HD-A1: No video after initializing? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-04-2014, 10:48 PM - Thread Starter
PowerPC's Avatar
So I decided to initialize to reset all of the crap I've changed over the years and then... no more video. Waited a while, then turned the machine off, turned it back on... on-unit display read that it was in SETUP but still no video.
I put in a disc, it began to play but I didn't have any audio or video.
What could have possibly gone wrong?
The component output still works though.
PowerPC is offline
post #2 of 10 Old 09-07-2014, 08:44 PM
RonAlam's Avatar
Quoted: 65 Post(s)
Liked: 52
select HDMI output in the settings?
RonAlam is offline
post #3 of 10 Old 12-07-2014, 03:58 PM
Bepaof8's Avatar
Quoted: 17 Post(s)
My HD-XA1 lost it's video and audio output this week. My main DVD player for over 6 years. Time to resort to my backup HD-A30. Hope it works!
Pete
Bepaof8 is offline
post #4 of 10 Old 12-08-2014, 04:27 PM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
Pete
Have you lost audio & video via ALL available connections (hdmi, component, composite, analog audio, digital audio)? Is the player loading and reading the disc ok? Have you tried both DVDs & HD-DVDs (I believe they use different lasers mounted on the laser assembly). Have you "initialized" the player in case something got messed up internally? See pg. 57 in the manual for how to initialize your player (link below).
http://support.toshiba.com/support/m...eeText=2809956
Just some thoughts & ideas . . .
A long-time audio/video addict!
Rich86 is offline
post #5 of 10 Old 12-08-2014, 04:44 PM
Bepaof8's Avatar
Quoted: 17 Post(s)
Thanks - I'll give it a shot!
Pete
Bepaof8 is offline
post #6 of 10 Old 05-21-2015, 10:22 AM
Traveler62's Avatar
My A1 will not play HDDVD, but would play DVD. Does anyone know what this means? I have had it unplugged for a long time.
There is a battery on the board that may be dead. Is this worth getting fixed or find something on Ebay? I do have an A35 that works fine.
Traveler62 is offline
post #7 of 10 Old 05-22-2015, 01:07 PM
RonAlam's Avatar
Quoted: 65 Post(s)
Liked: 52
try cleaning the lens?
RonAlam is offline
post #8 of 10 Old 05-22-2015, 07:02 PM
Traveler62's Avatar
How do you clean the lens? Is it necessary to take it apart?
It won't read HDDVDs or CDs (music or firmware CD that I made). With HDDVDs, it just makes to clunking noise for about a minute and says no disk. With CDs, it clunks a couple of times before saying no disk. DVDs play just fine.
Is there a file somewhere to use firmware on a USB thumb drive?
post #9 of 10 Old 05-25-2015, 08:23 PM
RonAlam's Avatar
Quoted: 65 Post(s)
Liked: 52
sounds like a dead laser bud :-(, to clean the laser, yes, youd need to take it apart.
RonAlam is offline
post #10 of 10 Old 09-11-2015, 02:35 PM
Bepaof8's Avatar
Quoted: 17 Post(s)
I did the "Initialize" and now it plays HD DVD's and DVD's, but it doesn't like my Onkyo TX-NR646. It doesn't want to play a HD DVD and says something about a HDMI error, even though it's connected to the receiver using HDMI. When connected directly to the Sony XBR-70X850B, it works fine. Strange. I don't see any settings for the Onkyo that might make that happen. I'll just run the audio through the receiver and live with it.
Pete
Bepaof8 is offline
Reply HD DVD Players
