Toshiba HD-XE1 Very slow... Is normal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-21-2009, 03:57 AM - Thread Starter
RMSMT's Avatar
Hi
I have a Toshiba HD-XE1, it was brand new in box, and now i've plug it in my new home theater.
The player is very slow to start a movie...
There are a few firmware upgrades... Will they make any diference in picture or making the player faster?
Tank you
RMSMT is offline
post #2 of 5 Old 12-21-2009, 11:04 AM
luigionlsd's Avatar
Originally Posted by RMSMT View Post
Hi
Tank you
If this is your first HD DVD player ever (or high definition period - HD or BD), then yes, it will be a bit slower than a DVD player. If you have used a HD DVD or BD player (PS3 excluded), would you say it's a lot slower than the rest? I believe the XE1 is equal to the A2, which I wouldn't say is THAT slow. Your best bet might be to install the latest FW update.
luigionlsd is offline
post #3 of 5 Old 12-22-2009, 04:14 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 336 Post(s)
Liked: 6994
The first generation Toshiba players were dreadfully slow. "A bit slower" than a DVD player is extremely understated.
larry
Ich bin hier und du bist mein Sofa
PooperScooper is offline
post #4 of 5 Old 12-26-2009, 02:33 AM - Thread Starter
RMSMT's Avatar
Hi
Yes being a bit slow is no problem, is the second generation of HD-DVD, but this is the best HD-DVD player available, so i don't want to try the others.
It looks to me the A2 is not comparable.... quite different machines and prices.
RMSMT is offline
post #5 of 5 Old 12-28-2009, 05:17 AM
Moderator
Moderator
Quoted: 336 Post(s)
Liked: 6994
I don't believe the FW updates do much, if anything, for speed. Also, hopefully you have a HDMI display because with DVI video levels will never be correct.
larry
Reply HD DVD Players
