Firmware 4.0 available for A-3, A-30, and A-35 - Page 29 - AVS Forum | Home Theater Discussions And Reviews
post #841 of 864 Old 03-15-2011, 11:04 AM
shyoung's Avatar
Thanks a lot to those who posted the information that on a Macintosh the firmware for Toshiba A3 must be burned to a CD using Disk Utility not Toast. I was about to trash my A3 when I finally found that info. It worked (after ruining about 6 CD's using Toast, trying different formats, different burning speeds, etc. - and trying to connect through the ethernet to no avail.)
shyoung is offline
post #842 of 864 Old 04-16-2011, 05:32 PM
alwaller's Avatar
Quoted: 56 Post(s)
Hi all
I have a a30, purchase when they first came out, upgraded too 2.9( I think )
Plays everything, afraid to upgraded again. If it is not broke don't fix it. Am I
missing anything by not upgrading to the latest firmware 4 ?
1) Polk Audio LSI 9 and matching center
2) RSL CG4 (side speakers)
3) SVS PCI 20-39 subwoofer
4)Onyko TX-SR705 receiver.
5) Outlaw 7125 amplifier
6) Panasonic Blu-ray Player
alwaller is online now
post #843 of 864 Old 04-16-2011, 05:43 PM
Splicer010's Avatar
Liked: 40
I am glad I updated to 4.0FW. No more freezing, plays everything.
Splicer010 is offline
post #844 of 864 Old 04-17-2011, 12:29 PM
BSTNFAN's Avatar
Quoted: 23 Post(s)
Liked: 34
Originally Posted by alwaller View Post
Hi all
At this point, if it plays everything you have and you're happy with it, don't touch it. If you pick up some new (to you) discs and have problems, worry about it then.
BSTNFAN is offline
post #845 of 864 Old 04-17-2011, 07:03 PM
BasicBlak's Avatar
Originally Posted by splicer010 View Post
i am glad i updated to 4.0fw. No more freezing, plays everything.
+1.
Panasonic PT-AX200U
Da-Lite Model B 106" HCMW
Sony KDS-60A3000
VIP 3D Theater Plus Converter w/ MonsterVision Max 3D Eyewear
Onkyo TX-SR805 (v1.08 w/DSP & HDMI Updates)
Oppo BDP-103
Sony PS3 Slim (v4.50)
Toshiba HD-A35 (v4.0)
Polk Audio RTi8 / CSi5 / FXi3
Boston 595x Subwoofers
My DVD Collection
BasicBlak is offline
post #846 of 864 Old 05-23-2011, 07:13 AM
avman09's Avatar
I have 4.0 but has trouble with Scorpion King at around the 40 minute mark. It would still play but the image froze or moved slowly for a few minutes then it would go back to normal and finished the disc without trouble. Anyone else has issues with that disc?
avman09 is offline
post #847 of 864 Old 05-23-2011, 07:16 AM
Splicer010's Avatar
Liked: 40
It's been awhile, but I don't recall any issues...
post #848 of 864 Old 09-26-2011, 07:18 PM
iamian's Avatar
Quoted: 51 Post(s)
Liked: 43
Is there any difference between the A-3 and the A-30 besides the 1080i and 1080p?
iamian is offline
post #849 of 864 Old 09-27-2011, 10:00 PM
8traxrule's Avatar
The A30 can be made region-free and PAL-capable with a downloaded firmware CD. A similar hack also enables it to bitstream Dolby Digital Plus and DTS (which you need to get the discrete extra surround channels on discs like Top Gun) but it won't bitstream Dolby TrueHD or DTS Master Audio.
8traxrule is offline
post #850 of 864 Old 09-28-2011, 08:25 AM
Al Sherwood's Avatar
Quoted: 754 Post(s)
Liked: 277
Not worried about region free or PAL, but DD+ and DTS bitstream would be interesting, can you provide details or a link to the information?
thanks!
Al
Al Sherwood is offline
post #851 of 864 Old 09-29-2011, 02:55 PM
8traxrule's Avatar
https://skydrive.live.com/?cid=6948f...0BDD190C%21437
You may need a Windows Live account to get to this, which is relatively easy.
post #852 of 864 Old 09-30-2011, 01:41 AM
Quoted: 754 Post(s)
Liked: 277
Thanks, I have the files downloaded (no problem as I have a Windows Live account already).
Interesting naming convention for the files?
Have you tried the process?
Al
post #853 of 864 Old 09-30-2011, 04:00 PM
8traxrule's Avatar
Yes, I used these on my A30 when I got it last year. Be sure to read the instructions, as one of the discs will shut the player off suddenly while 'installing' though that doesn't hurt anything.
post #854 of 864 Old 10-02-2011, 07:47 AM
Quoted: 754 Post(s)
Liked: 277
Thanks for the information and the files, I read the procedure and it did have a couple of interesting steps,(step 5, pulling the plug) not really 'by the book' as it were.
