aspect ratio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-26-2009, 07:33 AM - Thread Starter
aggregate's Avatar
I have the Samsung DVD-1080p9 with match with a Sangsung LN46A540 tv...the movies I seen so far have had letterboxes on them, I got the DVD player set to 16:9 wide...any help would be appreciated
aggregate is offline
post #2 of 4 Old 04-26-2009, 08:03 AM
boblinds's Avatar
Quoted: 12 Post(s)
Liked: 40
Not all films are shot in 16:9 aspect ratio. Older films were shot in 4:3 (like standard TV). Others are 2:1 or 2.35:1 or wider. To show the WHOLE picture on a 16:9 screen, it is necessary to have black bars surrounding the image. The alternative would be to zoom in and cut off part of the picture.
boblinds is offline
post #3 of 4 Old 04-26-2009, 01:15 PM - Thread Starter
aggregate's Avatar
thanks bob...found button on remote to make picture bigger but it also distorted it...quest can have the best of both worlds
post #4 of 4 Old 04-28-2009, 11:27 AM
fubdap's Avatar
Like boblinds said - Not all films are shot in 16:9 aspect ratio. If you read the cover of the DVD you will in most cases find the aspect ratio. The problem is the information is not on the same location for all the DVDs. You have to look for it.
fubdap is offline
Reply HD DVD Players
