Firmware 4.0 available for A-3, A-30, and A-35 - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 864 Old 09-28-2008, 08:45 PM
rdubz1's Avatar
updated a-30 to 4.0 no more freezing at 57 min. mark in bourne ultimatum
rdubz1 is offline
post #362 of 864 Old 09-28-2008, 09:35 PM
SkiSmuggs's Avatar
I don't know what it fixed, but I updated two HD-A3s with downloaded 4.0 without problems and they are both working well.
SkiSmuggs is offline
post #363 of 864 Old 09-29-2008, 07:48 AM
bguzman's Avatar
Quoted: 59 Post(s)
Liked: 528
Has anyone been able to update via the internet yet? I have tried but it keeps telling me that I have the latest firmware, 3.0 on an A-3.
bguzman
HT, Mitsubishi HC6500, 106" screen, Vizio P50-C1, Oppo BDP-103, Sony UBP X800, Panasonic LX-1000U, Pioneer Elite CLD-95, Faroudja NRS, DirecTV H21-100, PS3, Pioneer Elite SC-85, Def Tech; SM 450, CLR 2002, BP2X, Klipsch KSB 1.1(X4), Pro Sub 100, Polk PSW125
Old School, Sony PS-5500->Denon 103r->AU-320 SUT, Dual 1219->Shure M91ED, Kyocera DA-610cx, Realistic STD-2000D, Polk Monitor 10A
bguzman is offline
post #364 of 864 Old 09-29-2008, 09:11 AM
jdmac29's Avatar
bguzman
I can't update either via ethernet. I keep waiting don't want to have to go through all the burning issues I have read in these forums making an update disc.
jdmac29 is offline
post #365 of 864 Old 09-29-2008, 09:42 AM
Splicer010's Avatar
Liked: 40
Toshiba mails out update discs to all registered owners that requested them to do so...
Splicer010 is offline
post #366 of 864 Old 09-29-2008, 10:09 AM
BasicBlak's Avatar
I, too, can confirm this on my A35. Ultimatum was the last problematic HD DVD in my collection. Played the disc in its entirety after the v4.0 update without a single hiccup.
Panasonic PT-AX200U
Da-Lite Model B 106" HCMW
Sony KDS-60A3000
VIP 3D Theater Plus Converter w/ MonsterVision Max 3D Eyewear
Onkyo TX-SR805 (v1.08 w/DSP & HDMI Updates)
Oppo BDP-103
Sony PS3 Slim (v4.50)
Toshiba HD-A35 (v4.0)
Polk Audio RTi8 / CSi5 / FXi3
Boston 595x Subwoofers
My DVD Collection
BasicBlak is offline
post #367 of 864 Old 09-29-2008, 10:20 AM
Splicer010's Avatar
Liked: 40
I never had an issue with my Ultimatum disc on my A35 with 1.3...I skipped 2.0...and went straight for 3.0...
post #368 of 864 Old 09-29-2008, 10:23 AM
Josh Z's Avatar
Quoted: 2469 Post(s)
Liked: 1621
Originally Posted by stumlad View Post
Can someone with an A-30 confirm that you are actually viewing at 1080p24? I just updated to 4.0, and I selected 1080p24. When playing both Transformers and Pan's Labyrinth, both are showing up at 1080i. The old firmware worked at 1080p24 but with jaggies for AVC, so I'm not sure why 4.0 isnt letting me go higher than 1080i. I even tried 1080p 60 when I saw that 24 wasnt working.
Make sure you turn the Auto Frame Rate setting off.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #369 of 864 Old 09-29-2008, 11:08 AM
fubdap's Avatar
Originally Posted by Latin-Man View Post
Just upgraded my A35 from 1.3 to 4.0, and so-far-so-good.
question though; why are there 2 separate options for 1080/24p under frames and video??
