for about $15 I sure hope it is! The only region free player I still own is the Oppo BDP-83 (some FW hack)
I wouldn't mind turning my XA2 into region free!!
if any of ya'll have successfully done this, please lemme know
It's kinda sorta legit, but you can get the same off AVS for free plus a few CDs.
You need 3 firmware updates - one of them downgrades you to 1.x, the next converts you to the HD-XE1 which is the region free Euro version presuming you want PAL playback as well. The third accomplishes the region free part. Edit: once done, then you apply the appropriate 4.0 update.
HD-DVDs are region free by default, so all you're doing is making the DVD side region free.
There's a thread in this forum all about it... With links. I found one that brought you to someone's one live account.
So I took the plunge and converted my XA2 to "region free" however there appears to be some exceptions to this. I have some older Region 1 Paramount titles and it appears all Region 1 Fox titles are unable to be played. Anyone know the reason for this? All other region 1 studios I've tried appear to play ok.
After making the player regionfree, and if you want to play a RCE encoded region 1 disc (like those from Fox), you will need to apply the RCE hack which is as follows:
RCE HACK.
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T.search on remote.
You will see TEST on your player
6) Press PLAY on the remote
When player is turned off, this setting is cleared.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
