New Firmware 4.0 HD-XA2/HD-XF2/HD-A20 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 582 Old 09-25-2008, 10:13 AM
arty100's Avatar
My XA2 will not take the upgrade. This is a first for me as I have done this with no problem in the past.
I have tried iso-burner, roxio, nero and no method works.
Someone who has succeeded, what method did you use to transfer
the .iso file to CD?
arty100 is offline
post #92 of 582 Old 09-25-2008, 10:17 AM
cal87's Avatar
Quoted: 30 Post(s)
Liked: 29
I use ImgBurn
cal87 is offline
post #93 of 582 Old 09-25-2008, 10:27 AM
Lonely Surfer's Avatar
DeepBurner here. I burned a CD and updated my XA2 yesterday.
Lonely Surfer is offline
post #94 of 582 Old 09-25-2008, 10:30 AM
mikey ra's Avatar
Here's a little tidbit from me. I burned the iso to a cd-r. When I placed the cd in the player (XA2) the screen displayed "Loading" for almost 4 1/2 minutes before the "Ver" came up and I could accept the update. Patience is required before the update finally begins (the update from disc took 14 minutes total, including the loading delay).
mikey ra is offline
post #95 of 582 Old 09-25-2008, 10:46 AM
shabre's Avatar
I used Nero express burn....worked quick and smooth along with the FW update. Good luck!!!
shabre is offline
post #96 of 582 Old 09-25-2008, 10:49 AM
arty100's Avatar
Thanks everyone!
DeepBurner did the trick and waiting five minutes for the disk to
load.
I was fearful the long wait was bricking my XA2.
arty100 is offline
post #97 of 582 Old 09-25-2008, 11:14 AM
polyscroll's Avatar
I just updated two of my HD-A2s to Firmware 4.0 without a hitch. Used Nero to burn the CD-R with no problems.
I have noticed no changes so far other than the significantly sped-up forward and reverse scanning. It seems the frame-rate while scanning is higher. I would say that is an improvement compared to the way it used to be.
I'll try the XA2 and A20 next.
Kudos to Toshiba for their continued listening to our needs and support. I wish all consumer electronics companies behaved like this.
Cheers
polyscroll is offline
post #98 of 582 Old 09-25-2008, 11:53 AM
Sirluckyj's Avatar
Mine did the same thing.
Jim
Sirluckyj is offline
post #99 of 582 Old 09-25-2008, 12:13 PM
jcp2's Avatar
Quoted: 37 Post(s)
Liked: 25
A lot of people are mentioning cd-r's for the update. I thought that one can only do the update on a dvd-r. Am I mistaken?
jcp2 is offline
post #100 of 582 Old 09-25-2008, 12:19 PM
GmanAVS's Avatar
I will do the fw upgrade on my XA2, A35 and 2 A2s this week end, am thrilled about the initail reports!!!
I have had a Pioneer 51FD BD player for 2 months now and my 2 year old (ok 1yr, 9mo.) XA2 beats it hands down for SD DVD playback and is at par with High Def content,
.... enugh said , wtg Toshiba !
GmanAVS is offline
post #101 of 582 Old 09-25-2008, 12:23 PM
slimm's Avatar
Originally Posted by akadennis View Post
Has this been fixed yet?
The 4.0 firmware download for the A35 is still borked!
slimm is offline
post #102 of 582 Old 09-25-2008, 12:56 PM
Ted_K's Avatar
4.0 kills the menu access on The Searchers again, like 3.0 did, on the HD-A2. Time to hex edit another version of 2.7. Nice try, though....
Ted_K is offline
post #103 of 582 Old 09-25-2008, 01:15 PM
mikey ra's Avatar
Yep - CD is what is needed, not dvd.
mikey ra is offline
post #104 of 582 Old 09-25-2008, 01:16 PM
polyscroll's Avatar
Yep, You are mistaken.
