Firmware 4.0 available for A-3, A-30, and A-35 - Page 22 - AVS Forum | Home Theater Discussions And Reviews
Old 12-21-2008, 09:04 PM
Ronald_Jeremy's Avatar
Originally Posted by Splicer010 View Post
Contact Toshiba and explain to them and see wht they say...Did you update via the disc Toshiba sent or one you burned off the update link on the Toshiba website???
CD I got in the mail.
Ronald_Jeremy is offline
Old 12-21-2008, 09:07 PM
Splicer010's Avatar
Liked: 39
Then contact Toshiba...As I said earlier...I updated both my A3 and Venturer with the Toshiba supplied disc and both output everything just fine via HDMI...You can tell them I said so...
Splicer010 is offline
Old 12-22-2008, 08:00 AM
spongebob's Avatar
Quoted: 38 Post(s)
Originally Posted by Ronald_Jeremy View Post
Ok, this is getting trippier. And no I don't do drugs. And I am not a smelly hippie despite using the word trippier.
Tried new HDMI cable. The only extra one I had laying around was a 50' one. Same results.
And BasicBlak, no I am not running both outputs simultaneously. I had to pull my xbox component cables to hook it up by component.
Now the trippy part.
The SD DVD that I have been using is a homemade recorded DVD of Blazing Saddles. That is the SD DVD I have been using for testing.
For ****s and giggles, I grabbed a few of my commercial SD DVD's for testing. I pop in South Park Bigger Longer Uncut. Same thing as the HD DVD. Only sound. Pop it out, put in American Psycho. Audio but no video. Then pop in Thomas Crown Affair. Same thing. Audio, but no video. These are all SD videos. Then I pop in my Blazing Saddles and it works.
I tested a few, um, let's say (cough) videos that don't have copy protection built in, and they play.
Any commercial DVD will not play for me now. Whether it is SD or HD.
revert back to 1.3 and go from there.
bob
spongebob is offline
Old 12-23-2008, 12:16 PM
The plot thickens. Reverted back to 1.3. It is still doing the same thing!!! I talked to Toshiba before I did this, and they are willing to swap it out for a fee. I didn't have my purchase date so they couldn't tell me the fee. Not sure if it is in warranty or not).
I am at a loss. I initialized it after the reversion.
Guess tonight, I will take it to 2.0. If that doesn't work, then on to 3.0(which I have never loaded) Maybe the HDMI port just died. Not sure why it would play non-copyrighted cds though.
Old 12-23-2008, 01:04 PM
Splicer010's Avatar
Liked: 39
Might be cheaper to buy a used unit off ebay or craigslist for $25-$40 than to pay the 'fee'...Wish I could suggest something better for you...
Old 12-23-2008, 01:47 PM
Oh, and for anyone that wants to go back from 4.0 to 1.3, see the first page of this thread for editing the ISO. Except replace the 05 14 with 0F A1
That puts the revision at 4001 (it is at 4000 with 4.0) That will trick it to take the downgrade.
Old 12-23-2008, 05:27 PM
spongebob's Avatar
Quoted: 38 Post(s)
it's available on the forum already done.
bob
Old 12-23-2008, 05:29 PM
spongebob's Avatar
Quoted: 38 Post(s)
Do you have another set w/ hdmi to try?
component works, right?
bob
Old 12-23-2008, 09:08 PM
Spongebob. Thanks for all of the help. I am whipped on this thing after tonight.
I found another HDMI in my closet. Brand new. Still had the bubble wrap on the tips. Tried that. No go. 6' long.
BTW, yes component works. Had it stuck in the back of my mind that I didn't like that and will tell you why below.
New HDMI cable exibits same behavior with direct connection to the TV. I even changed the output res of the A3. If I went to 720p, the tv would recognize that. Switch back to 1080i, tv would change res to 1080i.
Upgrade to 2.0. Same behavior.
As another test, I decide to throw in another test variable.
I always make backups of DVD's I buy in case they get screwed up. (for the mods this has been deemed legal by SCOTUS) I picked up "Burn After Reading" tonight at Target. It will not play over HDMI. I ripped it and burned a copy for legal archival purposes. The backup will play. The original will not.
Hooked up component cables after unhooking hdmi.
