HD-A1 software update?? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
post #181 of 828 Old 06-02-2006, 07:51 PM
slimm's Avatar
Also, make sure that you actually click yes on the update screen. I found it hard to figure out whether yes or no was highlighted.
slimm is online now
post #182 of 828 Old 06-02-2006, 07:51 PM
killrmonkey's Avatar
Do you like the all black faceplate a hundred dollars more?
I do like the all-black look better, but I don't think a hundred dollars better. :) It's hidden behind the screen when I'm watching anything anyway. I'll have to really make sure all the glitches from that player are fixed before I decide.
Jason
killrmonkey is offline
post #183 of 828 Old 06-02-2006, 07:53 PM
Malcolm_B's Avatar
isn't this HDVD player supposed to play Standard Audio CD's as well?? Because mine sure doesn't
Mine plays CDs, and they sound terrific!
Blu Ray... 3-D TV... 4K... I Like New STUFF!!!
Malcolm_B is offline
post #184 of 828 Old 06-02-2006, 07:58 PM
Zbranek001's Avatar
Thanks for the update..... I burned the update using NERO 7... no problems...... The player seems to be running smoothly.... Since I've purchased the HD-A1 I've had nothing but lock-ups. Maybe tonight will be different!
Zbranek001 is offline
post #185 of 828 Old 06-02-2006, 08:02 PM
emilsjr's Avatar
Thanks for posting this.
For those like me who did not have Nero installed, you can get a 30 day eval of it from their site. Worked like a charm.
I do agree with some others that speed is not much different. However, my one trouble disc (VAN HELSING) now plays without issues.
I and many other people like to forget. Thank you . Even the panel member from DLUX on the home theater cruise agreed that DL BD is not real and is akin to science fiction. - AMIR
emilsjr is offline
post #186 of 828 Old 06-02-2006, 08:03 PM
Gary Murrell's Avatar
whats everyone elses time (in seconds) before you see video on screen after the drawer just closes, I am getting around 45 to 48 seconds
-Gary
Gary Murrell is offline
post #187 of 828 Old 06-02-2006, 08:04 PM
djpheer's Avatar
so again, does this update fix the issue with samsung HLS tvs not being able to connect?
Samsung 60'' 7150 Series
djpheer is offline
post #188 of 828 Old 06-02-2006, 08:07 PM
Kris Deering's Avatar
Quoted: 1711 Post(s)
Liked: 2689
Just loaded the firmware and it fixes the clipping issues with HDMI. BTB and above white information are fine now. Nice. I will see how many dropouts I get though. I've been having a hell of a time with those lately. Serenity and The Fugitive were dropping out and getting HDMI errors A LOT.
My Home Theater
Kris Deering is offline
post #189 of 828 Old 06-02-2006, 08:09 PM
1st on the Block's Avatar
The display on the player shows the progress in 5% increments for firmware completion. It does take 7-10 minute for the upgrade and the progress slows down around 60Pct (display) to a snail's pace. Oh, by the way, another successful A1 firmware upgrade here.
Pete
The endless pursuit of perfection..or my idea of it anyways........
1st on the Block is online now
post #190 of 828 Old 06-02-2006, 08:13 PM
Jon Spackman's Avatar
York is the man! I updated my Xa1 and the spots on FMJ that would freeze are perfect now. I also tried the spot on serenity that locked my player and required a power cord pull to reboot and it plays perfectly! no hiccup or nothing.
THANKS really go out to Toshiba for giving us this update. My only two complaints (freezes) are solved!
I also noticed that if i switch my Yamaha RV2600 to a different source while playing an HD DVD it says "HDMI NO LINK" and then stops the disc. No more "HDMI ERROR 0". It still makes you start the disc over from the beginning, but at least it doesn't look like a cable fell out or something because the handshake is broken.
Just enjoy HD in whatever form you can (Sat, Cable, D-VHS, OTA, HD DVD, or BD).
Jon Spackman is offline
post #191 of 828 Old 06-02-2006, 08:14 PM
emilsjr's Avatar
Exactly the same here on my A1.
emilsjr is offline
post #192 of 828 Old 06-02-2006, 08:16 PM
Gary-
I am getting 45 seconds from when the tray closes to when I get the universal earth thingy starts with sound. Did you time it before? I did not, if you did waht was your time before?
post #193 of 828 Old 06-02-2006, 08:17 PM
RWetmore's Avatar
Quoted: 383 Post(s)
Liked: 209
Successful update here too...thanks.
