Can anybody tell me if the Composite, Component or SVideo Video is live on the A20? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-01-2009, 08:03 AM - Thread Starter
DavidEC's Avatar
? Can anybody tell me if the Composite, Component or SVideo Video is live on this machine (A20) when the HDMI is plugged in ?
My machine is in a cabinet and really don't want to pull it yet..
In short I use to feed my DVD/DirecTV/VCR/TIVO into a whole house system using stereo RF modulator(s).. when I first tried the RF with the A20 HD-DVD player the image flagged so bad it was not watchable.. but now with the move of many stations to DTV UHF I no longer have the bands/channels to use RF and wiring direct video to the out lying rooms and will be running A/V cables.. the main room will use HDMI, the remote rooms will use Composite, Component or SVideo Video.
DavidEC is offline
post #2 of 3 Old 03-01-2009, 08:32 AM
rdclark's Avatar
Quoted: 285 Post(s)
Liked: 544
I don't know about the A20 but all outputs are simultaneously active on my A2, A3, and A30. But on the SD outputs the video is squeezed on a 4:3 display, not letterboxed as it is on some HD devices.
Wide Awake
on the Edge
of the World
rdclark is offline
post #3 of 3 Old 03-01-2009, 10:27 AM - Thread Starter
DavidEC's Avatar
Thanks for the reply..
If they are live on a A2 and a A30 then I am sure they are live on the A20...
It just I had a Maganvox DVD Recorder which had Component out and when any cable was plugged into any of the three jack's it would turn off the SVideo/Composite outs..
If there was a low cost way to split a HDMI out-up to many other sets.. then I would be able to run HDMI cables... But due to digital rights protection the only HDMI splitter that I know of ....is known not to work with a DirecTV HD-DVR...
DavidEC is offline
Reply HD DVD Players
