XBox 360 HD DVD Addon FAQ. Please posts questions here! - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 652 Old 02-07-2008, 09:58 AM
98_formula's Avatar
hey,
I have the HD dvd player add on for my xbox 360, but i can't locate the startup disc, is there somewhere I can download the information needed or a way to get the disc... can i burn it from someone elses?
thanks in advance...
Tim
98_formula is offline
post #632 of 652 Old 02-07-2008, 11:18 AM
Deezul's Avatar
Quoted: 40 Post(s)
Liked: 29
If your HD DVD drive is connected to the 360 and you're connected to the Internet, it will update automagically. It's also on the Xbox.com website if you do not have the 360 connected.
Xbox 360: Deezul AwT
HDTV since 2004, 3D since 2011
Go Jackets!
Deezul is offline
post #633 of 652 Old 02-07-2008, 12:23 PM
98_formula's Avatar
thanks, this will work even if its the first time i hook up the hd player to the 360?
post #634 of 652 Old 02-07-2008, 12:49 PM
Flavius's Avatar
Liked: 46
YES
Flavius is offline
post #635 of 652 Old 02-08-2008, 02:40 PM
plastikpyro's Avatar
i'm still not clear on this but if i have an elite with hdmi does the player still play movies in 1080i or 1080p? from my understanding the image constraint token prevents the movie from running in full 1080p because its being passed through usb correct?
plastikpyro is offline
post #636 of 652 Old 02-08-2008, 02:56 PM
NormanB123's Avatar
If you have a 360 with HDMI and your TV accepts 1080p then you are good to go with 1080p. The ICT relates to analog outputs like component and limits output resolution to something like 540. The ICT has no effect on digital connections.
NormanB123 is offline
post #637 of 652 Old 03-05-2008, 04:01 PM
GrindheadJim's Avatar
It stretches EVERYTHING ELSE! Settings are the same across the board.
WTH?!
\m/ Grind On \m/,
Jim
"Harmony can only flourish with mutual regard."
-Mark "Barney" Greenway, 1992
GrindheadJim is offline
post #638 of 652 Old 03-05-2008, 07:13 PM
Deezul's Avatar
Quoted: 40 Post(s)
Liked: 29
WTH?!
I know with my TV, in SD I have about 5 or 6 stretch settings. But in HD, I have only 2 choices - no stretch, and stretch. You might want to find a thread dedicated to your particular HDTV and ask there.
Go Jackets!
Deezul is offline
post #639 of 652 Old 07-24-2008, 04:49 PM
Bigsierra's Avatar
Has anyone had a problem with the image going to a white staticy screen for a second, then coming back? The sound keeps going fine though. I thought it might be the usb cord being too close to the power brick and moved it, but the issue still happens.
Bigsierra is offline
post #640 of 652 Old 07-25-2008, 12:12 PM
cdzie1's Avatar
Anyone know if the Xbox HD DVD player will work with the “New Xbox Experience” coming this fall?
I assume it will, but has there been confirmation?
cdzie1 is offline
post #641 of 652 Old 08-14-2008, 10:39 PM
Andy Pennell's Avatar
Originally Posted by cdzie1 View Post
Anyone know if the Xbox HD DVD player will work with the New Xbox Experience coming this fall?
I have no actual knowledge one way or the other, but it would be monumentally stupid if they disabled HD DVD playback.
HD DVD Veteran
Andy Pennell is offline
post #642 of 652 Old 08-14-2008, 10:40 PM
More critically no titles have ICT set (except a couple of Euro titles that did it accidentally).
HD DVD Veteran
post #643 of 652 Old 12-22-2008, 11:58 AM
Sundance's Avatar
8800 yen = about US$97, that is a lot of money for a program that (from reading here) almost works???
Sundance is offline
post #644 of 652 Old 01-12-2009, 02:31 PM
requiemforchaos's Avatar
Hello all.
I got an elite for christmas to replace my busted 20g pro which the hd-dvd addon worked just fine on. Now though, I can't seem to get to work on the new elite that I got. It works on the PC just fine so I know the drive is still functioning. When I plug it in the 360 slows to a crawl, the menus take forever to go away and the whole thing seems really bogged down. Then when I try to update it, it says it can't update it. It shows up in the My Xbox menu but not on the system memory menu so I can't clear the cache or anything for it either. I am clueless now, I have tried just about everything but still no go, even tried on my roommates brand new elite and the same thing happens. Any idea on what I should do? All help would greatly be appreciated. Thank you all for your time.
requiemforchaos is offline
post #645 of 652 Old 01-12-2009, 07:07 PM
Deezul's Avatar
Quoted: 40 Post(s)
Liked: 29
Originally Posted by requiemforchaos View Post
Hello all.
It works just fine on my Elite. Have you tried running the update without the HD DVD drive plugged in?
Go Jackets!
Deezul is offline
post #646 of 652 Old 01-13-2009, 10:06 AM
Nope, I haven't tried that. The install disk always asks me to plug it in, are you saying I should ignore it and just let it run?
When I put a dvd in the drive it plays the dvd. When I put an HDDVD in the drive it says "Can't connect to HD-DVD drive" and shoots me back to the dashboard. It's a little frustrating but thanks for your response.
post #647 of 652 Old 01-13-2009, 10:20 AM
Deezul's Avatar
Quoted: 40 Post(s)
Liked: 29
Are you running the update from a disc or view the Internet automatic update? If you're running into problems updating the HD DVD on two different 360s, I'd say the drive itself is bad.
Go Jackets!
Deezul is offline
post #648 of 652 Old 01-13-2009, 12:39 PM
I can't do either. When I download the update from the website, there's only one file and when placed in the dvd drive, it says Mixed Media Disc and does nothing when I try to play it. I can't update it through the Internet because it says it can't connect the Hd-Dvd drive.
I would say the drive is bad too but when I hook it up to my laptop, it works flawlessly.
Thanks again for trying to help, I really do appreciate it.
post #649 of 652 Old 01-13-2009, 05:30 PM
Deezul's Avatar
Quoted: 40 Post(s)
Liked: 29
I think the file you download is an ISO, so you might have to use something to burn an ISO. But I could be wrong. I can't think of anything else, unfortunately.
Go Jackets!
Deezul is offline
post #650 of 652 Old 01-14-2009, 12:58 PM
I've tried everything and still no go so I give up. Thanks for suggesting helpful things though. If I ever get it working, I'll post just how I did it but it is not looking too likely.
post #651 of 652 Old 01-14-2009, 01:33 PM
Davinleeds's Avatar
Did you try the install disk that came with the drive or did I miss that? Yup. I did. Wasn't there a particular sequence? Will see if I still have paperwork.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #652 of 652 Old 01-16-2009, 04:49 PM
Caffinetron's Avatar
Hi all,
I am new to this forum site because i am also having issues with my HDDVD addon. I have tried all things that i know of to get it to work (not connected to internet, connected to internet, deleting all memory, re-installing the driver etc) but everytime i put in a disc to watch it comes up with "disc unplayable". I have had the addon since Feb last year so it is still under warranty. I have watched movies on it but ever since the NXE update came along it has not worked. What is the update that you guys are talking about in the last couple of replies (NXE update?) or is there an update for the HDDVD addon that i don't know about? Any help would be much appreciated. Thanks
Caffinetron is offline
Reply HD DVD Players
