Xbox 360 HD-DVD player and the newest dashboard update? - AVS Forum | Home Theater Discussions And Reviews
Old 02-07-2012, 02:07 PM - Thread Starter
Billkwando's Avatar
Has anyone had problems getting the 360 HD-DVD player to play regular DVDs since the last dashboard update they did? (the one that borked party watching on netflix)
One of our 360s has a bum drive so we'd been using the HD drive to play both kinds of DVDs, and it suddenly stopped playing them.
Billkwando is offline
Old 02-16-2012, 08:53 AM
gar3's Avatar
I have played both DVDs and HD DVDs since the update but have not had any issues.
gar3 is offline
Old 02-16-2012, 10:39 AM - Thread Starter
Billkwando's Avatar
Awesome! That's what I needed to hear. Is this on a slim or a older 360? (just curious). The problem I'm having it on is one of the newer elites.
Old 02-17-2012, 04:21 PM
gar3's Avatar
Older white one. Jasper. I do have a friend with a slim Trinity and he hasn't had any issues either.
gar3 is offline
Old 02-20-2012, 03:39 PM
gerryger's Avatar
Actually I have the exact opposite problem. My player won't play any HD-DVD discs but it will play standard discs. This problem started with the latest Xbox upgrade.
gerryger is offline
Old 02-20-2012, 04:37 PM - Thread Starter
Billkwando's Avatar
I took mine apart and cleaned the lense with a qtip and alcohol (warning: tiny torx driver is required unless you wanna have to bend the aluminum case like I did...and it didn't go back together quite right)
Now the drive plays regular discs, but doesn't even try to play HD DVDs on the 360. If I hook it up to the computer it tries to play the hd ones, but it's jerky and the sound starts and stops.
Old 02-23-2012, 07:34 PM
gar3's Avatar
gar3 is offline
Old 02-26-2012, 12:49 PM
natecorn's Avatar
I can't seem to get my xbox to see that the drive is there at all, it's really weird. I have it connected and it says hd-dvd on the screen, but it says it's unreachable or something like that. I tried swapping usb cords to see if that was the issue but the same problem came back again, any suggestions?
natecorn is offline
Old 03-24-2012, 10:09 AM
Hockeytown Fan's Avatar
I'm having a similar problem, My x360 slim dont "see" the hd dvd add on. if i go to the settings and check hard drives it shows my hd dvd add on's drive space but I cant for the life of me find where to launch a movie from... I've trying searching and searching the dash and the internet for a solution and come across nothing but "go to video tab". Its like my x360 only see's it as a hard drive.
Help a Family in need, Show Them We Care! Like it on Facebook and tweet it!
http://igg.me/p/171832?a=874546
Hockeytown Fan is offline
Old 03-24-2012, 12:14 PM - Thread Starter
Billkwando's Avatar
Hmm, it sounds to me like you might have one of those 360s with small internal memory unit. Mine says 319 megs, but some of it's taken.
Just to reiterate, you go to the dashboard, then Video, then My Video Apps. If you don't see the HDDVD player in there, it's straight up broke, son.
Edit: I've bought 2 drives on ebay since I posted this thread and tried them both on older 360s and a slim, and they both work as expected. Basically these drives just seem to go bad sometimes. If the eject button constantly flashes, I think that's some kinda 360 error code, cos even though the drive would work on PC the 360 still wasn't havin' it.
Old 03-24-2012, 02:30 PM
have the slim 250 gig... it worked perfect till the dash update. I have no flashing lights on it either. its as if it just disappeared on the dashboard. Hooked it up to my PC to see what it does... it worked lol. WTF man
Old 03-24-2012, 02:42 PM - Thread Starter
Billkwando's Avatar
I just remembered something. Do you still have King Kong? I would try putting that in. IIRC my drive wasn't working right til I put that movie in, then it forced an update and was fine. Also try checking your USB cable. I know it's stupid but just in case.
Old 04-01-2012, 02:14 PM
Gchristie's Avatar
I had the same issue then I noticed the hd DVD app alongside my other video apps in the dashboard. It's completely off the guide otherwise
Gchristie is offline
Old 06-21-2012, 04:37 PM
Samuel M's Avatar
Mine doesn't play HD DVD's anymore, go figure.....
Samuel M is offline
Old 06-22-2012, 02:42 PM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
I had a similiar issue on the new slim models. My solution:
First re-install the drivers from the disc it came with, now look in the video apps tab. The new dash moved it to the tab. Now I can watch my HD DVDs again...
RonAlam is online now
Old 12-18-2012, 04:56 PM
tbase1's Avatar
Quoted: 43 Post(s)
Liked: 66
no sound playing hd-dvd add-on (usb) to 360 slim (hdmi) to avr to tv (hdmi)? (WTF)
tony4k
tbase1 is offline
Old 12-19-2012, 12:52 PM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
possible HDMI handshake issue ?
Old 02-19-2013, 12:13 AM
JasonRain's Avatar
_________________
WoW gold|Diablo 3 Gold|Runescape Gold|GW2 Gold
JasonRain is offline
Old 03-18-2013, 01:07 AM
Lord Q Hilleous's Avatar
I just tried to play my Hd DVD player and had the same issue. After an hour or so, I finally got it working. You have to go into settings, and enable 'auto play'. then insert your disk into the drive and it will start automatically. After that you can then turn auto play off again if you wish. Now when you go to the video/movie blade, you go into 'my video apps' and there will be a app that says 'HD-DVD" and thats how you play it from now on. This is the only way to get the app to show up.
Lord Q Hilleous is offline
Old 03-18-2013, 01:07 PM
RonAlam's Avatar
Quoted: 12 Post(s)
Liked: 30
look 3 posts up...and the previous post...
Old 06-30-2013, 01:50 PM
Gary Smith's Avatar
yes this works spot on cheers
Gary Smith is offline
Old 06-30-2013, 01:58 PM
Gary Smith's Avatar
why not? reinstall hd dvd disc go to video apps it will be there
Old 12-10-2013, 10:11 AM
Gabriel Sch's Avatar
can anyone know the latest version of the HDDVD player upload to download because it is no longer available latest version
Gabriel Sch is offline
Old 12-10-2013, 10:24 AM - Thread Starter
Billkwando's Avatar
If you still have your King Kong DVD that should install the software. I don't think newer versions have any added functionality.
Old 02-12-2014, 03:41 PM
zacmac77's Avatar
what worked for me is putting a disc in hd player (if able) and going to tv/video on dashboard and select "my apps" and look for hd movie. hope this helps as this advice helped me find mine. And sorry if this was already figured out or to old
zacmac77 is offline
Old 01-30-2015, 05:07 AM
Frank714's Avatar
Quoted: 462 Post(s)
Liked: 195
I'm late too the party, but maybe someone could help / explain.
With the arrival of the Marantz SR 7009 AVR it seemed a good time to finally revisit my HD-DVDs.
Problem: The playback of my HD-DVD drive via the SR 7009 to a FullHD DLP projector features images, where approx. every 3-4 seconds the image twitches / jumps as if it just skipped a couple of frames.
I had the output settings of my XBox alternate between "1080i" and "1080p" but the unpleasant effect prevails in both settings, I had also the video conversion of the SR 7009 disabled to make certain it's not the SR 7009 interfering, alas, no riddance of the problem.
Help or suggestions would be much appreciated. Could playback of my King Kong HD-DVD (see older suggestions), prompting an HD-DVD update, solve the issue?
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
