Fix door on an A30? - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2009, 06:51 AM - Thread Starter
jsmiddleton4's Avatar
Quoted: 589 Post(s)
Liked: 199
Due to a strange set of circumstances I have an A30 on which the door that covers the drawer seems to be missing its spring. I'm assuming its a spring loaded design. Anyone fixed this and if so how, steps, etc.?
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is online now
Old 02-27-2009, 08:08 AM
Electone's Avatar
If the A30 is similar to the A3, I didn't think it had a separate fold-down door that opens when the disc tray is ejected. I know the A1 and XA1 have separate doors.
The flap would be part of the faceplate of the player. You'll have to remove the cover and then there are usually three clips on the top and the bottom that hold the faceplate to the unit.
Electone is offline
