Transfering HD DVDs to Blu Ray. Illegal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 37 Old 07-05-2011, 10:17 AM - Thread Starter
plissken99's Avatar
Quoted: 193 Post(s)
Liked: 56
I am interested in transfering many of my HD DVDs to Blu Ray(or having them transferred), the ones without lossless audio, ie the majority. Seems to me it's all media that I purchased, so I should have the right to transfer it to a different disk. I am running Windows 7 64bit, and have a dual core 2.8 processor. I have a Blu Ray burner, I'd just need the 360 HD DVD drive I suppose. My video card and monitor are supposed to be HDMI compatable, but I can't seem to play Blu Ray on the system.
Do I have the capability hardware and OS wise to get the job done? And is there anyone who could help, and or do this for me? Sorry if this post is out of line, but again, I bought the media in the 1st place, as long as I'm not reselling it I can't see a problem.
The more things change, the more they stay the same.
Snake Plissken
plissken99 is offline
post #2 of 37 Old 07-05-2011, 12:50 PM
drcos's Avatar
Quoted: 17 Post(s)
Your hardware and OS should be fine. You may need to resolve the issue of not being able to play BDs. What kind of problem do you have when you try to play a commercial BD?
For what you want to do, you need some free software (like MultiAVCHD or ClownBD) and some non-free software (like AnyDVD or DVDFab).
Once you have your HDDVD drive (I use a 360 drive also), you use AnyDVD or DVDFab to decrypt the discs. Easiest to use is AnyDVD, it saves a couple steps later on.
Then MultiAVCHD or ClownBD to convert to BD format and burn. Search and you will find.
I did the same thing with a 360 drive (was $25) and a bunch of HD-DVDs (between $2 and $20 on Amazon). And I have Windows 7 64-bit. But in my case I convert to MKV to watch with a WDTV Live, or BD folders to watch with a Dune. Ah, failed technology gives me several movies in HD that are not on BD (yet)...
What you want to do (and others have done) is not illegal, but parts of the process are technically violations of the (unconstitutional) DMCA.
I'll stop ripping my BDs when I can put them in and watch the movie without trailers, warnings, cutesy menus...
drcos is online now
post #3 of 37 Old 07-06-2011, 08:43 AM
Canuck-eh!'s Avatar
I have been doing the same with many of my colleciton of 80+ HD-DVDs. Unfortunately, you will find that a number of the movies (Superman series, Mission Impossible series) will not fit a 25Gb BD-R. Otherwise, I use either my 360 drive or LG drive with AnyDVD and Clown-BD. However, I do not create the BD from Clown-BD. I check the resulting files with Image Burn before I burn to make sure that they will fit. The files that are too big, I save the resulting stream files to play on my HTPC. I have also been purchasing BD cases @ Bestbuy (States) because they can hold 2 discs - the original HD DVD and new BD-R I create. This way, when I am not around, my family can choose whether they want to watch the full package with extras on HD DVD or just movie on BD. Also, as I have an A-2 that does not do TrueHD directly, they can get the full audio on the Samsung BD player, if they wish. If you want more info, pm me directly
Good Luck.
Canuck-eh! is offline
post #4 of 37 Old 07-08-2011, 07:29 AM
drcos's Avatar
Quoted: 17 Post(s)
Oh, and look at this thread. Most of it applies, as the tools listed will do HD-DVD as well.
drcos is online now
post #5 of 37 Old 07-10-2011, 06:17 PM
jd213's Avatar
I think DVDFab Passkey Lite works with HD DVDs. If not there's always DumpHD.
jd213 is offline
post #6 of 37 Old 08-05-2011, 03:19 PM
iontyre's Avatar
I've been trying to do this without a lot of luck. I rip the hd DVD with dumpHD, then I try converting to blu-ray format using either multiavchd or tsMuxer and burn with ImgBurn but I can't seem to get the audio right especially with lossless formats. Half the time I end up with video and no audio at all on my BDRE. Can someone give me a complete example with settings on how best to do this?
Proud Galactic Imperialist
iontyre is offline
post #7 of 37 Old 08-05-2011, 04:26 PM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2524
I would suggest using ClownBD. It will do it all in one step (except recompression if needed).
