one and only 360 HD-DVD Drive thread & LINKS - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 2184 Old 11-10-2006, 06:14 AM
zero the hero's Avatar
I thought it looked great, but in some areas it seemed the whites were exaggerated - like sunlight is so bright you almost have to avert your eyes
I havent tried VGA yet though.
zero the hero is offline
post #32 of 2184 Old 11-10-2006, 06:15 AM
nataraj's Avatar
Originally Posted by Technicolor View Post
Unless you want the Xbox for playing, wouldn't it be better to just to buy the A2?
Depends. 1080p vs TruHD.
nataraj is offline
post #33 of 2184 Old 11-10-2006, 06:19 AM
BuGsArEtAsTy's Avatar
Quoted: 386 Post(s)
Liked: 170
Originally Posted by Htdude14 View Post
Most of us!!! Why pay more for 360 and add-on(clunky 2-piece setup) and no Dolby TrueHD when the PS3 has HDMI and is cheaper?? In your case, having the 360 consoles already, it makes sense.
BTW, way to buy your love
Well, I bought my Xbox 360 a very long time ago. Getting the Xbox 360 HD DVD drive is complete no-brainer, esp. since it's only US$177 with remote and King Kong.
HDMI is a definite advantage, or at least it would be in 2 years when I get a new TV, but in the meantime it's no biggie for me since I can only use component anyway.
BuGsArEtAsTy is offline
post #34 of 2184 Old 11-10-2006, 06:38 AM
HorrorScope's Avatar
Originally Posted by Hank527 View Post
Hello,
I have not been posting to frequently, but got this last night. I can say it is very easy to set up but maybe I am missing something because I think it is strange to have to plug into one of the front USB units on the Xbox 360 and the HD DVD then has 2 USB ports on the rear of its unit.
Anyway I hooked it up put it up via component to my sony SXRD. The power up is instant 1-2 seconds. I put in the disc and its probably under 10 - 20 seconds max unitl I see the universal logo all good.
Now the bad news maybe is it King Kong or the Xbox 360 or the SXRD. Watching King Kong looked very impressive HD unfortunately reveals many scenes that look fake or overly CGI ie the backgrounds on the dinosaur fight look CGI and almost have a different brightness to them (this might be the sxrd?) Anyway the only - on the HD DVD drive was that about once in every ten minutes or so a saw a brief hiccup where it seemed the disc might have stuttered so very slightly. Or is this the TV trying to keep up?
Need fellow users opinions. All in all for $200 and my 2nd HD-DVD I am very pleased . The downside seems to be all in that this will not do Dolby True HD. The upside is for the movie studious because this 2nd Hd-DVD drive is in the room where the kids watch TV so all Family Hd-DVDs will now be purchased for the kiddies. (cough cough Disney get on the ball)
Oh and the features/ menu functions are a tad different than the toshiba
My guess on the stutter is the 24 to 60 hz jitter, only a guess and I can believe it with Kong looking that way.
HorrorScope is offline
post #35 of 2184 Old 11-10-2006, 06:44 AM
Originally Posted by Paul Cordingley View Post
I really don't get this North American attitude. You buy it - you keep it. Why the complication?
Well first there is only a 3rd option you return it. If that seems like major complication then well I dunno what to say for that. It's called customer satisfaction, imo it's a good thing for the consumer. Saying that, I rarely return things and I bet that is the same for most of us. But imo it's a good option and protection for us. Nothing to hard to understand about that, if you don't have it, you should ask for it and want it! It's an awesome feature better then HD!!!
post #36 of 2184 Old 11-10-2006, 06:51 AM
FreeBaGeL's Avatar
Originally Posted by LAGOSIAN View Post
Who cares much about TrueHD? All I care about is that it has Dolby 5.1 Plus.
I already have that on my HD-A1. I bought it for my son for use on his 42" plaz.
Surprised no one has mentioned this yet, but I'm pretty sure you can't get that DD+ that is "all you care about" out of optical/coax either..
XBL & PSN: Vcize
Hit me up on XBL if you're going to be playing CoD Ghosts or the PS Vita
FreeBaGeL is offline
post #37 of 2184 Old 11-10-2006, 06:53 AM
cdub998's Avatar
Looks bigger then the PS3 to me, let's not forget the add-on is a paper weight without the 360 itself. If you're comparing then compare the entire unit.
Not true. It recognizes on the PC. There just isn't a player yet for HD-DVD on the PC. It will work soon enough.
Xbox 360 gamertag: Cdub998
PSN: cdub998
cdub998 is offline
post #38 of 2184 Old 11-10-2006, 06:56 AM
Quoted: 386 Post(s)
Liked: 170
Correct. The Xbox 360 can decode both TrueHD and DD+, but it can output neither over optical/coax. Both are re-encoded to 640 Kbps DD5.1 for output over optical/coax.
post #39 of 2184 Old 11-10-2006, 07:01 AM
ryoohki's Avatar
No, there's an issue with Ucontrol and the Xbox360 it seems, other all movies would have done that...
