Pictures of the inside of HD-DVD player? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 08-17-2006, 11:59 AM - Thread Starter
ResOGlas's Avatar
I was curious if any of you brave souls have opened up your HD-DVD player and taken pictures? From what I understand there is a Pentium 4 processor and PC Memory inside? Does anyone know what type of memory? It would be neat if we could replace the RAM and cut back on bootup times, I guess it all depends on the maximum amount of memory the motherboard supports.
ResOGlas is offline
post #2 of 27 Old 08-17-2006, 12:21 PM
BenDover's Avatar
search for postings by pclausen starting around april 18th
BenDover is offline
post #3 of 27 Old 08-17-2006, 12:26 PM - Thread Starter
ResOGlas's Avatar
I didn't see any posts he made with pics?
ResOGlas is offline
post #4 of 27 Old 08-17-2006, 12:41 PM
BenDover's Avatar
http://www.avsforum.com/avs-vb/searc...4&pp=30&page=2
click on that and start with his 4/15/06 post...
BenDover is offline
post #5 of 27 Old 08-17-2006, 12:47 PM
obie_fl's Avatar
Liked: 33
obie_fl is offline
post #6 of 27 Old 08-17-2006, 02:04 PM - Thread Starter
ResOGlas's Avatar
Ok, so it's using a 1GB DDR-333 PC2700 notebook memory module. Too bad there's only 1 slot for memory since 1GB is as large as they sell that memory.
http://www.cstone.net/~dk/hda1pcb.jpg
http://www.cstone.net/~dk/hda1ram.jpg
ResOGlas is offline
post #7 of 27 Old 08-17-2006, 11:16 PM
DIGITAL~DAN's Avatar
hey ResOGlas check out this video on the hda1 I found on the net
Click here to see the video.
DIGITAL~DAN is offline
post #8 of 27 Old 08-18-2006, 12:23 AM
RojasTKD's Avatar
Ummm... click where?
Apears to be no link.
RojasTKD is offline
post #9 of 27 Old 08-18-2006, 09:38 AM
Earlydoptr's Avatar
You didn't see it ? It was a subliminal flash video . There it goes again . The dog is saying "must watch HD DVD"
Earlydoptr is offline
post #10 of 27 Old 08-18-2006, 10:57 AM
Vasim Pathan's Avatar
so thats whats inside? how come the sucker weighs 25 pounds?
Vasim Pathan is offline
post #11 of 27 Old 08-18-2006, 11:36 AM
gsearles's Avatar
Home Theater Magazine also dissected one with some great pictures 1 or 2 months back.
Greg
gsearles is offline
post #12 of 27 Old 08-18-2006, 12:07 PM
lduguay's Avatar
Hmm, 25 pounds...Copper heat-pipe, aluminum heat sink and fans adds a bit of weight, but the bulk of the weight has to be the case.
lduguay is offline
post #13 of 27 Old 08-18-2006, 12:11 PM
lduguay's Avatar
Hey ResOGlas, i am curious why you would add memory to the A1. Like you said, there is no SODIMM DDR memory >1GB.
lduguay is offline
post #14 of 27 Old 08-18-2006, 03:00 PM
ascully's Avatar
Here is a link to the HTM article with pictures
http://hometheatermag.com/gearworks/806gear/
ascully is offline
post #15 of 27 Old 08-18-2006, 05:18 PM
Joe Q's Avatar
Thinking of messing with the Linux code on the USB Flash:)
Joe Q is offline
post #16 of 27 Old 08-18-2006, 05:22 PM
Q of BanditZ's Avatar
I wish I could upgrade that PC hardware... I'm just enough of a PC DIY'er that I feel that itch... ;)
Great ISF Job by Chad B.
Q of BanditZ is offline
post #17 of 27 Old 08-18-2006, 05:31 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
What would you do with more memory in a standalone player?:confused:
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #18 of 27 Old 08-18-2006, 05:41 PM
I would think it would yield you faster response and load times, for one...
post #19 of 27 Old 08-18-2006, 05:45 PM - Thread Starter
ResOGlas's Avatar
I was hoping that there would be an expansion slot or that the memory module wouldn't be the the best one available in that specific frequency. All in all I was just keeping my fingers crossed that there would be a way for us to upgrade our players and minimalize boot-up time.