It's important to keep in mind that DD+ is not supported on Blu-Ray so you either have to convert it to RAW PCM which takes up a lot of space and can't be properly played on a system with SPDIF or live with converting the DD+ to DD or using the DD track from the HD-DVD (if it had one).
Stereodude is offline
post #8 of 37 Old 08-05-2011, 06:24 PM
jd213's Avatar
TrueHD on HD DVD isn't compatible with BD, either. It needs to be converted from a .thd file to a .thd+ac3 file. eac3to can do this, and multiAVCHD might be able to do it as well since it's basically a GUI for a bunch of different programs including eac3to.
jd213 is offline
post #9 of 37 Old 08-05-2011, 06:40 PM
iontyre's Avatar
This is exactly the kind of thing I can't figure out. There is a checkbox in multiavchd to enable eac3to, but I don't know what I am supposed to do with the other setting there. Can't I convert the TruHD to LPCM? I have tried but it always seems to fail.
iontyre is offline
post #10 of 37 Old 08-05-2011, 06:43 PM
jd213's Avatar
You might just have to demux with eac3to first. There are various GUIs available but the command line interface provides more functionality.
jd213 is offline
post #11 of 37 Old 08-05-2011, 07:36 PM
iontyre's Avatar
Any hints on what the command would look like?
iontyre is offline
post #12 of 37 Old 08-05-2011, 07:46 PM
jd213's Avatar
eac3to lists the available commands when you type eac3to
jd213 is offline
post #13 of 37 Old 08-06-2011, 06:39 AM
Stereodude's Avatar
Liked: 2524
Are you sure about that? I only have 3 HD-DVD's with TrueHD, but when I use eac3to on them directly they show no embedded AC3 track. However, after I mux the track into a blu-ray and point eac3to at it, it reports an embedded AC3 track. I know none of the tools created and embedded an AC3 track into the TrueHD stream, so that means it had to be there all along.
Source HD-DVD:
Code:
EVO, 1 video track, 3 audio tracks, 2 subtitle tracks, 1:30:26
1: Joined EVO file
2: Chapters, 20 chapters with names
3: VC-1, 1080p24 /1.001 (16:9) with pulldown flags
4: TrueHD, English, 5.1 channels, 48kHz, dialnorm: -27dB
5: E-AC3, English, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB, -17ms
6: E-AC3, French, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB, -17ms
7: Subtitle (DVD), English, "SDH"
8: Subtitle (DVD), French
Converted Blu-Ray:
Code:
M2TS, 1 video track, 1 audio track, 1 subtitle track, 1:30:26, 24p /1.001
1: Chapters, 20 chapters
2: VC-1, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, English, 5.1 channels, 48kHz
   (embedded: AC3, 5.1 channels, 640kbps, 48kHz)
4: Subtitle (PGS), English
I'm extracting the AC3 and am going to play it and see if it's really a legit AC3 audio stream stream or if it's some artifact of the tools (either assuming it's there when it's not, or somehow a dummy stream).
post #14 of 37 Old 08-06-2011, 10:33 AM
Stereodude's Avatar
Liked: 2524
Okay, so of the 3 HD-DVD's I have with TrueHD audio (Training Day, Balls of Fury, & Inside Man) all 3 have a valid / real 640kbit/sec embedded AC3 stream in them which means they should be Blu-Ray compliant audio streams.
post #15 of 37 Old 08-06-2011, 10:50 AM
jd213's Avatar
Hmm. I only ever used eac3to to demux, and the one time I tried muxing in a .thd track with TSMuxer before converting it to thd+ac3, it wouldn't accept it.
jd213 is offline
post #16 of 37 Old 08-06-2011, 11:13 AM
iontyre's Avatar
I'm attempting a conversion of Blade Runner (final cut) from hddvd to blu using multiavchd right now. Set it to convert truehd to lpcm. I'll update when it is done.
iontyre is offline
post #17 of 37 Old 08-06-2011, 11:36 AM
iontyre's Avatar
Well, failure. I got great video, but no audio at all. I just included the Feature_1.evo and feature_2.evo files, removed all the audio files except the TrueHD, and set eac3to to convert TrueHD to LPCM. Here is my Log:
[13:59:33] Checking for available space and drive types (FAT32/NTFS)...