RWetmore is offline
post #194 of 828 Old 06-02-2006, 08:17 PM
Eric Busch's Avatar
I just applied the update to my HD-XA1, and I'm now having what would seem to be an HDMI audio problem. The player is hooked up to a Sharp 45" LCD via HDMI, with the player's digital audio output going into my receiver. Everything was working fine, but since applying the update I'm now getting a very high pitched whine from the TV speakers whenever the player is idling at the No Disc screen or within the Setup menu. Once a movie is in and playing the whine goes away and everything works as expected. When the HDMI connection is first established I noticed that the TV gives the following error: "An incompatable audio setting has been recieved. Check the output device settings." I don't remember ever seeing that before the update, and I've tried changing the players HDMI audio settings but that seems to have no effect. Is there anyway to completely disable the HDMI audio output and use it just for video?
Eric Busch is offline
post #195 of 828 Old 06-02-2006, 08:19 PM
LordofDoubleD's Avatar
Quoted: 88 Post(s)
Liked: 158
Is this the Nero 7.2.0 version? Sometimes I need help. I'm a Mac guy livin' in a PC world. :D
LordofDoubleD is offline
post #196 of 828 Old 06-02-2006, 08:19 PM
It's maybe coincidence, since the update, I've had better success getting the A1 to recognise +R DL discs with HD DVD files, on first load instead of reloading or wiping then retrying.
Pete
post #197 of 828 Old 06-02-2006, 08:19 PM
acegamer's Avatar
Well Van Helsing played great all the way through to the end! I have just started the chapter of Bourne Supremacy that was giving me trouble and that has already played through as well. I think that the freezing has been solved!
acegamer is offline
post #198 of 828 Old 06-02-2006, 08:22 PM
Josh Z's Avatar
Quoted: 2158 Post(s)
Liked: 1447
you need to use Nero, load the image nrg into nero and then burn it, use the lowest speed possible like Pimp said
I have Nero 5.5.8.2 and it doesn't even offer the option of changing the burning speed.
I've burned 3 copies now and the HD-A1 tells me, "This disc is not DVD format. Can not play the disc."
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
post #199 of 828 Old 06-02-2006, 08:30 PM
emilsjr's Avatar
Yep, but I believe Nero is Windows only.
Do you have an Intel Mac, by any chance?
Or access to the Virtual PC?
Assuming the older version is like 7.02, I had to skip the opening wizrd. I then went to the Recorder pull down and picked Burn Image. This then allowed selection of the file, and could select the write speed. Worked like a charm.
emilsjr is offline
post #200 of 828 Old 06-02-2006, 08:32 PM
Quoted: 88 Post(s)
Liked: 158
I have a PC laptop that I'm using - a Dell.
post #201 of 828 Old 06-02-2006, 08:32 PM
Quoted: 88 Post(s)
Liked: 158
do we need to delete that (savefile) text from the beginning of the file name?
post #202 of 828 Old 06-02-2006, 08:34 PM
emilsjr's Avatar
no, just point it to the file, with the (savefile).
emilsjr is offline
post #203 of 828 Old 06-02-2006, 08:35 PM
Hunter67's Avatar
I load my CD-R and I get nothing onscreen but the display says "VERUP" and just sits there; what gives?
Hunter67 is offline
post #204 of 828 Old 06-02-2006, 08:36 PM
bferr1's Avatar
Quoted: 87 Post(s)
Liked: 92
yorkie2k, thanks! Works perfectly!
bferr1 is offline
post #205 of 828 Old 06-02-2006, 08:45 PM
Hunter67's Avatar
Never mind, for some reason my display lost sync and wasn't displaying a picture....upgraded without a hitch!
Thanks guys, I haven't been this excited since I bought my player!
Hunter67 is offline
post #206 of 828 Old 06-02-2006, 08:47 PM
Ron-P's Avatar
How do I bring up the firmware?
Sometimes you reach what's real by making believe.
Ron-P is offline
post #207 of 828 Old 06-02-2006, 08:53 PM
eizenga13's Avatar
OK I got the update, but my HD-A1 still doesn't play CD's... that is VERY ODD... since I hear people tell me they sound quite nice... any idea why mine doesn't like CD's??
eizenga13 is offline
post #208 of 828 Old 06-02-2006, 08:56 PM
Quoted: 88 Post(s)
Liked: 158
Nero is giving me 4 image types:
Data Mode 1
Data Mode 2
Audio
HFS
also there is a raw data check box
What do I select? I tried Data Mode 2 - no dice!
post #209 of 828 Old 06-02-2006, 09:04 PM
Robert George's Avatar
Location: Trapped in time. Surrounded by evil. Low on gas.
You are not burning to the disc. I had this message also and after futzing around with Nero, I discovered some versions of this program it is not as simple as point and click to burn an image.
Robert George is offline
post #210 of 828 Old 06-02-2006, 09:05 PM
Quoted: 88 Post(s)
Liked: 158
So what do we do?
Closed Thread HD DVD Players
