How to clean Blu-ray disk? - AVS Forum | Home Theater Discussions And Reviews
Old 01-10-2008, 01:43 PM - Thread Starter
Rustyf7's Avatar
What is the best way to clean fingerprints and smudges off a blu-ray disk?
Rustyf7 is offline
Old 01-10-2008, 01:46 PM
TwinTurboJosh's Avatar
Water + microfiber towel
TwinTurboJosh is offline
Old 01-10-2008, 03:16 PM
maverick0716's Avatar
Best way? Like the guy above me posted.
Perfectly adequate way? Your breath + your shirt.
Panasonic 42PX75U Plasma
PS3 60 GB
Xbox 360 Elite
Toshiba HD-A2
Pioneer VSX-1018
Polk Audio RM6750
maverick0716 is offline
Old 01-10-2008, 03:58 PM
Chris Rein's Avatar
Yup.
Try doing that with an HD-DVD and you'll see scratches. A quick dusting with the shirt works fine...if needed. I only do that with rentals as I keep mine in great shape.
Chris Rein is offline
Old 01-10-2008, 04:38 PM
manikin's Avatar
+1
My method (you also dont have to go radially out as with CD's, and DVD's)
Support The Facts - Not Opinions
manikin is offline
Old 01-10-2008, 04:51 PM
dogdoctor's Avatar
With the BD hard coating has anyone actually caused a visible scratch with this method? I dropped a PS3 disc the other night and as it hit the end of the entertainment system lip I almost had a heart attack. But there was no damage, scratch, or any damage whatsoever. I consider myself lucky and don't want to test a repeat preformance.
PSN ID: dogdoctor
dogdoctor is offline
Old 01-10-2008, 05:07 PM
Disclord's Avatar
Originally Posted by manikin View Post
+1
Always clean ALL optical media in a radial direction since any inadvertent damage will then only cover a small number of pits and not obliterate whole sections of track.
Ty C. :-)
"Riff Randal, Rock-n-Roller!"
Disclord is offline
Old 01-10-2008, 05:11 PM
Captain Spaulding's Avatar
Well, I've been know to use a solution of water and plain old dish detergent, followed by thorough drying with a cotton towel or washcloth. They get so nice 'n clean 'n shiny that way! And I've never had a disk problem using this method.
Captain Spaulding is offline
Old 01-10-2008, 05:12 PM
tokerblue's Avatar
Quoted: 95 Post(s)
Liked: 67
I always use a mixture of 50% isopropyl alcohol and 50% water to clean everything along with a microfiber cloth. It's very cheap and it works very well. LCD screens, CD's, DVD's, etc.
tokerblue is offline
Old 01-10-2008, 05:17 PM
Disclord's Avatar
Since the DiscoVision/LaserDisc days, I've used either Windex or eyeglass cleaner - Pioneer used to specifically recommend Clean 'N' Shine and the front of your cotton shirt (I'm not making that up!). Rain-X also is good at making scratched discs play better - I don't know if it would help with Blu-ray since the depth of focus is so incredibly shallow, but it wouldn't hurt to try if you ever have a scratched disc. For LP's I use Everclear mixed 50/50 with distilled water and a drop of Kodak Photoflow.
Ty C. :-)
Disclord is offline
Old 01-10-2008, 05:24 PM
Ilka's Avatar
Unlike that other format, boiling it is NOT recommended ... LOL
Ilka is offline
Old 01-10-2008, 05:34 PM
Disclord's Avatar
Boiling????
Ty C. :-)
Disclord is offline
Old 01-10-2008, 07:19 PM
Wow....how dirty are you guys getting these discs? lol. Unless you use your discs as your dinner plate, then I would think detergents aren't neccessary. I've never had a single problem either, and I only use my breath and a cloth.
PS3 60 GB
Xbox 360 Elite
Toshiba HD-A2
Pioneer VSX-1018
Polk Audio RM6750
Old 01-10-2008, 07:31 PM
ilovenola2's Avatar
Me, too! With both formats.
ilovenola2 is offline
Old 01-10-2008, 08:02 PM
Claw97000's Avatar
Actually, back in the day of the Children of Men HD DVD boiling fiasco, which I tried, and it worked as a matter of fact, it made me come to the realization that I don't think very hot water will do any damage to a disc. Cook it for long periods of time? No way! But running a disc under hot water and wiping it off with a soft cloth really cleans it well. When I boiled COM it was for about 30 seconds and the disc looked brand new. Odd, extreme? Yes. But heck it worked.
