Toshiba HD-A1 HD-DVD FAQ: Link and Discussion thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #91 of 753 Old 04-22-2006, 11:00 AM
jschefdog's Avatar
Originally Posted by RichB View Post
I do not think you are correct with analog. I tried playing phantom and selecting the True-HD output and the player said it was not supported on this player. I would love to get True-HD out the analog outputs. Is there a trick?
- Rich
What it says is that "multi-channel" TrueHD is not supported. The spec sheets and manuals say that TrueHD is 2 channel only. If you go ahead and click OK, you will get 2 channels sent to whatever output you are using, including analog.
John S
jschefdog is offline
post #92 of 753 Old 04-22-2006, 11:27 AM
BenDover's Avatar
Yes, you are correct...the manual also indicates this to be the case...only 2 channel TrueHD.
BenDover is offline
post #93 of 753 Old 04-22-2006, 05:59 PM
brosnan's Avatar
Q: Is it possible to do single frame advance?
A: Not on the available HD-DVDs. The manual indicates the player is capable of single frame advance but that some discs may not allow that. For the HD-DVDs I have, the pause button just toggles between pause and play.
Mike
brosnan is offline
post #94 of 753 Old 04-22-2006, 06:12 PM
fire407's Avatar
Wow! No single frame advance? I'm just trying to get the basic information on this player and it's taken 93 posts to know that it doesn't have single frame advance. Post 30 is me asking about slow motion forward and reverse, and there's still no answer here. For example the HD-Tivo will let you slo-mo going forward, pause, and step frame by frame going forward only. However forward only does give you the abilty to study a scene frame by frame. I'll ask the question again. Is there any slo-mo capabilities with this machine using a HD disk?
fire407 is offline
post #95 of 753 Old 04-22-2006, 07:30 PM
brosnan's Avatar
Originally Posted by fire407 View Post
Q: ... does it do slow motion both forward and reverse?
A: No. it does forward slow motion only. There are several levels of slowness, but no indication of current speed.
Mike
brosnan is offline
post #96 of 753 Old 04-23-2006, 02:39 PM
TWD
TWD's Avatar
Quoted: 48 Post(s)
Liked: 42
If you are using HDMI out for video, does the player also output audio on the 2 channel audio out?
TWD
TWD is offline
post #97 of 753 Old 04-23-2006, 06:18 PM
jschefdog's Avatar
I have not tested 2 channel, but I know that you get 5.1 channel analog out regardless of whether or not you have an HDMI connection for audio and video. I think the analog signal is always sent to the RCA jacks no matter how you have it connected. I would expect 2 channel analog is always on as well.
John S
post #98 of 753 Old 04-24-2006, 03:41 AM
rdjam's Avatar
Originally Posted by Kadath View Post
Q: My remote seems to have a problem with the 'down' menu button, is this normal?
A: This seems to be a common complaint within the first batch of HD-A1 owners. Some have had better luck by replacing the batteries, but others have had to move to replacement remotes such as the Logitech Harmony series. Generally, the included remote is not considered a very good one due to poor layout, low visibility, no backlighting, 'missed' commands and more.
Sam
Hi Kadath - it's the contacts for the down button on the remote.
See some info on how to replicate here http://www.avsforum.com/avs-vb/showt...17#post7538317
It will help you enormously to go into Setup/General and set Remote Control Sounds "On".
rdjam is offline
post #99 of 753 Old 04-24-2006, 01:00 PM
ClaytonMG's Avatar
Originally Posted by sdavid21 View Post
A: Yes, Through HDMI, Not through Component
Q: Will it do so over component outputs?
A: No, Not through Component
It depends on the DVD. I belive if the copyprotection from the DVD is removed, it will display the DVD in both 720p and 1080i. But most DVD's will only play in 480p.
