Toshiba still repairing XA2's? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-05-2009, 01:59 PM - Thread Starter
gixx1000's Avatar
I have an XA2 that has had the shutdown bug since day one. I've always used the workaround with no issues. Lately it has begun shutting down while playing some cd's even when using the workaround. This has never happened before. I have the extended warranty from Best Buy and I'm wondering if Toshiba is still repairing or replacing these units. I'm not sure if I would just like to exchange in the store for something else, or if I can get a new player. Has anyone sent one of these units in for repair lately? If so, what was your experience?
gixx1000 is offline
post #2 of 8 Old 11-06-2009, 07:59 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
I sent in a supposedly brand new XA-2 unit I bought off ebay w/shutdown bug back in may/june & got back a brand spanking new unit. Tosh said on the phone they dont even try to repair end of life units and just replace the whole unit.
I was a happy camper & Tosh's turnaround time was 1 day.
qz3fwd is offline
post #3 of 8 Old 11-11-2009, 08:46 PM
Emannikcufesin's Avatar
If you don't mind me asking, how much did they charge you for the replacement XA2?
Emannikcufesin is offline
post #4 of 8 Old 11-11-2009, 09:02 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Flat rate $250 as I recall.
qz3fwd is offline
post #5 of 8 Old 11-13-2009, 11:04 AM
GizmoDVD's Avatar
So you bought an XA2 and sent it back to Toshiba and spent $250 to get a new one? How much was the XA2 that you bought from ebay?
GizmoDVD is offline
post #6 of 8 Old 11-26-2009, 10:39 AM
dizwip's Avatar
The hdmi on my XA2 just stopped working. Tried multiple cables, no luck...anyone ever fix this?
Dino
dizwip is offline
post #7 of 8 Old 11-27-2009, 06:51 PM
Blasst's Avatar
Quoted: 67 Post(s)
Liked: 65
Dino
Did you change anything else? Check to see if you selected HDMI? Does your component output work?
Blasst is offline
post #8 of 8 Old 11-28-2009, 09:55 PM
madkaw's Avatar
Liked: 31
Dino
This happened to me one time, for no reason the hdmi output just stopped working. I had to unplug it for a couple minutes then hook up the composite cable cable and re initialize the player. It has never happened again.
ISF Certified Calibrator
CalMan Pro
Electronics Junkie
madkaw is offline
Reply HD DVD Players