CD-Rs work fine for Firmware upgrades.
post #105 of 582 Old 09-25-2008, 01:17 PM
Rolls-Royce's Avatar
Quoted: 239 Post(s)
Liked: 352
It needs to be on CD-R. I burned mine using Nero. My XA2 went into the update routine almost instantly when the disc was inserted, and the update itself went very smoothly and quickly.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #106 of 582 Old 09-25-2008, 01:35 PM
boblinds's Avatar
Liked: 35
I just burned a CD with ImgBurn and stuck it in my XA2. Stepped out of the room to work on a composition project and, when I returned, it was all done. I verified that it updated to 4.0 but I haven't tried it out yet.
boblinds is offline
post #107 of 582 Old 09-25-2008, 02:32 PM
brinyhenry's Avatar
Just a quick FYI for everyone that updates. Please re-initialize your player first before trying it out. This usually clears up any quirks or bugs you might see after upgrading. Remember your settings because this resets everything.
brinyhenry is offline
post #108 of 582 Old 09-25-2008, 02:34 PM
BSTNFAN's Avatar
Quoted: 21 Post(s)
Liked: 34
Fixed now!
BSTNFAN is offline
post #109 of 582 Old 09-25-2008, 02:56 PM
shabre's Avatar
Good suggestion, although I have never done that, it is still a good idea!
shabre is offline
post #110 of 582 Old 09-25-2008, 03:44 PM
sharkcohen's Avatar
Every firmware release people recommend this. However, I have not once done this, and have not had any issues. I do not believe it is necessary to reinitialize after installing a new firmware.
sharkcohen is offline
post #111 of 582 Old 09-25-2008, 04:13 PM
nicholc2's Avatar
OK, I am totally at a loss here. I tried updating the A30 by internet and by the 4.0 download and in both cases, it says it is already updated. Anyone have any ideas?
nicholc2 is offline
post #112 of 582 Old 09-25-2008, 04:27 PM - Thread Starter
Zodon's Avatar
Are you sure you used this file?
http://tacp.toshiba.com/tacpassets-i...-A30-4000N.zip
As for the ethernet update, Toshiba seems to be taking their sweet time posting the 4.0 update there.... I've been checking it periodically as I don't have a cd burner...the suspense is killing me.
Zodon is offline
post #113 of 582 Old 09-25-2008, 04:56 PM
allargon's Avatar
Quoted: 51 Post(s)
Liked: 44
4.0 is starting to look a lot like 2.7 which doesn't make me happy at all.
I'm having random issues reading various combo discs (e.g., DVE and Assassination of Jesse James) on my A20. I'll keep an eye out. I remember despising 2.7 for that reason. I might need a hex-editor to go back to 2.6!
allargon is offline
post #114 of 582 Old 09-25-2008, 05:16 PM
PRO-630HD's Avatar
Quoted: 212 Post(s)
Liked: 129
Still not downloading through the ethernet port.
PRO-630HD is offline
post #115 of 582 Old 09-25-2008, 05:50 PM
Scubawoman's Avatar
I had freezing of August Rush (combo disc) with 2.7. With 4.0 no problems playing. I did initialize after installing 4.0. If you didn't initialize try that first.
Scubawoman is offline
post #116 of 582 Old 09-25-2008, 06:15 PM
sharkcohen's Avatar
I haven't had a chance to watch a single disc on my XA2 since installing 4.0. I work too much
post #117 of 582 Old 09-25-2008, 07:48 PM
nicholc2's Avatar
Yep, that's the one.
nicholc2 is offline
post #118 of 582 Old 09-25-2008, 09:36 PM
Yoeddy1's Avatar
Downloaded 4.0 iso for my A-30. Installed just fine. Too bad I don't have any hd dvd's anymore. Looking forward to upconverting some dvd's.
Yoeddy1 is offline
post #119 of 582 Old 09-25-2008, 10:06 PM
PRO-630HD's Avatar
Quoted: 212 Post(s)
Liked: 129
I know some people gave all their hddvd's away. Seemed foolish when many of the Paramount titles had superior VC1 encodes vs. MPEG-2 and 1.5 MBPS DD+ vs. 640 kbps DD. Many of those Universal HDDVD's will not be on bluray for some time if at all. Universal is only releasing about 3 titles a month.
post #120 of 582 Old 09-25-2008, 11:06 PM
Rich86's Avatar
Quoted: 128 Post(s)
Liked: 64
I'm very glad a lot of folks decided to unload their HD-DVD's - because - I have picked up a bunch of them at major bargain prices - and they are absolutely terrific - no need for blu-ray versions of these puppies at all ever!!
A long-time audio/video addict!
Rich86 is offline
Reply HD DVD Players