ClaytonMG is offline
post #100 of 753 Old 04-25-2006, 06:17 PM
UHD Addict
aaronwt's Avatar
Quoted: 6048 Post(s)
Liked: 3747
So should the player be set to enhanced black or not for HDMI out?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #101 of 753 Old 04-25-2006, 06:27 PM
satfam's Avatar
Quoted: 44 Post(s)
Liked: 56
I have a Pan A700E front projector with a HDMI to DVI cable--about a 30' run from my rack to the ceiling mounted projector. I was using a Denon 1910 dvd player which has a DVI out. Now I am considering the new HD DVD player using a Parts Express female DVI to male HDMI adapter. Will I have handshanking problems? Thanks.
H/T: Marantz 7702MK II, MM8077, MM7055, Triton 2s, SCXL, SL/SR-S50s, BL/BR-S50s, H/W-4 Sat3s, dual SB16 Ultras, Sony HW50ES, Dalite 110", Tivo PXL, PS-3, Apple TV, GIK Acoustics treatments
Gameroom: Denon AVR-X4300H, NHT S2,SC, 4 NHT ceiling speakers, 2 Velo SPL-1000R, Sony XBR65X850C, PS3, 4, Sony FMP-X10, Samsung K8500
satfam is offline
post #102 of 753 Old 04-25-2006, 07:17 PM
CasualViewer's Avatar
To connect to the Internet and do the firmware upgrade, does the player have to be hooked up to a TV/Projector to see what is happening? The reason I ask, is that my Internet connection is in another room. I have to decide whether to move the Internect connection or move the player without the TV (200 lb. CRT).
CasualViewer is offline
post #103 of 753 Old 04-25-2006, 10:45 PM
Techtom's Avatar
Q. I have an older HDTV that only supports component input. If I connect the HD-A1 to my HDTV what resolutions will I get?
A. For component output, you will get the following results:
  • Copy protected DVDs will be upconverted to 480p.
  • Non copy protected DVDs will be upconverted to 720p or 1080i based on the HD-A1 resolution setting.
  • HDDVDs without ICT will be output at either 720p or 1080i based on the HD-A1 resolution setting (current HDDVD titles are shipping without ICT, e.g Phantom..).
  • HDDVDs with ICT will be downconverted to 960x540p.
-Techtom
Techtom is offline
post #104 of 753 Old 04-26-2006, 04:52 AM
trbarry's Avatar
-Techtom
Shouldn't the last line be "HDDVDs with ICT will be downconverted to 960x540p, and then output at 720p or 1080i based on the HD-A1 resolution setting"?
- Tom
Why don't we power our electric cars from greener, cheaper Liquid Fluoride Thorium Reactors?
Tom Barry - Find my video filters at www.trbarry.com
trbarry is offline
post #105 of 753 Old 04-26-2006, 05:33 AM
Oppo Beta Group
RichB's Avatar
Quoted: 1199 Post(s)
Liked: 786
-Techtom
Call or send mail to digitalconnection.com. I believe they had a solution that handled HDCP as well.
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is online now
post #106 of 753 Old 04-26-2006, 06:17 AM
rdjam's Avatar
The "slow" button does work on the discs I tested. Only in forward.
The first press of "Slow" start slo-mo mode, each subsequent press drops the slo-mo speed more.
I meant to test the pause by holding it down continuously but forgot.
rdjam is offline
post #107 of 753 Old 04-26-2006, 06:19 AM
rdjam's Avatar
I choose not to use Enhanced Black - and this is a general rule for all my sources except DVHS.
rdjam is offline
post #108 of 753 Old 04-26-2006, 06:28 AM
rdjam's Avatar
Hi all - just as a note, I got confirmation from Calibre that the Vantage HD supports PCM audio up to 8 channels to be passed through over HDMI and still have the automatic time delay feature working. I'm assuming they meant up to 96/24, which is the 1.1 HDMI limitation, I think.
I'll be testing this out tonight.
rdjam is offline
post #109 of 753 Old 04-26-2006, 07:43 AM
Ursa's Avatar
Q: Where can I find a pre-built file for the HD-A1 for my programmable remote control?
A: Try this thread: http://www.avsforum.com/avs-vb/showthread.php?t=671196
Ursa is offline
post #110 of 753 Old 04-26-2006, 07:49 AM
Ursa's Avatar
Q: Can I have more than one output active at once?
