Error msg - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-26-2017, 09:09 AM - Thread Starter
muslov1's Avatar
Error msg
When i attempt to play a dvd or hddvd disc i receive an error msg. That reads " this disc is not dvd format" any one know what the issue causing this? Thanks
muslov1 is offline
post #2 of 10 Old 02-26-2017, 10:26 AM
Super Moderator
teachsac's Avatar
Quoted: 861 Post(s)
Liked: 1397
It would help if we knew what player you are using.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3 of 10 Old 02-26-2017, 12:03 PM - Thread Starter
muslov1's Avatar
I apologize, DAH! HD-A2
muslov1 is offline
post #4 of 10 Old 02-26-2017, 12:05 PM - Thread Starter
muslov1's Avatar
Also, I have done the firmware update , its showing 2.8/T23T
muslov1 is offline
post #5 of 10 Old 02-26-2017, 10:35 PM
Rich86's Avatar
Quoted: 136 Post(s)
Liked: 67
I expect the player is unable to read the discs you are trying. Is this a player you have had for a while and it has always worked ok? If it does this on all discs, and you have tried a number of them you know are good, then the laser assembly in the player may be the culprit. You might try cleaning the laser lens.
A long-time audio/video addict!
Rich86 is offline
post #6 of 10 Old 02-27-2017, 09:00 AM - Thread Starter
muslov1's Avatar
Yes I purchased this new , when the blue ray vs. HDDVD war was on. I picked the wrong side! It has been working last time I used it about 6 months ago. I have tried several discs and regular DVD's getting the same msg. I'll try what you suggest. thx
muslov1 is offline
post #7 of 10 Old 02-27-2017, 10:32 AM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
The latest firmware version is v 4.0.
https://onedrive.live.com/?id=6948F2...48F2460BDD190C
Download HD-A2-4000N.zip, unzip the iso file and burn that file as an image to a CD (do not use DVD).
But most likely it is an hardware error on the HD DVD drive in the player.
Viking61 is offline
post #8 of 10 Old 02-27-2017, 12:54 PM - Thread Starter
muslov1's Avatar
I will try the newer update , but you'd think it would still recognize the disc with the previous update. if it is a hardware error will this update remedy that? if it does not is there something else I can do for the hardware issue? thanks
muslov1 is offline
post #9 of 10 Old 02-28-2017, 06:43 AM
Viking61's Avatar
Quoted: 18 Post(s)
Liked: 27
You can check on ebay if you find a cheap broken A2, A20 or XA2 with an error anything else than drive related. They all have the same drive. Some players got stuck on WELCOME during a firmware upgrade. Those players should have a perfectly fine drive. Then you can just swap the drive. But I guess HD DVD players are so cheap now that you can just buy one fully working. Your HD-A2 was one of the early models that don't support Full HD, so you will get better picture with a bit newer model.
Viking61 is offline
post #10 of 10 Old 02-28-2017, 12:23 PM - Thread Starter
muslov1's Avatar
thanks for the information and assistance
muslov1 is offline
Reply HD DVD Players
