
post #2 of 5 Old 11-23-2007, 01:47 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
Look ^ in the stickies
almostinsane is offline
post #3 of 5 Old 11-23-2007, 01:59 PM - Thread Starter
Sebaz's Avatar
If you refer to the "My Blu-Ray Movie Burning Experiences..." it has 735 replies, which would be very time consuming for me to go through. I was hoping that someone could give me a link or a short successful experience.
Sebaz is offline
post #4 of 5 Old 11-23-2007, 03:21 PM
nickoakdl's Avatar
Quoted: 84 Post(s)
Liked: 65
Here's a link.
nickoakdl is offline
post #5 of 5 Old 11-23-2007, 06:37 PM
Mr_Bester's Avatar
Check the last couple of pages from that thread, it has links
dug
Mr_Bester is offline
Reply Blu-ray Software