[13:59:35] Destination [G:]: NTFS, 1568177.59 MiB (1531.423 GiB) free space
[13:59:35] Temp folder [D:]: NTFS, 781175.22 MiB (762.866 GiB) free space
[13:59:35] Log started for multiAVCHD v4.1 (build 770)
[13:59:35] Selected output mode: Blu-ray player (BD-R/BD-RE disc)
[13:59:35] Processing 2 titles...
[13:59:36] Processing (G:\\HDDVD\\BladeRunnerFC\\HVDVD_TS\\FEATURE_1.EVO)...
[13:59:36] Demuxing video from EVO/TRP/MP4 container...
[14:07:31] Demuxing of TRP/MP4 video stream failed!
[14:07:31] Detected video: ID#85:V_MS/VFW/WVC1 1920x1080, fps=29.970
[14:07:31] Converting TrueHD audio to LPCM (eac3to)...
[14:07:40] eac3to refused to convert audio!
[14:07:40] Trying to demux it...
[14:08:58] Trying to convert TrueHD again with eac3to to LPCM...
[14:08:58] Total of 2 tracks found in this file.
[14:08:58] Creating clip and playlist info (tsMuxeR)...
[14:08:58] Media split set at 25000MiB point...
tsMuxeR (Version 1.10.6) output:
VC-1 stream does not contain fps field. Muxing fps=29.97
Decoding VC-1 stream (track 1): Profile: Advanced@3 Resolution: 1920:1080i Frame rate: 29.97
Processed 97448 video frames
Creation of Blu-ray playlist
Creation of Blu-ray stream info and seek index
Mux successful complete.
Muxing time: 1 min 57 sec
tsMuxeR meta:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000 --vbv-len=500
V_MS/VFW/WVC1, "G:\\HDDVD\\BladeRunnerFC\\HVDVD_TS\\FEATURE_1.EVO", insertSEI, contSPS, track=85, fps=29.970
[14:10:48] Media transfer: 00000 -> 00000.m2ts
[14:12:32] Processing playlist...
[14:12:33] Title #1 added: "Part 1"
[14:12:33] Verifying title...
[14:12:39] Title has: 0 audio tracks and 0 subtitle tracks
[14:12:41] Processing (G:\\HDDVD\\BladeRunnerFC\\HVDVD_TS\\FEATURE_2.EVO)...
[14:12:41] Demuxing video from EVO/TRP/MP4 container...
[14:14:16] Demuxing of TRP/MP4 video stream failed!
[14:14:17] Detected video: ID#85:V_MS/VFW/WVC1 1920x1080, fps=29.970
[14:14:17] Converting TrueHD audio to LPCM (eac3to)...
[14:14:23] eac3to refused to convert audio!
[14:14:23] Trying to demux it...
[14:15:25] Trying to convert TrueHD again with eac3to to LPCM...
[14:15:25] Total of 2 tracks found in this file.
[14:15:25] Creating clip and playlist info (tsMuxeR)...
[14:15:25] Media split set at 25000MiB point...
Processed 71748 video frames
Muxing time: 1 min 25 sec
tsMuxeR meta:
V_MS/VFW/WVC1, "G:\\HDDVD\\BladeRunnerFC\\HVDVD_TS\\FEATURE_2.EVO", insertSEI, contSPS, track=85, fps=29.970
[14:16:45] Media transfer: 00000 -> 00001.m2ts
[14:17:52] Processing playlist...
[14:17:53] Title #2 added: "Part 2"
[14:17:53] Verifying title...
[14:17:57] Title has: 0 audio tracks and 0 subtitle tracks
[14:17:57] Preparing authoring information...
[14:17:57] Creating NTSC top menu.
[14:17:57] Setting pop-up menu...
[14:17:59] *** [00000.mpls] - Adding pop-up menu [1080p]...
[14:17:59] *** [00001.mpls] - Adding pop-up menu [1080p]...
[14:18:00] *** Completed!
[14:18:00] Authoring menu (NTSC).
