Toshiba EP35:VER UP go wrong,how can i do?(for help) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-01-2010, 08:53 PM - Thread Starter
city of wine's Avatar
MACHINE MODEL: TOSHIBA EP35(FIRST VER 0.9/1.0)
1. I had EP35 Upgrade firmware4.0(correct)
2 I used EP35 DIRTY 1 and EP35 DIRTY2 (to make EP35 READ DVD FREE REGON)
IN THIS STEP ,DIRTY 1 WAS right~but ON USE DIRTY2
machine go WRONG
PLASma SCREEN WAS nothing
PUT in hd dvd,it appears not play"
dvd and cd CAN PLAY,BUT STILL NO Image
HOW CAN I DO??
CAN i download ver 1.3 to roll back?
city of wine is offline
post #2 of 5 Old 03-01-2010, 10:57 PM
Viking61's Avatar
Quoted: 17 Post(s)
Liked: 27
Did you follow the procedure carefully? It is supposed to behave like that. Sounds like you skipped the second half of the routine.
Do this: (it will not be shown anything on your TV until you are finished)
1) Insert the CD with firmware called EP35-dirty2
2) After awhile it will show VER UP in the display, then you press OK once
3) It will still show VER UP in the display for awhile, then it will count from STEP 1/4 until STEP 4/4
4) STEP 4/4 can take up to 20 minutes. Just wait and let it run its course.
5) The disc will eject and the player will turn itself off
6) Remove the disc and turn the player on with the remote
7) It will show WELCOME for awhile and then a small update will run, only STEP 1/1 and the player will turn itself off again.
8) Turn the player on with the remote and you have a regionfree EP35
P.S.
It's too late now, but there is a much simpler way to make the HD-EP35 regionfree. For the EP35 there is a separate regionfree firmware (not the dirty discs).
Viking61 is offline
post #3 of 5 Old 03-02-2010, 02:25 AM - Thread Starter
THINKS ~ Viking61
the problem is I HAD Perform the wrong steps
UPDATE VER 4.0 before INSERT THE DIRTY DISC
NOW
the dirty 2 insert ep35 ALWAYS display"ver up" AND the screen SEE nothing
post #4 of 5 Old 03-02-2010, 03:34 AM
Viking61's Avatar
Quoted: 17 Post(s)
Liked: 27
Did you do as I said in step 2? You should press OK once when it shows VER UP with the dirty2 disc inserted. After you have pressed OK, it will still show VER UP awhile and then start counting STEP 1/4 to STEP 4/4.
Viking61 is offline
post #5 of 5 Old 03-02-2010, 04:27 AM - Thread Starter
WELL DONE~I HAD ALLREADY DONE~THINKS
Viking61
Reply HD DVD Players