Anything plays with video. HD, SD, commercial and backup. But this is why I rely on hdmi that I bitched about above. The A3 will not display above 480p at 2.0 through the component output.
will it do that at 1.3? I guess I need to check that out. But as I recall that was a major gripe I had when I bought this unit.
Old 12-23-2008, 09:51 PM
Meh is a happy camper.
HDMI still broke.
But going back to 1.3 from 2.0 AND using component I can get 1080i upconversion. And I can watch the commercial CP SD DVD as well as HD DVD's. It must have been the 2.0 upgrade after I first got it that killed the upconversion of certain SD DVD's.
Thanks for your help guys.
Old 12-24-2008, 02:50 AM
Splicer010's Avatar
Liked: 39
The A3 will NOT upconvert SDVD to 720p or 1080i over component......It just won't do it no matter what version of firmware you have installed...Component will show HD DVD disc at either 480p 720p or 1080i...SDVD over component has a 480p MAXIMUM output UNLESS the SDVD has no copyright which is few and far between...Now if your copy program removes any copyright protection then you are relegated to watching only your burned discs that will upconvert with no copyright encode...But this will happen using ANY firmware version...
Old 12-25-2008, 08:48 AM
jsmiddleton4's Avatar
Quoted: 590 Post(s)
Liked: 200
"it's available on the forum already done."
I swear I searched like a good forum user and I can not find a link to an already hacked ISO file. Link anyone?
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is offline
Old 12-25-2008, 11:23 AM
Jon Spackman's Avatar
A serch for "firmware mod" got this among ten other links for HD DVD firmware threads:
http://www.avsforum.com/avs-vb/showt...t=firmware+mod
Just enjoy HD in whatever form you can (Sat, Cable, D-VHS, OTA, HD DVD, or BD).
Jon Spackman is offline
Old 12-25-2008, 02:23 PM
Quoted: 590 Post(s)
Liked: 200
Thanks Jon but I've looked at those threads. I d/l the hex editor and if I end up with an A35 over the next week or so I'll just check 4.0 firmware and if I need to go back to 1.3 I'll hack the .iso file myself.
Old 12-25-2008, 02:40 PM
spongebob's Avatar
Quoted: 38 Post(s)
http://www.avsforum.com/avs-vb/showp...9&postcount=15
back to 1.1 and go from there.
bob
Old 12-25-2008, 03:13 PM
Quoted: 590 Post(s)
Liked: 200
Thanks. Not sure I'll have an A35 or not but if I pick one up I'll play.....
Old 12-29-2008, 06:11 AM
Karyyk's Avatar
So the Venturer *WILL* update with the Toshiba firmware?
I bought a number of these on the cheap to give as Christmas presents (and kept one for myself) and am wanting to make sure everyone I gave one to gets the best experience out of the player. Has anyone tried the 4.0 firmware on the Venturer model?
Karyyk is offline
Old 12-29-2008, 06:28 AM
Splicer010's Avatar
Liked: 39
Yes...The Toshiba 4.0FW disc for the Toshiba A3 DOES work on the Venturer...I myself have updated mine as I stated in my post you quoted...
Old 01-09-2009, 07:50 PM
tonngo0's Avatar
Hmm ... should I update my A35 to 4.0, I still has it at 1.3 version firmware.
How about Toshiba gives a new firmware to make all HD-DVD player region free.
tonngo0 is offline
Old 01-09-2009, 08:13 PM
bkc6j's Avatar
In another thread I've been talking about a problem where I have a disc stuck in the drive (error 200bc600) that will not eject no matter what I do.
I otherwise have control of the player (can get to Setup menu, etc.). Since I am FW 3.0 now, one of my last resort options (before just sending the thing back to Toshiba) is to try and update to FW 4.0.
So my current question (which seemed more appropriate to go in this thread) is: What happens if I do a FW update with a disc (movie) in the drive??
I know that the instructions all say "Do not run FW update with a disc in the drive." ... but I have been wondering if they are just being over cautious. Maybe worried you will run an auto FW update with another FW disc in the drive or something.
Any thoughts or experience that anyone has would be greatly appreciated!