Claw97000 is offline
Old 01-10-2008, 09:12 PM
ddddd55555's Avatar
While we're cleaning, can you use a cd/dvd cleaning disc in a blu ray player?
ddddd55555 is offline
Old 01-10-2008, 10:52 PM
Claw97000's Avatar
Well, don't Cd/dvd cleaners usually work by a small brush on the disc wiping off the laser lens in the player? I used one on my CD player that was like that, and the disc would run at various speeds to clean the lens. That being said, don't BD players run at a different speed than SD/CD players? If so, I would avoid using CD/DVD cleaning discs in a BD player since they are built to run at SD player speeds.
Old 01-10-2008, 11:54 PM
Deviation's Avatar
CD/DVD cleaning kits basically sell you rubbing alcohol in a little spray bottle. I use my eyeglasses cleaner and a cotton cloth because it's always sitting out.
Deviation is offline
Old 01-11-2008, 07:59 AM
ddddd55555's Avatar
Yeah, those are the ones I am talking about. If that doesn't work is there a different way to clean a blu ray player? Do they need to be cleaned?
Old 01-11-2008, 01:44 PM
hazel_wu's Avatar
One of my BD was shipped to me floating in the case, so I do get a lot of visible "scratch marks" on my disc. However, after the "breathe + T-shirt" method ALL scratch marks are completely gone. Thanks to the BD hard coating.
hazel_wu is offline
Old 01-11-2008, 01:49 PM
talyler's Avatar
I always use water + microfiber cloth for Blu Ray, HD DVD, an video game rentals. I've never had a problem. Movies/video games I own never get scratched of smudged
Xbox Live & PSN: talyler
talyler is offline
Old 01-11-2008, 02:30 PM
NemoZorro's Avatar
I spray the surface with a small air compressor first to remove any dust/dirt particles, then do the water/microfiber cloth thing.
Our "RV" disc was really smudged with fingerprints upon purchase (yes it was new). I almost returned it, but got over my fear and went for it. It cleaned perfectly.
I have had tiny scratches appear on SD DVDs when cleaning this way, and I'm afraid to try on HD DVDs. Really love the BD protective coating.
NemoZorro is offline
Old 01-11-2008, 03:09 PM
Deviation's Avatar
My copy of Blade Runner arrived with scratches on all five discs, though two of them are DVDs. None of my other Blu-ray Discs have a single scratch on them, however.
Old 01-11-2008, 10:29 PM
papi4baby's Avatar
Most of my disc for Blade runner were loose in the box, lucky for me the BD had no scratches, the DVD did, haven't watch them thought. Not really concern over it thought.
Blu ray.
papi4baby is offline
Old 01-12-2009, 06:52 AM
Nitro89's Avatar
where do you buy these microfiber cloths in the UK?
Nitro89 is offline
Old 01-12-2009, 08:46 AM
webdev511's Avatar
With the BD hard coating has anyone actually caused a visible scratch with this method? I dropped a PS3 disc the other night and as it hit the end of the entertainment system lip I almost had a heart attack. But there was no damage, scratch, or any damage whatsoever. I consider myself lucky and don't want to test a repeat performance.
Yes, I had an "Uncharted: Drake's Fortune" disc come from Game Fly with a huge scratch that rendered the disc unplayable. Other than that the worst I've had is fingerprints that just needed to be cleaned off.
Originally Posted by Disclord View Post
Boiling????
Yup, Boiling. That particular fix was most common for combo-discs. Particulate from fabbing the DVD-9 side (which was done after the HD DVD side?) would stick to the HD side. Apparently the final cleaning at some of the replication facilities wasn't as thorough as others. We'll never see that problem on Blu as it has to be super clean before the anti-scratch goes on.
Webdev511
San Jose, CA
TrueHD = DTS-MA = LPCM
Low Bit Rate AVC > Low Bit Rate VC-1
High Bit Rate VC-1 > High Bit Rate AVC
MPEG-2 = Great for DVD and that's about it.
webdev511 is offline
Old 01-12-2009, 10:32 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Since the DiscoVision/LaserDisc days, I've used either Windex....
Windex is a HORRIBLE and damaging way to clean plastic. Windex is formulated for glass and contains ammonia and other ingredients that are absorbed into the plastics. Over time they turn yellow.
Ever seen a convertible with the plastic back window that was yellow? Guess what was mistakenly used to clean it?
William is offline
Old 01-12-2009, 12:44 PM
deltasun's Avatar
Any physical limitation to applying said hard coating to DVD's? Why is this a blu-ray exclusive?
You see me reaching for my f****** wallet?!?
deltasun is offline
Old 01-12-2009, 04:27 PM
hazel_wu's Avatar
Blu-ray data layer is way too close to the surface of the disc. HD-DVD and DVD data layer are in the middle of the disc, thus scratches won't damage the data layer easily.
hazel_wu is offline
Old 01-12-2009, 04:45 PM
bplewis24's Avatar
Ahh, the good ole days
Brandon
bplewis24 is offline
