New Firmware 4.0 HD-XA2/HD-XF2/HD-A20 - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #571 of 589 Old 05-12-2015, 10:11 AM
jdryyz's Avatar
Quoted: 36 Post(s)
I just needed to set the clock?
I noticed my clock was not set correctly (probably after my last major power outage). It still thought it was 2008 . So, I set the correct date and, hey, no more warning message!
This makes me wonder why a clock is needed for an optical disc player in the first place. None of my Blu-Ray players require this. I suppose it has something to do with time-sensitive content that may be available on some discs. And, in fact, it was Universal that was offering something like that if I'm not mistaken. I forget the name of it though. It was their equivalent of "BD live", right?
Now if only I can get some advice on my tray problem.
jdryyz is offline
post #572 of 589 Old 05-12-2015, 10:14 AM
Rambler358's Avatar
Quoted: 94 Post(s)
Liked: 25
Sounds like a hardware issue. Things do fail over time...
Rambler358 is offline
post #573 of 589 Old 05-12-2015, 10:22 AM
jdryyz's Avatar
Quoted: 36 Post(s)
If you're talking about the tray, yeah I have no doubt it is a hardware issue. But if it is something simple I can replace, I would like to know. Perhaps it is just the rubber o-ring that is used for the eject motor. I have no idea what the replacement part would be though. Hopefully I won't have to replace the entire drive.
jdryyz is offline
post #574 of 589 Old 05-12-2015, 11:59 AM
barrelbelly's Avatar
Quoted: 348 Post(s)
Liked: 434
I've had to reset clocks on my HD A35...HD A3...and even my older (but still preferred Panasonic DMP BD35 many times. In fact...every time power was disrupted from them. Whether voluntarily or involuntarily. It has never related to Hardware issues. But was software related to information stored in "Persistent" memory. Those earlier players used persistent memory files to access & link with the internet for updates and other content for players and movies.
barrelbelly is online now
post #575 of 589 Old 05-12-2015, 12:02 PM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
The HD DVD drive in the A2, A20 and XA2 is the same. See if you can find a cheap A2 or A20 on ebay, and just swap the drive. If you find a player with the WELCOME fault, it is ok for your need. That fault is not drive related.
Viking61 is offline
post #576 of 589 Old 05-12-2015, 12:05 PM
jdryyz's Avatar
Quoted: 36 Post(s)
Sounds great! Thanks for the tip.
jdryyz is offline
post #577 of 589 Old 05-12-2015, 09:00 PM
Worf's Avatar
Quoted: 569 Post(s)
Liked: 307
Aren't the drives keyed to the motherboard? At least they were on the a1 and such.
Worf is offline
post #578 of 589 Old 05-13-2015, 11:51 AM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
On the 2nd and 3rd generation players it is very easy to change the drive. Just to open the player and unplug the powercable and datacable going from the drive to the powerboard and the motherboard. After that it is just a few screws holding the drive in place.
Viking61 is offline
post #579 of 589 Old 05-13-2015, 09:00 PM
Worf's Avatar
Quoted: 569 Post(s)
Liked: 307
I know the drive is easily changed, I meant the firmware itself locks itself to the drive serial number.... Change the drive and it stops working.
Worf is offline
post #580 of 589 Old 05-13-2015, 11:03 PM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
I'm not aware that the drive is locked to anything . . but . . I do seem to recall that the firmware updates have 2 sections built into them: 1 for the motherboard and the other for the drive. So if you swap out a drive and install one from a different player running a firmware version different from the one installed in the player, that might cause an incompatibility? Not sure how one would deal with that beyond ensuring both units (the player donating the drive and the one getting the drive) are both running 4.0 before swapping the drive.
A long-time audio/video addict!
Rich86 is offline
post #581 of 589 Old 05-13-2015, 11:22 PM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
I changed drive on my HD-XE1 (European version of the HD-XA2) with the drive from a cheaper player which was on an early firmware version. The drive worked without any obvious errors, but to be sure I downgraded and upgraded again the firmware of my player.
Viking61 is offline
post #582 of 589 Old 05-14-2015, 09:08 PM
Worf's Avatar
Quoted: 569 Post(s)
Liked: 307
Ok, guess it was just the old a1/xa1 units. Those had an encrypted partition that was keyed to he specific drive. Swap the drive and it didn't work. Of course, you could decrypt it on a regular PC with the drive connected to the PC.