PS: The disc is a brand new 'The Rundown' movie HD-DVD disc
bkc6j is offline
Old 01-09-2009, 09:08 PM
Splicer010's Avatar
Liked: 39
Do not update fw with a disc in the machine!!! You will brick the player!!!
Old 01-09-2009, 11:09 PM
Coyote Waits
htwaits's Avatar
Quoted: 920 Post(s)
Liked: 2030
Call Toshiba. I just checked my A30 and it doesn't have a jam release hole. You probably have to open the case.
Don't do a firmware update.
htwaits is online now
Old 01-09-2009, 11:46 PM
bkc6j's Avatar
I did call them and didn't get much help from the front line technician (seemed like his opinion was that any problem not fixed by pulling the plug for a while was going to result in sending it back in).
I specifically asked them about a way to manually open it to get the disc out and they wouldn't tell me anything.
Anyone know any tricks to get the disc out?
I'd like to avoid opening the case (as it might void the warranty), but am wondering if I could use something to just pull the drawer open with it unplugged (no idea if the mechanism is in 'neutral' mode with it unplugged or if that would screw something up).
bkc6j is offline
Old 01-10-2009, 12:20 AM
Coyote Waits
htwaits's Avatar
Quoted: 920 Post(s)
Liked: 2030
Keep going higher until you get someone who makes sense to you.
Don't force the tray either.
Also, doesn't Toshiba have any authorized repair centers for carry in?
BasicBlak's Avatar
As has been stated by the consensus (though there are a few dissenters), v4.0 is a worthy update that adds a great degree of overall system stability. As to your region-free question, HD DVDs are pretty much already region free (I have several import titles); that happens to be one of the reasons why many dual-format content providers would occasionally delay the domestic HD DVD release of a title vis-a-vis its Blu-ray counterpart. However, if you're looking to play import SD DVDs, then I wouldn't hold my breath waiting for that update.
Panasonic PT-AX200U
Da-Lite Model B 106" HCMW
Sony KDS-60A3000
VIP 3D Theater Plus Converter w/ MonsterVision Max 3D Eyewear
Onkyo TX-SR805 (v1.08 w/DSP & HDMI Updates)
Oppo BDP-103
Sony PS3 Slim (v4.50)
Toshiba HD-A35 (v4.0)
Polk Audio RTi8 / CSi5 / FXi3
Boston 595x Subwoofers
My DVD Collection
BasicBlak is offline
Old 01-11-2009, 09:52 AM
I WANT MORE's Avatar
Quoted: 399 Post(s)
Liked: 256
Originally Posted by BH13 View Post
BSTNFAN,
I had the same exact same issue when I tried to update to 4.0. Here is what I found out:
When I updated the firmware to 3.0, it deleted all of my settings, audio, video, etc. I don't know if this was supposed to happen, but it did. I forgot all about this when I went to update to 4.0. I finally realized that it had reset all of my network settings to the factory default.
Check your network settings closely to make sure that you have everything set up the way you originally had it. Clear everything out of the network settings and start fresh. I would bet this will help you.
How do you do this? I am getting the Can not find out server message.
Perhaps I misremembered.
I WANT MORE is offline
Old 01-11-2009, 05:23 PM
stretch35's Avatar
If I remember correctly from pix I've seen of the inside of 3rd generation hd players, the drive is a sealed box, not like opening a cd player where you can see disc spinning.. when my tosh unit would hang up and wouldn't open, I would hold power button in for several seconds (with unit on) that would force shutdown. Upon turning unit back on unit worked fine. I think you pulled plug already what happens when you plug it back in?
stretch35 is offline
Old 01-12-2009, 06:08 AM
generallee's Avatar
My wife just brought home a Tosh A3 she picked up at her church bazzar. I dared not laugh at her so I called Tosh for a firmwre update disk which should arrive any day. I think I have an extra HDMI cable under the bed but have not tried to run the player yet. Does the forum have any tips?
generallee is offline
Old 01-12-2009, 06:20 AM
Splicer010's Avatar
Liked: 39
Why would you laugh at her???
Old 01-12-2009, 06:38 AM
generallee's Avatar
I dared not or I would be beaned with the frying pan. She is always bring home things she thinks are good buy's. Now I guess after I get it hooked up, I will have to go looking for HD DVD's