ResOGlas is offline
post #20 of 27 Old 08-18-2006, 06:34 PM
angelo913's Avatar
Why? Is it swapping data from the USB Disk? I doubt it. This player has to only play one HD-DVD movie at a time, I would even think 1GB or ram is over kill for this task.
I think the bottleneck is the Flash BIOS chip as the USB 2.0 connection is fast. Anyone know the throughput of the chip used?
As for processor used it isn't a "regular" P4 it's based on the P4-M core that is more efficient per clock cycle and generates less heat than a regular P4. Therefore the 2.5Ghz P4-M with single-channel PC2700 will outperform a 2.5 P4 with dual-channel DDR PC3200. Also, the current Core-Dual is based on the P4-M core NOT the P4.
...Angelo
2x HD-XA2 firmware 3.0
1x HD-A1 firmware 3.0
HD DVD movies: 141
angelo913 is offline
post #21 of 27 Old 08-19-2006, 08:22 AM
lduguay's Avatar
The Flash module is made by M-Systems, a mModule uDoc (Disc on Chip)
It has a USB 2.0 interface and is able to boot Linux (and other OS)
It can read up to 13MB/sec and 7MB/Sec writing.
I am pretty sure this is part of the bottleneck. Any hard disk (SATA or IDE) now read at >50MB/sec.
Obviously, 2 GB of memory will certainly not improve the boot time.
lduguay is offline
post #22 of 27 Old 08-19-2006, 08:50 AM
lduguay's Avatar
Hmm, the mModule uDoc uses access control and data encryption with PKI. So messing around with the module itself is pretty much useless. I guess the easiest way would be to burn the appropriate code to a CD or by phishing the FTP stream , when upgrading the player from the maintenance menu. Then again, without the original source code, it could be an extremely complex task to rewrite custom code. If the original source code 'leaks' somewhere, then everything is possible. If the code was outsourced from China or India, it could showup sometime. ;)
lduguay is offline
post #23 of 27 Old 08-19-2006, 09:00 AM
lduguay's Avatar
If you want to wipe clean the mModule, check this out
http://www.m-sys.com/Files/download/...ot_Package.zip
Then flash your own code...
I guess you would buy another uDoc module and keep the original one is a safe store.
lduguay is offline
post #24 of 27 Old 08-19-2006, 09:07 AM
Joe Q's Avatar
You kind of lost me there.
The fellow that opened his machine took the USB module and plugged it into a PC.
It is running Linux and I saw no sign of any encryption as you can see in the enclosed link:
http://geekswithblogs.net/lorint/arc.../05/77332.aspx
Joe Q is offline
post #25 of 27 Old 08-19-2006, 09:17 AM
lduguay's Avatar
Good find Joe Q.
I guess Toshiba did not use any access control or encryption. I know the module itself is able to use PKI, probably for other uses, such as banking or other security devices.
lduguay is offline
post #26 of 27 Old 08-19-2006, 12:16 PM
angelo913's Avatar
Obviously, 2 GB of memory will certainly not improve the boot time. :confused:
It looks like the PCBA has room for another chip. If they used a "dual-channel" set or 2 chips in parallel it would double the throughput to 26MB/s Read and 14MB/s Write that would cut the boot-times in half and also reduce the Upgrade time too.
I think the BIOS/Flash chip "upgrade" would speed-up boot times more than anything else, since some people are making a fuss about it. But then you still have DVD/HD-DVD load-times that are slower than DVD Players. which is related to the HD-DVD drive.
In my conclusion for faster Booting & Loading is upgrading to a faster USB Disk and faster HD-DVD drive is required to get the "full" effect. ;)
...Angelo
HD DVD movies: 141
post #27 of 27 Old 08-20-2006, 09:34 AM
lduguay's Avatar
The HD-DVD NEC drive takes around 21 seconds for media recognition alone. Only a drive firmware upgrade could help speed-up things.
I think the 2 chips module is able to read at 20MB/sec peak (according to the specs)
lduguay is offline
Closed Thread HD DVD Players
