Can I used the Toshiba A2 Internal HD-DVD drive in my pc? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-14-2009, 04:40 PM - Thread Starter
rob316's Avatar
I have not used my A2 in around a year, I do not want to throw it out or Ebay it. Can I take out the Internal HD-DVD drive and put it in my Windows 7 machine which already has a Pioneer BR drive.
rob316 is offline
post #2 of 3 Old 11-15-2009, 08:31 AM - Thread Starter
rob316's Avatar
Anyone????????
rob316 is offline
post #3 of 3 Old 11-15-2009, 08:48 AM
boblinds's Avatar
Quoted: 12 Post(s)
Liked: 40
http://uneasysilence.com/archive/2006/11/8303/
I suspect the process may be similar for the drive in the A2.
Do this Google search "Toshiba A2 hd dvd drive in pc" and (in addition to your post ) you may find the info you need. Good luck.
boblinds is offline
Reply HD DVD Players
