Odd HD-A1 issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-13-2009, 06:00 AM - Thread Starter
Electone's Avatar
I'm having a weird issue with my HD-A1. It is hooked up via HDMI to my Pioneer VSX-01 receiver. If I turn the receiver and tv on first, the A1 boots up normally. If I turn it on first, it sticks on "Welcome" and I have to hold the power button down for 5 seconds to re-boot it. Is it just looking for the HDMI handshake, or am I looking at the early stages of a failure?
Electone is offline
post #2 of 4 Old 04-14-2009, 07:11 AM
luigionlsd's Avatar
Try pressing the V. Output button on the remote (the player's display should say HDMI in the middle-top of the screen) to make sure you're actually in HDMI.
luigionlsd is offline
post #3 of 4 Old 04-14-2009, 11:59 AM
BTBuck1's Avatar
if you're running older firmware it will do this, try updating to 4.0.
HDDVD owner: 360 add-on, HD-A30, HD-A2, A1
Blu-ray disc supporter: ubp-x800, XB1s,ps3-60gb, Oppo BDP-93, ubd-k8500
TV's: xbr55x850b/kdl55hx729/un49ks8000
Audio: Denon/Polk, Onkyo/Klipsch-Sony, Samsung SB
BTBuck1 is offline
post #4 of 4 Old 04-15-2009, 05:33 AM - Thread Starter
Electone's Avatar
I did an initialization and cleared persistant memory. Firmware is at 4.0. I think this has something to do with my receiver. Before I bought the new receiver, the A1 was hooked directly up to my TV. Now, it goes through the receiver first. I believe there is a setting on the VSX-01 that allows the receiver to send HDMI signals to the television even when the unit is off. I'm going to see if that helps.
Electone is offline
Reply HD DVD Players
