A2, Batman Begins, and True HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-23-2011, 12:00 PM - Thread Starter
18628239's Avatar
I have a Toshiba A2 connected via HDMI to a Denon 3312 (which in turns feeds a JVC projector). I'm trying to get Dolby True HD output.
In the A2 Setup, I have HDMI Audio set to Auto (PCM and Downmixed PCM are the only other choices). While I am not using the SPD/IF, it is also set to Auto (Bitstream and PCM are its other choices).
In the movie, I have selected Dolby True HD selected, but this is not being received by the Denon 3312 as the AVR is reporting BD Multichannel In, which means no True HD.
Since I pulled the A2 out of storage after a couple of years I thought maybe someone could tell me what I am doing wrong, or just not doing right in the A2 setup.
"What we do in life echoes in eternity." General Maximus Decimus Meridius
18628239 is offline
post #2 of 7 Old 06-23-2011, 02:20 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The A2 can't bitstream TrueHD or DTS-MA. Only the A-35 and X-A2 can do that.
Multichannel PCM is the best you can get which is still excellent audio quality!
I have an A2, A-35 and Batman Begins so I can verify this!
You're never going to see TrueHD or DTS-MA from the A2. Doesn't have the hardware to do it.
You also only get 1080i from the A2, not 1080p.
Afro GT
afrogt is offline
post #3 of 7 Old 06-24-2011, 03:53 AM - Thread Starter
18628239's Avatar
Is True HD prohibited across SPD/IF? I noticed its option includes Bitstream, but I'm guessing that is for regular DD. Thanks for letting me know about the limitations of the A2. Time to go try the BD versions.
18628239 is offline
post #4 of 7 Old 06-24-2011, 09:55 AM
HogPilot's Avatar
Liked: 25
IIRC, you have two options when using optical or coax for sound - you can downgrade to the "core" lossy DD or DTS and get 5.1, or you can stay lossless with decoded PCM and get 2.0.
There are 10 types of people: those who understand binary, and those who don't.
HogPilot is offline
post #5 of 7 Old 06-24-2011, 10:06 AM
JOHNnDENVER's Avatar
That Multi-channel is the lossless audio, just being decoded by the A2 and is as optimal as it gets period even though it is not being decoded by the AVR.
JOHNnDENVER is offline
post #6 of 7 Old 06-26-2011, 06:30 PM - Thread Starter
18628239's Avatar
John, I had not realized the interpretation of 'Multichannel In' on the Denon meant the processing (decoding) was being done at the source. Good info!
18628239 is offline
post #7 of 7 Old 06-30-2011, 10:34 PM
lchiu7's Avatar
Quoted: 12 Post(s)
Similarlyly I have an A3 and am slowly migrating my content to my server and playing with a Popcorn Hour.
Interestingly when playing a HD-DVD on the A3 my HK receiver shows multichannel PCM and of course I am only seeing 1080i on my projector. But the Popcorn cannot decode HD audio and sends the audio as bitstream so the HK displays Dolby TrueHD and of course I get a 1080P image on my projector.
lchiu7 is offline
Reply HD DVD Players
