HD-A3, 408bc504, Updated FW, still nothing. - AVS Forum | Home Theater Discussions And Reviews
Old 11-07-2009, 05:03 PM - Thread Starter
HTtom's Avatar
I tried watching Out of Sight (Universal), but it froze in under one minute and displayed the 408bc504 error. I tried another movie and it didn't recognize the disc. I updated the firmware to 4000U (based on a thread here with the links), but after completing step 4/4 and ejecting the iso disc, it did not power down as Toshiba says it does. I tried updating the firmware again, but it said it was already complete.
I tried Out of Sight again, and it froze a few seconds before the first time. I then put in The Italian Job (Paramount), but it says, "The disc is not DVD format. Cannot play the disc." I tried Anchorman (Dreamworks), and it played perfectly up to 4:15 and then froze. I can't eject the disc or turn the player off.
I then went to Toshiba's site and it prompted me to download 2000U after selecting the HD-A3. I downloaded that and attempted to update the firmware, but it said the update was already complete.
What do I do now?
HTtom is offline
Old 11-08-2009, 01:10 AM
Viking61's Avatar
Quoted: 16 Post(s)
Liked: 26
Pressing Display, 7, 0, 1, Display would do a factory reset on a working player. You could always try it on your player too.
Viking61 is offline
Old 11-08-2009, 11:36 AM - Thread Starter
HTtom's Avatar
I tried that, nothing happened. Where'd you get that info? Other threads said there was no way to reset the player.
HTtom is offline
Old 11-08-2009, 12:04 PM
Viking61's Avatar
Quoted: 16 Post(s)
Liked: 26
There are some "secret" codes for the Toshiba HD DVD players. I only know a few:
  • Display, 7, 0, 1, Display will do a factory reset (on the firmware you have installed)
  • Display, 1, 9, 5, Display will show the complete system information of your player
  • T.search, 1, 3, 9, "Region number", T.search is the RCE hack for regionfree European models.
Viking61 is offline
Old 11-08-2009, 12:12 PM - Thread Starter
HTtom's Avatar
I appreciate the reply, but the reset code did not do anything.
Searching this forum shows that code for the HD-XA2, I can't find any mention of it for the HD-A3.
HTtom is offline
Old 11-08-2009, 12:15 PM
Viking61's Avatar
Quoted: 16 Post(s)
Liked: 26
As your player didn't shut down after the firmware upgrade, I suspected that it wouldn't react to the factory reset code either. But I figured it was worth a try.
Viking61 is offline
Old 11-11-2009, 10:47 PM - Thread Starter
HTtom's Avatar
Any other opinions? I'd really hate to sell my discs because the player no longer works.
HTtom is offline
Old 11-12-2009, 02:40 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
That code means:
4 0 * * C 5 0 4 Contents Error
Error code : 0x00000000 Error Code
qz3fwd is offline
Old 11-12-2009, 02:49 PM - Thread Starter
HTtom's Avatar
Originally Posted by qz3fwd View Post
That code means:
I'm aware of that, I think most of us with HD-DVD players have seen that before.
Any suggestions on how to get my player working?
HTtom is offline
Old 02-26-2010, 08:50 AM - Thread Starter
HTtom's Avatar
Until last night, I haven't tried watching an HD-DVD since this happened. The same thing happens. Any ideas? I'd hate to buy a used unit, but I've got 40 movies (some of which aren't on Blu, or scheduled to be) that I'd like to be able to watch.
HTtom is offline
Old 02-26-2010, 10:43 AM
JOHNnDENVER's Avatar
Saddly, this usually means a drive replacement in my experiences with it.
JOHNnDENVER is offline
Old 02-27-2010, 07:24 AM - Thread Starter
HTtom's Avatar
What's a drive replacement? How much is it?
HTtom is offline
Old 02-27-2010, 01:41 PM
Chingu808's Avatar
Quoted: 41 Post(s)
That code means:
I just got the same error playing Ocean Eleven hd-dvd on my A2. This was the first time I played that movie on my A2. It was a brand new disc and got the error about the 42 minute mark of the movie. I open/close the tray and tried to play the movie again. It started up and then I chapter skipped past the 42 minute mark. It played for about another minute and then got the error again. When I tried to play the hd-dvd again I got the "No Disc" error. I then powered off and tired to play the hd-dvd and still got the "No Disc" error. I then powered off the A2 again I tried to play a different hd-dvd and it played. First time problems with this A2 which was purchased back in Dec 2006. Now that I got this error I am going to keep on using this player hoping something happens to it. I brought a 4 year warranty from BB when I brought the unit. It's good till Dec 2010. I still have another A2, A3 and A30 in the closet.
Chingu808 is offline
