LG BH200 Firmware on XA1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-11-2012, 10:46 AM - Thread Starter
nightstalkerbry's Avatar
Hi,
I'm rather new to the HD-DVD arena. I've found it's a cheap way to beef up an HD video collection, and am trying to make the best of it. With that said, I'm really curious if this can be done:
The A1 and the XA1 both use standard motherboards that allow you to easily replace the firmware flash memory with a different usb drive.
With that said, I'm really curious if the firmware from the LG BH200 could be written to a flash drive and swapped into an XA1. If not, perhaps it could be ported over?
I suggest this because the HDDVD drive in the XA1 is a standard IDE drive that could easily be swapped out with a Bluray/HDDVD combo drive.
This if done correctly would potentially give you an LG BH200 with multichannel analog out.
Perhaps you could then replace the processor with something faster, and faster larger RAM and have a Dual format player that kicks major ass!
nightstalkerbry is offline
post #2 of 4 Old 12-11-2012, 11:20 AM
8traxrule's Avatar
Firmware for one product can't be installed on another. I bricked a Toshiba A2 (it stayed on "Welcome" and never started up) just by loading a CD with firmware for a different Toshiba model by accident.
8traxrule is offline
post #3 of 4 Old 12-11-2012, 11:47 AM - Thread Starter
With the A1 and XA1, it shouldn't brick, because you'd keep the original firmware device on the side and replace it if necessary. I think...
post #4 of 4 Old 12-11-2012, 04:26 PM
junglalien's Avatar
lol
no you can not put LG firmware on a Toshiba
junglalien is offline
Reply HD DVD Players