I have mine set to just 1080p and under frames at 1080/24p
I will be interested in finding out the answer to the above. I was also puzzled to find that out when I did the same upgrade.
fubdap is offline
post #370 of 864 Old 09-29-2008, 01:06 PM
BasicBlak's Avatar
I came from 3.0; didn't own Ultimatium when I had 1.3, but Superman Returns was a witch with a capital "B" to play back then. On my A35, v1.3 was the last f/w where "Auto" setting on Picture Mode and AVC/MPEG-4 in 24Hz mode worked properly. However, bitstreaming high-rez audio was somewhat unstable. 2.0 was no real help to me, save for the improved playback of a couple more HD combo discs; operationally, 3.0 made my player significantly more robust and got rid of my bitstreaming issues, but the AVC jaggies problem remained. At 4.0, I now seem to pretty much have the best of all worlds (though the picture is still just a smidgen soft in Auto Picture Mode with HD DVD; it's slightly sharper when set to "Film", so the Auto setting when playing HD seems like it could use a little more tweaking by Tosh). One's mileage clearly varies with these updates in a lot of aspects, but this is what I was able to ascertain with my own setup over the life of the various updates.
Panasonic PT-AX200U
Sony KDS-60A3000
Oppo BDP-103
My DVD Collection
post #371 of 864 Old 09-29-2008, 01:20 PM
BasicBlak's Avatar
This was addressed several times in the previous incarnations of the various Tosh HD firmware threads and over in the official A30, A35 & XA2 threads, but basically it was intended to address a feature in the HD DVD spec that never materialized due to the HD DVD format being discontinued. If memory serves, I believe it was said that certain future discs would have been encoded to allow the player to identify the 24Hz frame rate automatically, or something along those lines. But, again, only if the content provider encoded the disc appropriately. One of my chief complaints about the HD DVD format was that they gave a little too much discretion to the content providers on some pretty basic features--the lack of a firmware-/player-based resume function for HD discs is a perfect example. But I digress....
Panasonic PT-AX200U
Sony KDS-60A3000
Oppo BDP-103
My DVD Collection
post #372 of 864 Old 09-29-2008, 05:02 PM
King_David's Avatar
Downloaded the ISO file, burned it to a CD-R, placed it in my A35, and nothing!
The player kept showing "LOADING".
King_David is offline
post #373 of 864 Old 09-29-2008, 05:07 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
Have you read this thread yet?
Foxbat121 is online now
post #374 of 864 Old 09-29-2008, 07:21 PM
cgking114's Avatar
Ethernet download is now available for HD-A30.
cgking114 is offline
post #375 of 864 Old 09-29-2008, 08:13 PM
King_David's Avatar
Thanks for the help, just completed it.
post #376 of 864 Old 09-29-2008, 08:27 PM
sharkshark's Avatar
...and 35 from Canadian server... dl'ing now.
sharkshark is offline
post #377 of 864 Old 09-29-2008, 08:34 PM
gotspeed6's Avatar
a35 Usa now
im so far ahead...I feel outdated
gotspeed6 is offline
post #378 of 864 Old 09-29-2008, 09:59 PM
hd James hd's Avatar
Just did 4.0 through ethernet port on A-35. Was not available yesterday.
hd James hd is offline
post #379 of 864 Old 09-30-2008, 06:43 AM
jdmac29's Avatar
I should have waited. Burned the cd last night for the first time, it actually worked with imgburn. I have not tried the bourne ultimatum lockup I had but the superman returns still freezes right after Lois and Superman get done flying and she comes into the room to eat. I guess it must be the disc, no firmware has ever fixed that freeze on that scene.
jdmac29 is offline
post #380 of 864 Old 09-30-2008, 09:26 AM
stumlad's Avatar
I don't see a choice for "off", I see a choice for auto and forced 1080p24. I tried them both. I even tried 1080p60 which doesnt work either.
I'm going to play around with a few things. I have it hooked up to my onkyo 705, so I'm going to try running it directly into my projector and see if that makes a difference. It shouldn't because my PS3 works at 1080p24 through the Onkyo.
Worst case, I'll downgrade to older bios and see if I can get 1080p24 again with those.
I'm still waiting to hear from someone else who owns an A-30 if they can truly output in 1080p. Everyone here seems to have an A35.
stumlad is offline
post #381 of 864 Old 09-30-2008, 10:12 AM
sharkshark's Avatar
well, the =cool= kids have a '35.
post #382 of 864 Old 09-30-2008, 10:38 AM
Smarty-pants's Avatar
Quoted: 751 Post(s)
Liked: 628
My projector is 720p native, but it will accept a 1080/24 rez. When fed 1080/24 the pic seems a pinch smoother.