[14:18:00] Creating title thumbnails for 2 titles (XMB)...
[14:19:08] Failed to extract title thumbnail for title #1.
[14:19:09] Using 1 thumbnail/chapter links for title #1...
[14:19:09] *** Extracting 1 chapter thumbnails...
[14:21:12] Using 1 thumbnail/chapter links for title #2...
[14:21:12] *** Extracting 1 chapter thumbnails...
[14:22:13] Image processing for XMB menu completed!
[14:22:13] Preparing menu pages...
[14:22:14] Encoding static XMB menu page [1/2] [Static title thumbnail].
[14:22:35] Encoding static XMB menu page [1/2]: Chapter page [1/1].
[14:22:40] Encoding static XMB menu page [1/2]: Setup page (audio/subtitle).
[14:22:42] Encoding static XMB menu page [2/2] [Static title thumbnail].
[14:22:55] Encoding static XMB menu page [2/2]: Chapter page [1/1].
[14:22:59] Encoding static XMB menu page [2/2]: Setup page (audio/subtitle).
[14:23:01] Menu authoring completed.
[14:23:04] Encoding Title List menu page [1/1].
[14:23:13] Authoring welcome screen (NTSC).
[14:23:13] Encoding welcome screen...
[14:23:17] Authoring welcome screen completed.
[14:23:18] Setting main menu for 2 titles...
[14:23:18] Go to menu after last title.
[14:23:18] Setting menu properties...
[14:23:18] Selected TV system: [NTSC]
[14:23:18] Processing clip (CPI/CLPI) files...
[14:23:20] Completed.
[14:23:20] Setting Blu-ray format...
[14:23:21] Done!
[14:23:21] Saving multiAVCHD quick-load project (mpf):
[14:23:21] G:\\BluRay\\AVCHD_BladeRunner\\multiAVCHD.mpf (OK!)
Compilation summary:
Format: Blu-ray player (BD-R/BD-RE disc)
1. Part 1 [01:07:44]
2. Part 2 [00:49:52]
Overall duration : 01:57:36
Output size : 14865 MiB (14.516 GiB)
[14:23:21] G:\\BluRay\\AVCHD_BladeRunner folder created (AVCHD/Blu-ray output)!
[14:23:21] Burn its CONTENTS to BD-R/RE UDF 2.50/2.60 disc!
[14:23:23] You may now remove temp folder (D:\\Program Files\\MultiAVCHD\\_TEMP\\multiTEMP-20110806\\).
[14:23:23] Your compilation contains 1hrs 57min 36sec of video material.
[14:23:23] multiAVCHD finished in 1428.189 seconds (00:23:48.188)!
[14:23:23] End of log.
iontyre is offline
post #18 of 37 Old 08-06-2011, 12:21 PM
Stereodude's Avatar
Liked: 2524
I've only done movie only discs, with no menus using ClownBD so I'm afraid I can't help you with this method.
post #19 of 37 Old 08-06-2011, 12:27 PM
iontyre's Avatar
I don't think the menu has anything to do with it... it won't convert the TrueHD audio to LPCM. Same thing happens is I don't use any menus. eac3to is where the problem is. Does ClownBD use eac3to? If so, than I have a problem that you have solved...
Furthermore, multiavchd seems to think EVERY audio track on HD DVD's is TrueHD, even when I know they are DD+.
