Tosh Hd-xa1 User Thread & LINK to FAQ - Page 63 - AVS Forum | Home Theater Discussions And Reviews
post #1861 of 1863 Old 06-20-2008, 08:17 AM
willyd's Avatar
bump
i'm trying to figure out if my rca hd dvd player is worth keeping as a cd player. it looks like i could resell it for $50-$100 on ebay (about the same amount i paid for it -- possibly a tad more, even). any help? do i have to connect the 2.0 stereo analogs to take advantage of burr browns for cd's?
the 5.1 analog inputs are going to be re-occupied by a new pioneer 05fd blu-ray player.
thanks in advance for any help that can be provided.
willyd is offline
post #1862 of 1863 Old 06-20-2008, 08:53 AM
eitakura's Avatar
Originally Posted by willyd View Post
bump
yes, if you connect the 2.0 stereo analog outputs, you'll benefit from the burr browns.
eitakura is offline
post #1863 of 1863 Old 06-23-2008, 12:12 PM
tienvg's Avatar
Originally Posted by stevo1214 View Post
Remote from the 2nd and 3rd generation works but they don't have the 'V ouput' and ' Resolution' buttons, So I don't know if you can change the resolution or switch the video output or not.
I contacted the seller to see if he can find the missing remote. Turns out he had the remote. Finally got the remote but didn't have the 'V output'. It turns out he sent me the remote for the XA2 (se-r0251)instead. It looks almost the same as XA1 but has a button label 'picture' instead of 'v out'. I still couldn't get it to change resolution with this button. I found out this remote cost twice as much as the XA1 . If anyone has an extra XA1 remote to exchange, let me know..
tienvg is offline
Reply HD DVD Players
