New guy on the block with a problem... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-03-2010, 11:51 PM - Thread Starter
SERIOUS7's Avatar
everytime i put in a HD DVD the unit starts to play then shuts off....?
i'm trying to find out what is the problem ...
SD DVD's work ok ...
any idea's...?
SERIOUS7 is offline
post #2 of 11 Old 05-04-2010, 02:09 PM
JOHNnDENVER's Avatar
When SD works and HD doesn't, it almost always indicated an issue with the HD laser. I suppose it could even be a PS of some sort. Maybe the HD laser takes more power to run it?
JOHNnDENVER is offline
post #3 of 11 Old 05-04-2010, 10:33 PM - Thread Starter
SERIOUS7's Avatar
yeah , when i put in a HD DVD the unit will play for about 15-20 minutes then shut off , lights go out and i have to power up the unit again....
SERIOUS7 is offline
post #4 of 11 Old 05-05-2010, 09:21 AM
sonydude1966's Avatar
Quoted: 14 Post(s)
any idea's...?
If you have an XA2, then it sounds like the "shutdown bug". Either change your resolution to 1080i, or you can simply power on your player BEFORE you turn on your TV. Those are two work arounds for the shutdown bug.
sonydude1966 is offline
post #5 of 11 Old 05-05-2010, 11:39 PM - Thread Starter
SERIOUS7's Avatar
i think i found the problem , it was dust ... tonight i open up the unit and blew it out with "Endust for Electronics , The DUSTER " air in a can ...then i check out my powercord to make sure it was tight and so far so good ...
i would like to thank you guys for your help...
to be on the safe side i ordered the OPPO BDP83SE as a back up ...
thanks again ....
S7
SERIOUS7 is offline
post #6 of 11 Old 05-06-2010, 06:57 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 136
The Oppo is going to be an awesome HD-DVD player
qz3fwd is offline
post #7 of 11 Old 06-03-2010, 07:13 AM
dparisoe's Avatar
Does anyone know of a fix for the bad Laser? Is POTS tweak that may help or can you order a new laser? I have the A3 and it will no longer play HD-DVD's only DVD's. It will start to play and then after a few minutes it will freeze up.
dparisoe is offline
post #8 of 11 Old 06-03-2010, 10:05 AM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
Have you tried clearing the Persistent Storage?
Viking61 is offline
post #9 of 11 Old 06-07-2010, 01:58 PM
chili555's Avatar
Quoted: 24 Post(s)
Liked: 64
Originally Posted by qz3fwd View Post
the oppo is going to be an awesome hd-dvd player
rofl
chili555 is offline
post #10 of 11 Old 07-06-2010, 02:08 PM
blackssr's Avatar
Quoted: 1176 Post(s)
Liked: 588
thanks again ....
S7
I've paid for my sins. We're even!
blackssr is offline
post #11 of 11 Old 07-06-2010, 04:32 PM
ti-triodes's Avatar
Quoted: 344 Post(s)
Liked: 480
Originally Posted by blackssr View Post
What, you never tried tried the Endust fix? It works on balky hi-def players, automobiles and troublesome women!!!!
ti-triodes is offline
Reply HD DVD Players
