Want to use Xbox 360 HD DVD player on my laptop - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-29-2009, 06:59 AM - Thread Starter
Thezlog's Avatar
What do I need to run it and how fast does my laptop need to run at?
Thez
Thezlog is offline
post #2 of 5 Old 09-30-2009, 11:10 AM
luigionlsd's Avatar
I'm using Windows 7 Enterprise at home (got it from work) and the drivers all picked up fine and playback is great using WinDVD. The drive was picked up and detected automatically on 7 (and I'd assume Vista), and Windows Update grabbed the proper driver. If you're using XP, I haven't used the drive on an XP environment for a year or so, but you may need to manually install an extra driver, unless it has been added to the Windows Update repository. As for playback, I believe most of it is CPU intensive rather than GPU, so it really depends on what you'll actually see. What are the specs of your laptop?
luigionlsd is offline
post #3 of 5 Old 10-08-2009, 02:44 AM
mackagata's Avatar
Hi All..
My first question is:-
1. Does the Xbox 360 HD-DVD Player support other media? For example DVD+R DL DVD's? (I've looked everywhere but can't find an answer to this.)
2. If the answer to my first question is NO, just forget my other question, lol
3. I have a 7.9GB .mkv file and was wondering if it would be possible to convert it somehow and burn it onto a DVD+R DL DVD so it can be played in the Xbox 360 HD DVD player?
Hope someone can help, Many thanks!
mackagata is offline
post #4 of 5 Old 10-08-2009, 03:09 PM
pitweasel's Avatar
Which version of WinDVD are you using? I'm using PowerDVD at the moment (7.3), but I can only get it to play in File Mode from the hard drive; it crashes when I try to play it straight from the HD-DVD drive. Trying to find a way around that...thanks!
pitweasel is offline
post #5 of 5 Old 11-02-2009, 02:31 AM
EJ
EJ's Avatar
Originally Posted by mackagata View Post
Hi All..
Yes, it seems to support anything I have thrown at it. Won't your regular DVD player read the .mkv file? It just sees it as a file stored on a disc, I wouldn't think an HD-DVD drive would be necessary. Compared to my other 2 DVD drives, the HD-DVD drive is slower at reading data.
Former USSB uplink operator.
EJ is offline
Reply HD DVD Players
