Get My X-A1 Fixed? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-18-2011, 08:29 AM - Thread Starter
Desmo888's Avatar
Anyone know of a reputable place to get my XA1 fixed?
Desmo888 is offline
post #2 of 9 Old 12-18-2011, 02:10 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Toshiba?
They used to have a flat rate of $150.
I bought a brand new XA2 off ebay which was DOA and Tosh replaced it with a brand new XA2. That was 2009. Depends on what stock they have left over.
qz3fwd is offline
post #3 of 9 Old 12-19-2011, 01:58 PM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
whats wrong with it?
RonAlam is offline
post #4 of 9 Old 12-19-2011, 04:43 PM - Thread Starter
Desmo888's Avatar
wont read HD DVD
Desmo888 is offline
post #5 of 9 Old 12-19-2011, 05:19 PM
ti-triodes's Avatar
Quoted: 231 Post(s)
Liked: 260
You can get a new laser assembly from the auction site and change it yourself. Do a search for HD DVD laser lens. They are listed for XBox but people have installed them in Tosh players with no problems. They go for $7. If you don't want to go that route, it would probably be cheaper just to get another player.
ti-triodes is offline
post #6 of 9 Old 12-21-2011, 01:38 PM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
you can also swap drives, Im pretty sure people have done that too. Especially for bricked player on auction sites.
RonAlam is offline
post #7 of 9 Old 12-21-2011, 08:39 PM
booji's Avatar
You cannot swap drives on the XA1. The main board & drive are married together on the Gen 1 players, and must be replaced as a set. If the drive alone is swapped out, the unit will not boot. Also, the Xbox lasers are Gen 2 type, and are not compatible with Gen 1 or 3 players.
booji is offline
post #8 of 9 Old 12-22-2011, 02:55 AM
junglalien's Avatar
DT0811 = 2nd gen laser. I know because I replaced one in an XA2. IDK if they work with 1st and 3rd gen.
http://www.ebay.com/itm/NEW-HD-DVD-D...item2a15a92ef1
junglalien is offline
post #9 of 9 Old 12-24-2011, 04:45 AM
booji's Avatar
Yes, junglalien is correct. Xbox lasers are compatible with Gen 2 HD-DVD players. My mistake. Previous post edited.
booji is offline
Reply HD DVD Players
