HD-DVD A20 wont read HD-DVDs - AVS Forum | Home Theater Discussions And Reviews
Old 01-17-2010, 09:01 PM - Thread Starter
gold_digger's Avatar
I upgraded HD-DVD A20 to firmware 4.0 couple of weeks ago. Everything was fine till today when in the middle of KingKong I got disk read error message. I took the disk out for inspection and found it to be free of smudges and scrathes. I cleaned it anyway and put it back in the player. It went on and on with loading with none of the other function keys working. I finally gave up and power down the unit by taking the power cord out of the outlet hoping to reset the player. When I plugged the unit back all the functions were back. Now I can play only SD DVDs on the player. Any attempt to play a HDDVD locks the unit in loading and the only way to regain the control is by killing the power. Any one has experience with this issue. What can I do to watch HD-DVDs. I have a large collection and dont want to let go of this unit.
gold_digger is offline
Old 01-19-2010, 11:00 AM
JOHNnDENVER's Avatar
decently common failure. In the end I think the drive itself is probably going to have to be replaced.
JOHNnDENVER is offline
Old 01-21-2010, 05:30 PM - Thread Starter
Can you please elaborate a little.
Old 01-28-2010, 10:50 PM
Tspeer's Avatar
I think he means the hd-dvd rom drive. Think cd-rom drive for a pc. many of the toshiba's used the same drive, and can be swapped out.
Thats if you can find a working one cheap. Might be better to get a player off ebay. I can't imagine them costing much.
I Bet You Wish You Could! - Roger Wilco
Directions for updating your Onkyo xx5 receivers firmware. **Newly updated 7-22-2009**Re-uploaded 2-23-2015**
Something from damninteresting.com
Tspeer is offline
Old 01-30-2010, 07:51 PM - Thread Starter
Where can I find direction to swap the drives? I also own a brand new A3 that I can take the donor drive.
Old 01-31-2010, 08:49 AM
junglalien's Avatar
I think A3 has a different drive. You need a drive from an A2, A20 or XA2. Open it up its self explanatory. Look for broken A2s or A20s on ebay that say they are "stuck on welcome".
junglalien is offline
