HD-A3 stuck on wecome screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-12-2013, 01:45 PM - Thread Starter
Simondupay's Avatar
Went to update frimware and it got to step 4/4 and froze so I restarted it and now it's stuck on the wecome screen and won't boot up. I tried unplugging it to reset it but it didn't work I also got the disk out. Should I be looking for another player or is there a fix?
Simondupay is offline
post #2 of 4 Old 02-13-2013, 09:29 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4130 Post(s)
Liked: 4220
I don't if there is fix, but I have a brand new never used HD A3 in the classified section !
http://www.avsforum.com/t/1450766/toshiba-hd-a3-hd-dvd-player-new-never-used
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #3 of 4 Old 02-26-2013, 01:07 PM - Thread Starter
Simondupay's Avatar
Any way of resetting the firmware?
post #4 of 4 Old 02-26-2013, 03:32 PM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
The only solution I have ever heard of is to insert the firmware update disc into the player, and restart it and hope the firmware update process picks up where it left off. You could send it to Toshiba to fix, but that would probably cost more than the player is worth.
A long-time audio/video addict!
Rich86 is offline
Reply HD DVD Players
