XBox 360 HD DVD Addon FAQ. Please posts questions here! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 652 Old 11-10-2006, 06:03 PM - Thread Starter
bkilian's Avatar
Originally Posted by Arya Stark View Post
has pal playback been confirmed?
PAL playback of what? For DVDs, since it's the 360 doing the playing, it'll play whatever your 360 can.
bkilian is offline
post #32 of 652 Old 11-10-2006, 06:39 PM
BLK 04's Avatar
Does anyone have link showing VGA can output 1080P. I thought max resolution for 360 was 1080i.
Dear BLK 04,
You have received a warning at AVS Forum.
Reason:
Signature Rule Violation
BLK 04 is offline
post #33 of 652 Old 11-10-2006, 06:50 PM
TheCHAMPisHere's Avatar
::In Borat Voice:: Very Nice!
TheCHAMPisHere is offline
post #34 of 652 Old 11-10-2006, 06:55 PM
gooki's Avatar
What about ICT?
If a disc has the ICT flag, it will be displayed in a degraded form over analog connections. No current HD DVDs have this flag, and the studios have mentioned that they do not have any plans to turn this flag on in the near future.
Might want to get confirmation on that. Last offical word i heard was that ICT flag had no effect on the VGA output - ie you still get full 1080P res.
Latest live update adds 1080p support to the xbox 360. FYI VGA can go even further if it wanted to.
International HDDVD Screenshot Archive (Full 1080p Images): www.hdmovies.co.nz
gooki is offline
post #35 of 652 Old 11-10-2006, 06:56 PM
BuGsArEtAsTy's Avatar
Quoted: 377 Post(s)
Liked: 167
That all changed with the last update. 1080p is now supported.
BuGsArEtAsTy is online now
post #36 of 652 Old 11-10-2006, 07:00 PM
gooki's Avatar
It may accept both resolutions, but your TV has a native resolution doesn't it?
CRTs don't have a native resolution. As per the psoters answer i would have bet on 1080i being the better looking image as 1080i does not reduce the quality of the image where as 720p is effected by down scalling.
gooki is offline
post #37 of 652 Old 11-10-2006, 07:01 PM
BLK 04's Avatar
awsome, thnx guys.
Dear BLK 04,
Reason:
BLK 04 is offline
post #38 of 652 Old 11-10-2006, 07:03 PM
apodaca's Avatar
What are the load times as compared to HD-A1 assuming both units start from power up.
The first gulp from the glass of natural sciences will turn you into an atheist, but at the bottom of the glass God is waiting for you.
-Werner Heisenberg
apodaca is offline
post #39 of 652 Old 11-10-2006, 07:36 PM
tclp's Avatar
Aparently Nvidia 'PureVideo' allows for playback of HD-DVD, mind you -- you need a supporting video card. Anyone happen to have both (MS HD DVD & Supporting video)
~T
tclp is offline
post #40 of 652 Old 11-10-2006, 07:49 PM
tclp's Avatar
apparently someone over at TheGreenButton.com has gotten it to work in Vista...
SUCCESS!!!
I re-installed the Japanese version I downloaded in September since Chris didnt seem to think that downloaded version wouldn't work. And low and behold everything works perfectly! I am watching an HD-DVD on my PC for the first time...
Setup was easy, just plugged the xbox hd-dvd drive in, XP found it quickly. It couldnt find an Xbox 360 HD-DVD Memory driver, but it doesnt appear to be needed.After the drive was connected I re-installed WinDVD 8 HD, rebooted and all is good with the world!
Thanks M$!!!
Charles
The japanese version (http://www.intervideo.co.jp/products/wd8p/) of WinDVD 8. I purchased it back in September when I pulled my HD-DVD drive out of my HD-A1, but was unsuccessful in getting it to work.
I am running XP MCE as there are no Nvidia Purevideo HD drivers out yet for Vista As soon as they are available I will be installing on another drive to try it out.
As Bryan mentioned you have to have a HDCP compliant video card, Nvidia Purevideo HD drivers, HD-DVD drive and software to run it. Unfortunately the HD-DVD drive has to be one supported by the WinDVD software, which the Toshiba is but the NEC is not.
Charles
P.S. I also have the blu-ray drive working with Cyberlink Powerdvd as Bryan mentioned above.
~T
tclp is offline
post #41 of 652 Old 11-10-2006, 07:53 PM
ShinHed's Avatar
I met all the credentials but, you still need HD-DVD playback software.
ShinHed is offline
post #42 of 652 Old 11-10-2006, 08:29 PM
Spiderman2006's Avatar
Local Sears, Wal-Mart and Gamestop don't have it? Will Best Buy have a big supply of them? I have to drive bout 50 miles to the nearest one.
