How to disable Deep Colour on Toshiba XE1/XA2? - AVS Forum | Home Theater Discussions And Reviews
Old 11-09-2012, 03:17 AM - Thread Starter
Webmonkey's Avatar
Quoted: 52 Post(s)
Liked: 31
Hi guys!
I am having a problem with longer cable runs to my new projector and if I select 1080p on my XE1, I get sparkies and drop-outs. 1080i and 720p er fine.
I do not see a menu option for disabling deep colour, - it seems to be on by default (the menu of my X30 says 12-bit) .
Webmonkey is online now
Old 11-11-2012, 09:46 AM - Thread Starter
Webmonkey's Avatar
Quoted: 52 Post(s)
Liked: 31
nobody is using this player anymore? :-(
Old 11-14-2012, 04:24 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 3969
12bit video is not necessarily Deep Color. 12bit YCbCr 4:2:2 has been supported since HDMI V1.0. You're going to have to boost the signal. A different cable may make a difference, but that would be trial and error. You may need to get two cables with a equalizer in the middle. Trying an equalizer by itself on the source end may help and save you the trouble and expense of getting new cables. Something like this: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10419&cs_id=1041907&p_id=2849&seq=1&format=2
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