I have both the A35 and the Onkyo DV-HD805 HD players. Neither one of them will output 1080/24 to my pj. It has always been limited to 1080i. The pricks at Toshiba have implemented the auto detect feature that will not let you feed a rez higher that what your display will accept. However, that is not true in my case and could be solved if Toshiba would allow the auto detect feature to be turned off.
Smarty-pants is offline
post #383 of 864 Old 09-30-2008, 11:01 AM
brookhart995's Avatar
Have a A35 now with 4.0 firmware and I still can't play Children Of Men! It works fine on my A3 with 4.0 firmware.... what gives Toshiba??
brookhart995 is offline
post #384 of 864 Old 09-30-2008, 04:32 PM
Massimo N's Avatar
I just tested my A30 (FW 4.0) hooked up to my Samsung LNT4665. It outputs 1080p just fine when connected directly to the TV. Player says 1080p and TV says 1080p.
I normally connect it through my receiver (Panasonic SA-XR70) and this receiver only passes through 1080i, the player and TV now say 1080i. This is just my living room setup and the TV is not that big, so I'm not too concerned.
Could it be that one of your components in your stream is sending the EDID info that it only accepts up to 1080i?
Massimo N is offline
post #385 of 864 Old 09-30-2008, 08:09 PM
stumlad's Avatar
Well, I played around with it tonight, and it seems the culprit is my monoprice HDMI powered splitter. My Onkyo accepts 3 hdmi inputs (PS3, HD DVD, PC) and outputs to my splitter which goes to an LCD tv and projector.
I tried going directly to the projector which worked. Then through the Onkyo which also worked. Once I put the splitter in there, it wouldn't go past 1080i. Funny thing is that the PS3 works fine via 1080p24, so there may be some type of handshaking/checking going on with the A-30 whereas the PS3 may not ?
stumlad is offline
post #386 of 864 Old 09-30-2008, 08:29 PM
smithfarmer's Avatar
Liked: 46
My Infocus 7210 is a native 720P pj and it receives a 1080P24 signal from my A35 w/FW 1.3 just fine. Place the blame where it rightfully belongs - on the "pricks" who designed your pj.
smithfarmer is offline
post #387 of 864 Old 09-30-2008, 08:36 PM
Liked: 46
I'm pretty sure the PS3 allows a forced 1080P24 output no matter if your display will accept it or not.
post #388 of 864 Old 09-30-2008, 09:05 PM
Quoted: 751 Post(s)
Liked: 628
Well, like I said, I've had 2 1080p/24 capable HD DVD players that will not send the signal... only 1080i. However I have had 4 different Blu-ray players hooked up the same way and they ALL will send 1080/24 to my projector. It's NOT the projector .
post #389 of 864 Old 09-30-2008, 10:44 PM
BobRob's Avatar
I also have the 7210 and A35, but have not been able to get p24 working. What settings are you using for your PJ and player, and how are you verifying that you are indeed getting p24?
"War is Peace; Freedom is Slavery; Ignorance is Strength; Blu-ray is Better."
BobRob is offline
post #390 of 864 Old 10-01-2008, 02:46 AM
Japhy Ryder's Avatar
Hi, first timer here. I know a decent bit about these sorts of things, but I really could use your help on a simple question!
I have almost the exact same set-up as you: an LNT4661 hooked up to an A30. I just updated the firmware to 4.0/2.0 successfully over the ethernet. Because of all the previous problems, I hadn't done any updates until now.
So here's my question: (since we have almost exactly the same set-up minus a glossy screen): Does the LNT-4661 work with only the 1080p rez setting or can it handle the 1080p/24Hz setting? What's your experience? What's your set-up?
That's my big question, and it's driving me batty for some reason. Besides that, if you have any other advice on the ideal video settings for this pair, that'd be great to know as well (e.g. on or off for: Enhanced Black Level, RGB Output Tange, etc.)
Oh! I have a less important follow-up question. Also, at the moment, I have the Onkyo HT-SR800 (no TrueHD, etc.). So the best sound I get for now is the Dolby 7.1, DTS-ES 96/24 Neo6 platform.
When outputting my audio from the A30 to the HT-SR800 via (gasp) optical, which setting is the best choice: PCM or Bitstream?
I really appreciate it! Any and all advice would be useful, but especially about the 1080p versus 1080p/24Hz question. Thanks.
Japhy Ryder is offline
Reply HD DVD Players
