Please help me decide......A3 or A30 - AVS Forum
post #1 of 6 Old 03-06-2008, 01:05 PM - Thread Starter
viny2007's Avatar
I have a 50" Panny TH50P700U which is a 1080P plasma. I have a Pioneer Elite VSX-91TXH receiver.
Right now I have a Pioneer DV-400K which is supposedly a 1080P upconvert player. I want to replace it with either A3 or A30. I could buy either from local Circuit City.
Here are my questions:
1. Will either one of these upconvert better than my existing Pioneer?
2. A3 is 1080i and A30 is 1080p. Will the A30 be anywhere noticably better in my case? I am not sure if my TV upconvert from 1080i to 1080p.
If there is no difference then I will get the A3 since it's $90 and the A30 is $130. But I don't mind spending the $130 either if the 1080p makes a difference.
FYI. My current Pioneer upconverts connect to my Pioneer Elite via HDMI and the receiver then HDMI into the TV.
Thanks for any advise that may help me decide. I want one this weekend to play around with.
Vince
viny2007 is offline
post #2 of 6 Old 03-06-2008, 01:52 PM
mikelets456's Avatar
From what I have read, the 1080I output on both is identical. The 1080P on the A30 is supposed to be a "little rough" but the A35 is supposed to be excellent. I have a 1080I display so my decision was a "no brainer".
Like I said, this is from the forums and reviews/tests that I have read that came to this conclusion.
Acts 17:27
"His purpose in all of this was that the nations would seek after GOD and perhaps feel their way toward him and find him-though he is not far from any of us"
Yamaha Drum kit....
mikelets456 is offline
post #3 of 6 Old 03-06-2008, 02:02 PM
joemama127's Avatar
mike-
How is it possible that the A30 is a "little rough" for 1080p while the A35 isn't? Think about it..
edit- for the OP...if you have a 1080p tv then I would get the A30. I have one and feel that it's nearly the equal of my XA2 for all things except cd audio...but it isn't bad.
"The quickest way to get over your fear of plasma is to actually own *one"- joemama127
*or 3 :)
joemama127 is offline
post #4 of 6 Old 03-06-2008, 02:44 PM
jevans64's Avatar
Liked: 52
I have both the A30 and A35 and I don't see any noticeable difference in PQ between the two. The A35 gives you the multi-channel audio outs and the blue HD-DVD logo up front. Other than that, they are similar as far as HDMI output is concerned. They BOTH do 1080p/24. The A30 and A35 ( as far as Toshiba is concerned ) are your only choices to get the most out of that TV.
Amazon had the A35 for $190 last week but they are back up to $240 now.
HD-DVD = 94
Blu-Ray = 120 ( 24 Warner red2blu )
jevans64 is offline
post #5 of 6 Old 03-06-2008, 03:17 PM - Thread Starter
viny2007's Avatar
Thank you all for your comments. I researched some more on this forum and also concluded that the A30 for me was the way to go so I got one from Amazon for $130 from Vanns.
viny2007 is offline
post #6 of 6 Old 03-06-2008, 10:58 PM
erkq's Avatar
Liked: 94
Be a vulture. I went into BB abd asked about an A35 fro $99. They said, "go across the street to Magnolia. They have A35's, we only have A30's. So I went and asked the same question. "open box?" OK "no manual? no remote? 10 bucks more for a 2 year replacement warranty?" ok, ok, ok... out the door for $117. Be a vulture. They're giving these things away.
erkq is offline
Reply HD DVD Players
User Tag List
