pioneer dv-220kv-k subtitles font size. - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2009, 07:55 AM - Thread Starter
mooshmoosh's Avatar
Hi guys.
I recently bought the dv-220kv-k pioneer hd dvd player.
I feel that the size of the subtitles when playing a divx file, is too small.
What can i do?
If anyone know of a firmware solution to my problem, i would be happy if he
post it here.
If you think that it would be better to return the device and get a different
brand or model device that support HD and a bigger subtitles font at the same
price level, pleas advise me of it.
be blessed.
thanks. moysh.
mooshmoosh is offline
Old 10-09-2009, 07:05 AM
Diffio's Avatar
Hi!
Did you fine the solution? I have the same problem
Diffio is offline
Old 10-09-2009, 08:37 AM
Vader424242's Avatar
Quoted: 79 Post(s)
Liked: 65
Wrong forum. This forum is for HD DVD players, not SD players that can upconvert standard definition content. In other words, HD DVD is not the same as SD DVD played at HD resolutions. You might receive a better response in the SD DVD forum:
http://www.avsforum.com/avs-vb/forumdisplay.php?f=18
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
