Toshiba hd-a1 firmware help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-16-2011, 10:11 AM - Thread Starter
Seadaddy's Avatar
I am having a problem burning the iso image to a disk i downloaded the firmware directly from the toshiba website. The problem i think i have is properly extracting the image to a cdr i downloaded winzip and the player displays that it is a non playable cd. Anyone that could help would be great? I just think i am improperly converting the iso image.
Seadaddy is offline
post #2 of 4 Old 07-17-2011, 07:39 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 284 Post(s)
Liked: 3948
After you unzip the image you got, you need to burn the CD in "raw" mode with the ISO image. Not all burning software may do that, although most of them do. You don't want the image written to the CD as data in file system created by the burning software. The ISO image is the exact image you want written to the disk.
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #3 of 4 Old 07-17-2011, 11:46 AM
CochiseGuy's Avatar
Imgburn is the easiest software to use and is free. It will automatically recognize an iso file and burn it as an image to the CD.
CochiseGuy is offline
post #4 of 4 Old 07-17-2011, 01:44 PM - Thread Starter
Seadaddy's Avatar
Thanks very much, i'm going to give it a shot in a while.
Seadaddy is offline
Reply HD DVD Players