Are you referring to step 16, regarding it turning off suddenly?
Al
post #855 of 864 Old 10-12-2011, 02:03 PM
train driver's Avatar
Greetings.
My A30 just died. It was working fine during the last movie played, and it shut down the same as it always has. When I tried to power it up yesterday, it was stone dead. Nothing. It was as though it was unplugged. I tried all of the buttons on both the unit and on the remote. I unplugged it and checked the fuse. I even took the fuse out and put it back in. I even tried jumpers in place of the fuse. Still nothing.
The only exception I noticed was about two weeks ago, the unit stopped playing a disk, and I got the error message "408bc504". I've never did a firmware update (it worked just fine without the updates). And the movie that was playing when I got the error message was Matrix, which has been played many times without problems.
Did my power supply die, or did the entire unit just become a doorstop?
Helpful suggestions would be appreciated.
Unhelpful suggestions are also welcome, but only if they are entertaining.
train driver is offline
post #856 of 864 Old 10-12-2011, 04:17 PM
Quoted: 754 Post(s)
Liked: 277
That is a bummer, I could suggest a few things but you would need a meter and a reasonable understanding of electrnics to check for the basics...
The other options would be a used player and swap some parts around, having said that if find a used one that works then best to use it and not tempt fate!
I bought a number of players through the local ads, spares for parts and remotes, just in case something like you have just experienced happens to me.
Al
post #857 of 864 Old 10-12-2011, 05:08 PM
Al,
Thanks for the good ideas; alas, my knowledge of electronics is limited to this side of the power button.
I do have an older A2, which will have to suffice. When that one goes bad, perhaps I'll have enough parts to assemble a working unit. Or maybe I'll just buy the Blurays of the relatively few HD titles I have.
I was hoping that someone might have had the same problem and that the solution was not too expensive.
Thanks again.
post #858 of 864 Old 10-13-2011, 03:38 AM
8traxrule's Avatar
Are you at least getting the red light on the player when it's plugged in? If not, it's most likely a power problem. The only way I've seen these players not work is when the display says "WELCOME" and never gets past that.
post #859 of 864 Old 10-13-2011, 10:12 AM
Quoted: 754 Post(s)
Liked: 277
Originally Posted by train driver View Post
Al,
Thanks again.
You are welcome, I am embarrased to say how many HD-DVD players and drives I have, but then again when they cost anywhere from $10-40 it doesn't really break the bank.
I have over 100 titles so I like to be covered!
As 8traxrule mentioned, do you even get a red power indication on the front panel?
Al
post #860 of 864 Old 10-13-2011, 08:41 PM
This is going to sound strange, but after letting the unit sit unplugged for a few days, and after reading 8traxrule's comment, on a whim (even though I was certain that the red light was not lit), I decided to plug it back in and check for the light. And guess what--the light DID come on. Then I pushed the power button, and it came to life just like it had every time before.
It is now working again; why, I have no idea.
post #861 of 864 Old 10-13-2011, 10:32 PM
joeags's Avatar
I believe that by having the unit unplugged, you did a reset of the player. Did you have to update your preferences again after restarting? That would be a pretty clear indicator. I and a few others had problems with the 2nd generation players with the sound output, and unplugging the player fixed it for a short time. But it generally failed again in the future. I'd use this time to ensure that you have a good spare!
joeags is offline
post #862 of 864 Old 10-14-2011, 06:23 AM
When I first encountered the problem, I did unplug the unit for a brief time (that is when I checked the fuse and tried jumping the fuse bracket). I then replugged it in and the unit was still dead. Which is why I was so surprised when it came back to life.
Regarding having to reset preferences, yes, they needed resetting; however, each time I unplug the unit (for lightning storms) the preferences need to be reset.
I do have a spare (A2). I did like the IQ better in the A30. I had mainly used the A2 for watching standard-def DVDs.
I haven't had a chance to watch a movie on the A30 deck yet (I will try tonite). I'll report back on how it performed.
Thanks to all who have helped me with this!
post #863 of 864 Old 10-20-2011, 06:26 AM
Finally had a chance to try out the deck; it performed flawlessly throughout a 2.5 hour movie. I guess it had come back from the dead (just in time for Halloween). Still have no idea what happened.
Ghost In The Machine?
post #864 of 864 Old 05-28-2012, 04:13 AM
Super Moderator
markrubin's Avatar
Quoted: 1273 Post(s)
Liked: 2772
unstuck
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
Reply HD DVD Players
