Toshiba HD-A1 HD-DVD FAQ: Link and Discussion thread - Page 26 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #751 of 753 Old 04-15-2008, 12:54 PM
mcjimsey's Avatar
Liked: 26
I set up analog outs on the A35 going into a Rotel Pre/Pro going by the distance setting for delay by measurment. This weekend I wanted to tweek these using the Phase test signals on Avia II test disk. I sit slightly off center on my R&L front speakers so I adjust the delay to shift the Phantom image between the front speakers and then work around the room with the Center & Sourrounds (works very well with my Pre/Pro & Denon BD player). Now, I adjusted the distance on my LT Front speaker ranging from 0 to 20 feet leaving the RT front set @ 12 feet WITH ABSOLUTELY NO EFFECT on the sound!
Am I missing something on the A35 player, these distance setting don't do anything. Are they just for looks?
I have debating changing this A35 back out for my A1 because I think the analog section of the A1 is better but I don't remember "IF" the A1 shares this issue?
Anyone try this test with the A1? Comments??
Thanks, Bob..
mcjimsey is offline
post #752 of 753 Old 05-06-2008, 07:18 AM
yukon04's Avatar
Han anyone upgraded to f/w ver 3.0? I downloaded from website and am debating whether to install.
yukon04 is offline
post #753 of 753 Old 05-07-2008, 03:38 PM
Tyrod's Avatar
I installed it directly from ethernet. I don't notice any changes at all.
Tyrod is offline
Reply HD DVD Players