iontyre is offline
post #20 of 37 Old 08-06-2011, 01:03 PM
iontyre's Avatar
Ok, so I tried ClownBD. Aborted almost immediately. Here is the log:
eac3to v3.24
command line: "D:\\Clown_BD_v0.79\\eac3to\\eac3to.exe" "G:\\HDDVD\\BladeRunnerFC" 1) 2: "D:\\Clown_BD_v0.79\\Temp\\Chapters_2.txt" 3: "D:\\Clown_BD_v0.79\\Temp\\Video_3.*" 4: "D:\\Clown_BD_v0.79\\Temp\\Audio_4_English.WAV" 5: "D:\\Clown_BD_v0.79\\Temp\\Audio_5_English.THD+AC3" 10: "D:\\Clown_BD_v0.79\\Temp\\Subtitles_10_English.sup" -progressnumbers -LOG="D:\\Clown_BD_v0.79\\Temp\\LOGS\\eac3to_PASS3_LOG.LOG"
EVO, 1 video track, 6 audio tracks, 10 subtitle tracks, 1:57:36
1: Joined EVO file
2: Chapters, 37 chapters with names
4: E-AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, -5ms
5: TrueHD, English, 5.1 channels, 48kHz, dialnorm: -27dB
6: E-AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, -5ms
7: E-AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -21ms
"Commentary #1"
8: E-AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -21ms
"Commentary #2"
9: E-AC3, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -21ms
"Commentary #3"
10: Subtitle (DVD), English, "SDH"
11: Subtitle (DVD), French
12: Subtitle (DVD), Spanish
13: Subtitle (DVD), Japanese
14: Subtitle (DVD), Chinese, "Chinese"
15: Subtitle (DVD), Korean
16: Subtitle (DVD), Portuguese
17: Subtitle (DVD), Japanese, "Commentary #1"
18: Subtitle (DVD), Japanese, "Commentary #3"
19: Subtitle (DVD), Japanese, "Commentary #2"
Creating file "D:\\Clown_BD_v0.79\\Temp\\Chapters_2.txt"...
[a04] The Nero decoder doesn't seem to work, will use libav instead.
[v03] Extracting video track number 3...
[v03] Writing new framerate "24fps /1.001" to bitstream.
[v03] Removing VC-1 pulldown...
[a05] Extracting audio track number 5...
[a04] Extracting audio track number 4...
[a05] Removing TrueHD dialog normalization...
[a04] Removing E-AC3 dialog normalization...
[a04] Decoding with libav/ffmpeg...
[a05] Decoding with libav/ffmpeg...
[a04] Remapping channels...
[a05] Encoding AC3 <640kbps> with libAften...
[a04] Applying RAW/PCM delay...
[a04] Reducing depth from 64 to 24 bits...
[a04] Writing WAV...
[a04] Creating file "D:\\Clown_BD_v0.79\\Temp\\Audio_4_English.WAV"...
[a05] Creating file "D:\\Clown_BD_v0.79\\Temp\\Audio_5_English.THD+AC3"...
[a05] This track is not clean (2).
[a05] [libav] Invalid channel 6 specified as output from matrix
[a05] The libav decoder reported error -1 while decoding.
Aborted at file position 5242880.
iontyre is offline
post #21 of 37 Old 08-06-2011, 01:25 PM
Stereodude's Avatar
Liked: 2524
Oh... You're trying to keep the all the audio and video tracks? E-AC3 / DD+ isn't compatible with Blu-Ray so it's converting it to LPCM then AC3 encoding it. It looks like you might have the option for the TrueHD track set wrong. I set it to unconverted.
Here's how I've done it...
Step 1:
Step 2:
Step 3:
post #22 of 37 Old 08-06-2011, 01:32 PM
mb1756's Avatar
If you want an honest answer, yes it is illegal to copy DVDs. Read the warning banner on the front of each and every copyrighted movie. It doesn't matter whether you sell it or is only for personal use. It is illegal.
mb1756 is offline
post #23 of 37 Old 08-06-2011, 01:37 PM
iontyre's Avatar
Thanks Stereodude,
No, I'm not keeping them all, only selected the main movie and the TrueHD track. Just like you have it.
iontyre is offline
post #24 of 37 Old 08-06-2011, 02:01 PM
iontyre's Avatar
Tried several direct from disc. Selecting only the movie and audio. They don't even give me the option to select anything but the TrueHD audio. Set to uncoverted or Core doesn't matter, they all abort almost immediately with a log like this:
eac3to v3.24
command line: "D:\\Clown_BD_v0.79\\eac3to\\eac3to.exe" "J:" 1) 2: "D:\\Clown_BD_v0.79\\Temp\\Chapters_2.txt" 3: "D:\\Clown_BD_v0.79\\Temp\\Video_3.*" 5: "D:\\Clown_BD_v0.79\\Temp\\Audio_5_English.AC3" -CORE -progressnumbers -LOG="D:\\Clown_BD_v0.79\\Temp\\LOGS\\eac3to_PASS3_LOG.LOG"
EVO, 2 video tracks, 1 audio track, 4 subtitle tracks, 1:55:56
1: Joined EVO file
2: Chapters, 30 chapters
4: VC-1, 480p30 /1.001 (3:2)
6: Subtitle (DVD), English
9: Subtitle (DVD), Spanish
[v03] This EVO/VOB file contains authoring faults. Will try to work around that. (1807)
[a05] [libav] Substream 0 parity check failed
[a05] [libav] Substream 0 checksum failed
[a05] [libav] Substream 0 length mismatch.