Worf is offline
post #583 of 589 Old 03-10-2017, 02:41 PM
jra166's Avatar
Quoted: 12 Post(s)
Hello Everyone,
I have had two XA2s in storage for a few years, but have recently begun building a live music/concert library. Most concerts of course are shot at 60fps. I have pulled out one of my XA2's to upscale the SD concert footage and am blown away by how much better they look than my OPPO 103D. I had forgotten just how good the XA2 was.
Both of my XA2s are still on Firmware 2.7. If my primary use for the Toshiba is to upscale concert DVD's and the rare DVD movie, is there any benefit to upgrading to firmware 4.0? I have had no issues with 2.7 so the upgrade would be purely for any added benefit if there is any. Thanks.
jra166 is offline
post #584 of 589 Old 03-10-2017, 11:21 PM
Worf's Avatar
Quoted: 569 Post(s)
Liked: 307
Probably the best answer is if it ain't broke, don't fix it....
jra166 likes this.
Worf is offline
post #585 of 589 Old 03-11-2017, 10:21 AM
snowghost's Avatar
Quoted: 25 Post(s)
I'm still pissed the format died. Plus I have a ton of brand new ones that have Laser Rot. Now that I work for Warner Bros. I'm going to see if somebody will swap them out for BD.
Rambler358 and jra166 like this.
"The best long distance runners eat raw meat, run naked and sleep in the snow."
snowghost is offline
post #586 of 589 Old 03-12-2017, 07:10 PM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
Warner (Burbank, CA) was pretty good about that for quite a while - but they have changed their ways somewhat recently and limited their willingness to assist customers who have been bitten by their defective quality manufacturing partner (cinram?) for HD-DVDs!
Rich86 is offline
post #587 of 589 Old 03-15-2017, 08:04 AM
exm
exm's Avatar
Quoted: 136 Post(s)
Liked: 83
Originally Posted by jra166 View Post
Hello Everyone,
I used to own the XA2, and I sold the unit with all discs a few years back. Right now I'm the happy owner of an Oppo UDP-203, and I'm sure all Oppo units upscale at least as good as the XA2. The XA2 is still a great unit though.
In the past I used to sell region-free V4.0 firmware for the XA2 on eBay. I still have the instruction and .iso files. If you have a FTP server or location where I can send these, I'm more than happy to help you out. As far as "should you update"? Here's what Toshiba said: "This firmware update improves network connectivity for supporting the download of web- enabled network content associated with certain HD DVD discs, improves certain video and audio processing capabilities, and also addresses certain disc playback and HDMI/DVI related issues identified by Toshiba."
Some other good links:
HD DVD Master Firmware Burning Thread
HD-DVD Firmware links for all models
exm is offline
post #588 of 589 Old 03-15-2017, 09:04 AM
inspector's Avatar
Quoted: 133 Post(s)
Liked: 66
I finally took away my HDA1 from my HT...sorry to see it go.
...finally retired and spending time in my HT!!!
Equipment consists of: Epson 6040 3D/4K UB Projector(ISFed); 110" 16x9 Dalite HD Progressive Screen; Samsung 3D/4K K8500 Player; Definitive Speakers (Center, Towers, Rears); Earthquake P12 sub; Onkyo 608 A/V Receiver; MX990 Remote; 5 Bello chairs; Coaire Mini-split A/C.
inspector is offline
post #589 of 589 Old 03-16-2017, 02:02 AM
BTBuck1's Avatar
Quoted: 13 Post(s)
I just took mine back out and plugged it in lol, had it boxed up
Since I got the HD-a30 on a crazy close out back when the format crashed and burned, but with the recent acquisition of a Samsung ks8000'for my man cave, had a extra set that needed a player so the A1 went to the older Sony 1080p set and the a30 to the ks8000!
It's fun to toy with the old relics of HT past.
HDDVD owner: 360 add-on, HD-A30, HD-A2, A1
Blu-ray disc supporter: ubp-x800, XB1s,ps3-60gb, Oppo BDP-93, ubd-k8500
TV's: xbr55x850b/kdl55hx729/un49ks8000
Audio: Denon/Polk, Onkyo/Klipsch-Sony, Samsung SB
BTBuck1 is offline
Reply HD DVD Players
