Harmony Remote with HD-XA1 and HD-XA2 stacked on top of each other? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-17-2010, 06:12 AM - Thread Starter
conqst99's Avatar
Location: Schnecksville, PA (near Allentown in Lehigh Valley)
Hi All,
Just recently relocated my backup HD-XA1 in the same rack with my HD-XA2. Never had both units in same area before and didn't realize that the remote (either original one) works for both players. I just bought a Harmony 880 PRO remote to control my whole system. After testing it, I realize that when I set a program to just start up the XA2 for example and then push play, etc. (or when powering off), both units do the same thing. Is there a way that one of the players can be set to be on a DIFFERENT CHANNEL or not? Thanx in advance for any suggestions.
conqst99 is offline
post #2 of 3 Old 03-06-2010, 09:34 PM
youngryu's Avatar
simple answer no.
with an ir remote setup, ir signal will be received by both units. the work around is to use a rf setup with individual ir blaster. ex harmony 890
youngryu is offline
post #3 of 3 Old 04-04-2010, 09:12 AM
Shmack's Avatar
I ran into the same problem with my A2 and A30, which are both set up in the same area. I ended up unplugging the one that I didn't want to use.
Shmack is offline
Reply HD DVD Players