Aborted at file position 1048576.
iontyre is offline
post #25 of 37 Old 08-06-2011, 02:02 PM
Stereodude's Avatar
Liked: 2524
It looks like eac3to when used through ClownBD inserts the AC3 stream into the THD. At least that's what the bold line below seems to show. I guess I missed that detail before when I was doing this.
eac3to v3.24
command line: "C:\\HDTV Tools\\Clown_BD_v0.79\\eac3to\\eac3to.exe" "F:" 1) 2: "D:\\TempBD\\TD\\Chapters_2.txt" 3: "D:\\TempBD\\TD\\Video_3.*" 5: "D:\\TempBD\\TD\\Audio_5_English.THD+AC3" 9: "D:\\TempBD\\TD\\Subtitles_9_English.sup" -progressnumbers -LOG="D:\\TempBD\\TD\\LOGS\\eac3to_PASS3_LOG.LOG"
EVO, 1 video track, 5 audio tracks, 4 subtitle tracks, 2:02:02
1: Joined EVO file
2: Chapters, 28 chapters with names
4: E-AC3, English, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, -13ms
6: E-AC3, French, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB, -13ms
7: E-AC3 Surround, Spanish, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -29ms
8: E-AC3 Surround, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -27dB, -29ms
"Commentary 1"
9: Subtitle (DVD), English
Creating file "D:\\TempBD\\TD\\Chapters_2.txt"...
[v03] Creating file "D:\\TempBD\\TD\\Video_3.vc1"...
[a05] Creating file "D:\\TempBD\\TD\\Audio_5_English.THD+AC3"...
[s09] Extracting subtitle track number 9...
[s09] Creating file "D:\\TempBD\\TD\\Subtitles_9_English.sup"...
[a05] Audio has a gap of 46ms at playtime 0:00:00.
[a05] The audio gaps/overlaps can't be removed from the TrueHD bitstream.
[a05] In order to remove them you'll have to transcode to another format.
[a05] The original audio track has a constant bit depth of 16 bits.
Video track 3 contains 175570 frames.
Subtitle track 9 contains 1368 captions.
eac3to processing took 28 minutes, 51 seconds.
Done.
post #26 of 37 Old 08-06-2011, 02:04 PM
Stereodude's Avatar
Liked: 2524
You are decrypting the discs with something like AnyDVD HD or DVDFab HD Decrypter right first?
post #27 of 37 Old 08-06-2011, 02:19 PM
iontyre's Avatar
Tried a few straight from disc... yeah, that was dumb!!! I do have some decrypted, and if I use anything other than TrueHD for the audio it works fine (Blade Runner with DD+, and Aeon Flux with DTS both work). Just can't get the TrueHD to work. Is there some other tool, a decoder or something I need? What is that line about decoding with libav/ffmpeg all about?
iontyre is offline
post #28 of 37 Old 08-06-2011, 04:53 PM
Stereodude's Avatar
Liked: 2524
Did you download the whole "Clown_BD, eac3to, tsMuxer Package" from http://www.clownbd.com/? What OS are you running?
post #29 of 37 Old 08-06-2011, 06:00 PM
iontyre's Avatar
Yes, I got the whole package. Running Windows 7 Professional.
iontyre is offline
post #30 of 37 Old 08-07-2011, 05:35 AM
iontyre's Avatar
The sad thing is there are many reports that hddvd's from Warner are developing playback problems, so backing them up to blu-ray is the only way to protect our investments.
iontyre is offline
Reply HD DVD Players