A: Sort of. When the player is in 480i mode, both the component and S-Video outputs are active. However, at any resolution above 480i, only one output will be active (i.e., HDMI or Component).
Q: Can I use HD-DVDs with my SDTV (to take advantage of the improved audio)?
A: No, the minimum resolution for HD-DVDs is 480p with the HD-A1. Thus, you need an EDTV or HDTV for use with HD-DVDs.
Ursa is offline
post #111 of 753 Old 04-26-2006, 10:26 AM
William L Carman's Avatar
Quoted: 115 Post(s)
Liked: 33
Q: How do you use the book mark function? I tried several times pressing "B" on the remote and nothing happens! I cannot find any reference to book marks in the manual.
William L Carman is offline
post #112 of 753 Old 04-26-2006, 08:34 PM
ingram4868's Avatar
Q: Will HD DVD also have macroblocking issues that the SD Faroudja chip players had with the Panasonic HDTV plasma?
A:
ingram4868 is offline
post #113 of 753 Old 04-26-2006, 08:51 PM
rdjam's Avatar
The "B" button works on mine - at least for Phantom of the Opera. I actually pressed it by accident while experimenting.
And you're right, I had *scoured* the manual for a reference, but there was nothing
rdjam is offline
post #114 of 753 Old 04-26-2006, 08:52 PM
rdjam's Avatar
A:
The Toshiba players do not have the macroblocking issues - good news
rdjam is offline
post #115 of 753 Old 04-27-2006, 05:00 AM
efranzen's Avatar
I believe that the B bookmark ability is a feature of the Warner discs only (iHD option?). It even explains that option at the beginning of TLS (that's the only Warner title I have). The Warner discs also show counters on the title menus with a time remaining bar whereas the Universal titles do not.
efranzen is offline
post #116 of 753 Old 04-27-2006, 07:17 AM
mikeny's Avatar
Sorry if this was asked already, but, does the A1 play back DVD Plus R and RWs?
I know it's advertised to play the DVD -R and -Rw
Edit:
Found good news in this post:
"Originally Posted by aaronwt
My Memorex and Verbatim SL and DL discs are all set to change the booktype to DVD-Rom. They work in my A1 no problem.
+R DL and SL and +RW discs all work fine in my A1. I don't have any problems with the several discs I've tried."
XBL: mmjp08 PSN: mikeny1
mikeny is offline
post #117 of 753 Old 04-28-2006, 08:21 AM
RADMANK's Avatar
Q: Looking to connect a ethernet bridge to this will it work?
RADMANK is offline
post #118 of 753 Old 04-28-2006, 09:35 AM
eizenga13's Avatar
Originally Posted by disgruntled1 View Post
Q: When upconverting SD DVDs is there any MB-Enhance artifacts like in the Panasonic S77/97, Oppo, etc?
A: ?
I am the proud owner of the DVD S97 and the HD-A1, I can say with no hesitation that the HD-A1 blows the DVD- S97 out of the water (sorry old girl, we got to put 'ya down!) I watched a few S97 staples yesterday and was pleasantly suprised. Master and Commander looked better than the best setting on the S97 when played through the HD-A1, Obviously the authoring of the DVD is intrinsically going to have MB, but the HD-A1 really cleaned it up a lot, the scene with the anchor during the first "duet" still was unappealing but better than I have previously seen it. The SW Episode III has absolutely NEVER EVER been as crisp and clean (execept on opening night at the digital theatre)... can't wait for either on HD-DVD now! Hope this helps, PM me with any other questions.
eizenga13 is offline
post #119 of 753 Old 04-28-2006, 11:54 AM
Donnie Eldridge's Avatar
Q: Can I play HD-DVD media from other countries?
Donnie Eldridge is offline
post #120 of 753 Old 04-28-2006, 01:13 PM
eizenga13's Avatar
A: No... and YES. The disc must be coded Region 1 or ALL encoded... SO technically if you have HD-DVD with the REGION ALL encoding you can play it on the HD-A1.
Reply HD DVD Players
