Downgrade HD-A30 from firmware 4.0 to 1.3/2.0? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 10-31-2008, 08:50 PM - Thread Starter
santora's Avatar
I just updated my A30 to 4.0 and now it won't play any HD DVDs. It starts to stutter and then freezes up. Looking to roll it back to either 1.3 or 2.0. Is there a modified firmware out there for that?
And if not, how do I edit the firmware for the A30 (using a hex editor) to roll back the firmware? What settings need to be changed?
Mark Santora
santora is offline
post #2 of 14 Old 11-01-2008, 01:03 AM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
Mark Santora
  1. Download the 1.3 firmware file
  2. Open the ISO file in a hex editor
  3. Change the value in 26/27 from 05 14 to 0f a1
  4. Save the ISO file and make a firmware CD from it
Viking61 is offline
post #3 of 14 Old 11-01-2008, 08:53 AM - Thread Starter
santora's Avatar
Thanks Viking61. I'll give that a shot. Quick question though - this is the mod for the A30 and not the A3, right? It looks similar to other mods I've already seen.
Mark Santora
santora is offline
post #4 of 14 Old 11-01-2008, 09:31 AM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
It's the same procedure for all Toshiba HD DVD players.
Inside the firmware there is a value that functions as "run if current firmware version is lower than". Your current firmware version is 4000 (after installing 4.0), and all you actually do is to set this "run if lower than" value to 4001 (hex 0f a1).
Btw, have you tried emptying the "Persistent Storage". I have seen others report it cured similar problems.
Viking61 is offline
post #5 of 14 Old 11-02-2008, 04:23 AM
Electone's Avatar
Mark Santora
That's really unfortunate. Firmware 4.0 has been a blessing for the majority of people who have applied it.
Electone is offline
post #6 of 14 Old 11-02-2008, 12:38 PM - Thread Starter
santora's Avatar
I know. I've read a lot about how great it was. Unfortunately it just seems to have played havok with my machine. I'm going to downgrade today and then see if I can go back up to 4.0 in the future.
Apperantly there are a small number of players that get stuck during boot up with 4.0. Mine plays then starts giving me problems. Strangely - no problems with DVDs. And the HD DVDs are in excellent condition - no scratches.
Mark Santora
santora is offline
post #7 of 14 Old 11-02-2008, 12:39 PM - Thread Starter
santora's Avatar
Good to know. I will be trying it this afternoon. Thanks again.
Mark Santora
santora is offline
post #8 of 14 Old 11-04-2008, 03:03 PM
tbase1's Avatar
Quoted: 47 Post(s)
Liked: 70
I upgrade my a30 today and all is well. As soon as I get a chance I'll upgrade my a20.
tony4k
tbase1 is online now
post #9 of 14 Old 08-28-2011, 12:59 PM
photofreakdave's Avatar
I know this is an old post but does anyone happen to have any firmware before the 4.0 for the Hd-A30 that they could upload and send me a link to. I have been looking everywhere but toshiba deleted it from their site.
I was stupid and just did a 4.0 Upgrade and now no Warner Brothers HD-DVDs will play without glitches and pauses which wreck the movies especially on the Matrix and 300 movies
photofreakdave is offline
post #10 of 14 Old 08-29-2011, 07:29 AM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
https://skydrive.live.com/?cid=6948f...0BDD190C%21294
Look under the 'Rollback firmware' folder if you want a ready modified firmware file to roll back to ver. 1.3 or under 'Original firmware' if you want modify it by yourself for another version.
Viking61 is offline
post #11 of 14 Old 11-23-2011, 08:09 PM
ou82mutch's Avatar
ok i burned the already modified version to a disc and insterted it into my hd dvd a-2 player and it takes a few minutes and goes to ver up and then i click yes and tells me that cannot find server. i then tried to change the hex myself and same thing. what am i doing wrong. Trying to rollback to a lower version than 4.0 preferably something lower than 3.0. Anyhelp would be hot. thanks!!!!
ou82mutch is offline
post #12 of 14 Old 11-27-2011, 12:08 PM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
Sounds like you tried to start the update from inside the Setup menu. That is not the way to do it. You shall just put the CD in, and the update should start by itself. Did you burn the iso-file to a CD as an image? You can use the free software ImgBurn (www.imgburn.com) or similar. And you have to use a CD-R or CD-RW. You can't use a DVD.
Viking61 is offline
post #13 of 14 Old 12-03-2011, 01:02 PM
ou82mutch's Avatar
Thanks used the imgburn and it is now going. i needed to get it back to where it was before as my wb movies are not playing correctly and it is getting me hulk mad....lol. The software is was using before did not burn as an image.
post #14 of 14 Old 12-04-2011, 05:16 PM
Rich86's Avatar
Quoted: 133 Post(s)
Liked: 67
There are a fair number of Warner HD-DVDs failing on many of us - so let us know if this firmware change improves matters or not.
A long-time audio/video addict!
Rich86 is offline
Reply HD DVD Players
