What happens to 7.1 LPCM tracks on a 5.1 system - AVS Forum | Home Theater Discussions And Reviews
Old 01-30-2008, 02:25 PM - Thread Starter
jshigashi's Avatar
I have sort of become the unofficial geek for my friends regarding home theater. Anyhow I am setting my friend up on a system and he is trying to decide if he wants to go for a 7.1 system. I told him that as far as movies (blu-ray of course) go they are few and far between, and he won't be able to get at least half of those that are out (PS3 / DTS-MA problem)... but who knows what the future holds.
Anyhow, I obviously informed him about lossless audio and he is going to go with a receiver capable of accepting all formats, but he asked me what would happen in the instances of the 7.1 LPCM tracks. Would he be able to select that and get 5.1 LPCM, or does he have to go with the 5.1 DD track.
jshigashi is offline
Old 01-30-2008, 02:31 PM
Jiffylush's Avatar
When you select 7.1 and you don't have a receiver that uses it, or you only have 5.1 speakers you will get 5.1 LPCM.
I am not sure if you lose 2 channels or if they are just matrixed in the rears, but you do get 5.1 LPCM (I verified on Waiting... IIRC)
Jiffylush is offline
Old 01-30-2008, 02:50 PM - Thread Starter
jshigashi's Avatar
I guess that's what I am asking... do you lose the 2 channels? I just watched 3:10 to Yuma and I heard quite a bit coming out of the 4 surround and rears on my 7.1 set-up, just wondering if it gets the rears (mixed/combined/matixed?) by the receiver (Onkyo 605). If not it seems like it would be losing a lot. Not really an issue now so much, but could be in the future?
Old 01-30-2008, 03:39 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2901
Depends on how the soundtrack is delivered on the disc.
If it is an uncompressed PCM track, then who knows. I haven't seen a firm answer one way or the other as to whether the 2 surround-back channels are downmixed into the surround-channels or simply tossed away. It would likely be player dependent.
If the soundtrack is encoded in one of the new lossy or lossless codecs, then you will get all 7.1 channels of information in 5.1 channels, with none of the audio discarded. One of the advantages of using coded soundtracks is that they're designed to be backwards compatible with 5.1-speaker systems.
Sanjay
Sanjay
sdurani is offline
Old 01-30-2008, 05:47 PM
Doug Schiller's Avatar
The odd thing, 7.1 PCM is the only soundtrack that my 7.1 system properly decodes.
DTS 7.1 (New Line) downgrades to DTS Core 5.1 and I don't think there has been a Dolby soundtrack that has supported more than 5.1 channels (not counted the on life support EX but that is really a matrixed deal).
Doug Schiller is offline
Old 01-30-2008, 05:53 PM
oblio98's Avatar
According to Alexander Jero who produces music in DTS Master Audio 7.1, he has the option at the encoding process as to how the 7.1 mix will be downmixed into 5.1. This is done in the decoder and keeps all audio information so that nothing is lost by not having the extra two speakers.
I would assume that Dolby TrueHD has the same capability.
[Early Adopter]
oblio98 is offline
Old 01-30-2008, 05:58 PM
Fanboyz's Avatar
Quoted: 506 Post(s)
Liked: 158
Question: I cant figure out if 7.1 sound tracks are really just 6.1 with the rears in mono.
Crank and the other films like Ultimate Avengers are this way.
However PS3 games like Resistance Fall of Man, are true 7.1 .
LG OLED65B6P. Klipsch: RF82, RC62, RS52, RB61, RP-140SA. SVS PB-U13. Denon 6300H. Oppo 103D. Oppo UPD 203.
Fanboyz is offline
Old 01-30-2008, 07:30 PM
tai4de2's Avatar
Player-dependent or receiver-dependent?
Is there a protocol negotiation such that the player knows that the receiver is only capable of 5.1 over PCM instead of 7.1, and therefore the player can react by performing some mixing? At least the latter part of that seems unlikely to me.
tai4de2 is offline
Old 01-30-2008, 07:36 PM
Fanboyz's Avatar
Quoted: 506 Post(s)
Liked: 158
EDID data in HDMI tells machines what channels they have.
Fanboyz is offline
Old 01-30-2008, 11:50 PM
sdurani's Avatar
Liked: 2901
I guess where ever the downmix is occuring.
Yes, as Fanboyz said the EDID on the receiver will ask for however many channels it can accept. If that turns out to be 5.1, then the player will send only 5.1 channels. If your receiver can accept 7.1 channels, even if it configured for 5.1 speakers (or even 2 speakers, like a TV), then the player will send 7.1 channels and the downmixing should happen in the receiver.
Sanjay
Sanjay
sdurani is offline
Old 01-31-2008, 12:12 AM
shamus's Avatar
Quoted: 23 Post(s)
I would think so. This stuff is so new to everyone, who knows what they missed.
With my limited audio ears, Im pretty sure the Panasonic bd10 does indeed place any info from the backs back into the sides.
shamus is offline
Old 01-31-2008, 12:01 PM
sdurani's Avatar
Liked: 2901
Indeed, check out both comments in the following post:
http://www.avsforum.com/avs-vb/showp...&postcount=119
Sanjay
Sanjay
sdurani is offline
Old 01-31-2008, 01:40 PM - Thread Starter
jshigashi's Avatar
Thank you for all of the clarification Sanjay, and others as well.
Old 01-31-2008, 11:06 PM
Roger Dressler's Avatar
Quoted: 1522 Post(s)
Liked: 710
The downmix is done in the encoder in TrueHD (maybe the same in DTS, too). That way, a 5.1 player only has to decode 5.1, not 7.1 and perform downmixing.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