Spiderman2006 is offline
post #43 of 652 Old 11-10-2006, 08:31 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 740
If you have compusa near you, go online and check their web site. They show what stock they have at different stores...
amirm is offline
post #44 of 652 Old 11-10-2006, 08:36 PM
tclp's Avatar
can you give the Japanese version of WinDVD 8 a try and let us know ?
~T
tclp is offline
post #45 of 652 Old 11-10-2006, 08:37 PM
vinodk's Avatar
Quoted: 87 Post(s)
Liked: 33
Anybody using X360 HD-DVD connected to Sammy HLS series dlp at 1080p? Sammy can accept 1080p via component. I am wondering if I can connect X360 to Sammy via either PC input or via component input with VGA to component breakout cable.
Vinod
vinodk is offline
post #46 of 652 Old 11-10-2006, 08:50 PM
ShinHed's Avatar
Unfortunately, there's no download link to the Japanese WinDVD 8. Only an update and older versions.
ShinHed is offline
post #47 of 652 Old 11-10-2006, 08:51 PM
venk's Avatar
My Local Best Buy told me they wont get them until the 17th. GRRRRRRR!!!!!! I need to go there since i've got about $60 in gift cards to spend and not much else to spend it on.
venk is offline
post #48 of 652 Old 11-10-2006, 08:53 PM
cliftonrouse's Avatar
I got mine from EB Games website. They are still shipping in 24hrs. You can get next day shipping for like $9.99 + Tax.
cliftonrouse is offline
post #49 of 652 Old 11-10-2006, 09:00 PM
knpm's Avatar
if you have a circuit city in your area, you can check online for availability and order one for in store pick up
hope you find one.
knpm
knpm is offline
post #50 of 652 Old 11-10-2006, 09:03 PM
Robert D's Avatar
How about the Target stores?
Robert D is offline
post #51 of 652 Old 11-10-2006, 09:07 PM
MidnightWatcher's Avatar
Quoted: 53 Post(s)
Liked: 27
Someone got it to work with the Japanese version..
http://thegreenbutton.com/forums/per...ad.aspx#148368
That's it, gotta get me one of these babies and upgrade my video card to HDCP
MidnightWatcher is offline
post #52 of 652 Old 11-10-2006, 09:12 PM
Robert D's Avatar
If the xBox player can be made to work on PC's imo Microsoft will sell millions of them.
Robert D is offline
post #53 of 652 Old 11-10-2006, 09:17 PM
tclp's Avatar
Robert,
The drives work just fine with PC's, it's just the software that is an issue (assuming you have supporting hardware). I just tried to buy one online BB Canada with a $25 off coupon (had to spend $250+, was ordering two hd-dvd movies and the xbox to make use of coupon) .... but I'm too late they aren't even taking orders anymore.
I've already seen/heard of tons of people buying them just because they want them for PC, but I do agree unless another company like LG/Toshiba/Sony/LiteOn/etc starts offering a 'desktop' drive for cheaper MS will sell a few extra million ontop of the millions that they will sell due to xbox owners
~T
tclp is offline
post #54 of 652 Old 11-10-2006, 09:24 PM
Robert D's Avatar
Amazon says they have two of them http://www.amazon.com/Xbox-360-HD-DV...8&s=videogames
Robert D is offline
post #55 of 652 Old 11-10-2006, 09:56 PM
candyrocket786's Avatar
Christ! The price of the Video Cards are as much as a 360 console.
360/ PS3 GamerTag : DVDVampire
HD-DVD: 181
Blu-Ray: 70
candyrocket786 is offline
post #56 of 652 Old 11-10-2006, 10:00 PM
Robert D's Avatar
Here is a HDMI HDCP video card for $140 http://www.newegg.com/Product/Produc...82E16814102032
Robert D is offline
post #57 of 652 Old 11-10-2006, 10:01 PM
Quoted: 53 Post(s)
Liked: 27
Some, yes, some are even more (for hardcore gamers), but some are MUCH less as well.
post #58 of 652 Old 11-10-2006, 10:14 PM
rdjam's Avatar
RESULT! Yes!
I saw someone on another thread also got the drive running with no work at all under Media Center.
However, he did not have HD DVD playback software installed.
He ran the POWERDVD (or somesuch) HD player test and it "passed" the add-on drive as a valid HD DVD player.
Sounds like it'll work fine and we'll probably have a poster here soon to that effect. Seems all you'll need is a decent graphics card capable of AVC decoding, and the playback software.
rdjam is offline
post #59 of 652 Old 11-10-2006, 10:17 PM
rdjam's Avatar
I like... I buy...
rdjam is offline
post #60 of 652 Old 11-10-2006, 10:26 PM
Originally Posted by rdjam View Post
RESULT! Yes!
Lets say I pickup the HDCP Card, Software and compliant display device.... am I still screwed because I'm running a P4 @3ghz with 1gig of RAM?
HD-DVD: 181
Blu-Ray: 70
Reply HD DVD Players