89+ Blu-ray Disc ;)
ryoohki is offline
post #40 of 2184 Old 11-10-2006, 07:12 AM
Ok. Good to know, thanks.
post #41 of 2184 Old 11-10-2006, 07:48 AM
mimason's Avatar
Does the 360 stil run loud and hot while using the HD-drive?
mimason is offline
post #42 of 2184 Old 11-10-2006, 07:54 AM
JWLou's Avatar
As far as easily detecting the CGI - I would say there is nothing wrong with your TV, the 360 add-on, or the connection type you are using. People tend to forget that CGI isn't used because it "looks better" - it is used because it is a relatively cheap alternative to creating hard shots or in this case impossible shots (since there are no more T(or V i suppose)Rexs OR giant gorillias. HD-DVD will certainly bring out the detail which may cause things to be a little more fake but that is the nature of adding detail - you notice more things.
Glad to hear the drive worked pretty well. Tis a good day for HD-DVD!
JWLou is offline
post #43 of 2184 Old 11-10-2006, 08:03 AM
Hank527's Avatar
The 360 runs the same as before.
I've been reading lots of posts, but thats it. No comments I'm pro HD-DVD because of development costs and costs to us as end consumers. Really $40 for fox titles is soso Laserdisc pricing and prohibits many from buying blind. Which reduces sales on ebay
Yes I did have the wireless controller so that is why I didn't see it. Plus I hokked it up in a tight spot. Thats another plus then. I didn't put 2 and 2 together pull the TV out and disconect the wireless adaptor.
I used the myscenes special feature which worked flawless today. I booked marked some scenes for the kids and they used myscenes without a hitch.
Another - is when using myscenes it takes a good 5-10 seconds to start the movie from your bookmarked scenes.
Comparison with the Toshiba is difficult because I'm using 2 different setups. I love Dolby True HD and firmware 2.0 is great. Plus I only evaluated King Kong and not a standard DVD which I love the Toshiba's upconversion. I give the HD-DVD add on drive an A. Considering you get a $20 - 25 movie with it is a + plus the remote control(but most of us have that anyway). Its my second HD-DVD drive and yes I do want a 3rd. I'm really impressed for now.
I think the drive is a great secondary unit and a good primary unit. If you want something great you need Dolby True HD and probably want faster load times as well. So it looks like the new Toshiba maybe the best drive
I was lucky in the order, but I've always been lucky when it comes to killin' folk - Unforgiven cannot wait for the hd-dvd of this gem
Hank527 is offline
post #44 of 2184 Old 11-10-2006, 09:00 AM
Chris Rein's Avatar
Faster load times? The 360 trounces the A1 that I had in load times.
So far I am really pleased with the quality of the image from this puppy. Microsoft has really gone above and beyond to make the 360 a true entertainment center. I haven't watched Kong yet, but have sampled a few other discs. No hitches, problems, whatever. All good stuff!
Chris Rein is offline
post #45 of 2184 Old 11-10-2006, 09:04 AM
Chris Rein's Avatar
No. Actually the opposite. The add-on drive is quiet. The 360 is really doing nothing but processing, and it doesn't crank up the fans, drive, etc which makes the 360 noisy as it does when playing a game.
Funny, the remote that came with it is fully backlit. Something that the other big boys don't even do, like the A1. I know, I know, it's a remote and we all have our fancy universal remotes, but I just wanted to point it out as most reviews get dinged on a shoddy remote.
post #46 of 2184 Old 11-10-2006, 10:25 AM
Quoted: 386 Post(s)
Liked: 170
I don't own an A1, but I tried the remote in-store, it seemed almost that Toshiba was trying to compete with the cheap Chinese DVD players for the worst remote award.
Glad to hear the Xbox 360 remote is half decent. I use a Logitech Harmony Xbox 360 remote though.
post #47 of 2184 Old 11-10-2006, 10:48 AM
Htdude14's Avatar
And a pc being smaller??? Point is the add-on and the 360 or a pc is large and 2 piece compared to the PS3.
Htdude14 is offline
post #48 of 2184 Old 11-10-2006, 11:12 AM
Quoted: 386 Post(s)
Liked: 170
Actually, you can get a PC with a dual-core CPU and DVI that's even smaller than the add-on drive itself. In fact, when the Santa Rosa chipset small form factor machines come out in 2007 with fast Core 2 Duo CPUs and HDCP support, that's gonna be perfect for this drive.
However, size is not the issue here anyways. If someone wants to share his/her HD DVD drive between an Xbox 360 and (eventually) a PC, it makes sense to do it, all for the low price of $200 (plus $40? for the playback software).
post #49 of 2184 Old 11-10-2006, 11:25 AM
c.kingsley's Avatar
Quoted: 197 Post(s)
Liked: 372
I saw Kong at a digital projection cinema, and I noticed this same issue. So it is not your TV. IMO the whole dinosaur scene should have been removed. It looked terribly fake.
c.kingsley is offline
post #50 of 2184 Old 11-10-2006, 11:27 AM
eXgo's Avatar
-the cgi -
they look fake, umm cuz maybe they are fake.
So Far... So Good... So What!
Unlock Your Samsung PNxxD550 series 5 plasma to achieve Expert 10 point Calibration and Expert Patterns. http://www.avsforum.com/avs-vb/showthread.php?t=1339743
eXgo is offline
post #51 of 2184 Old 11-10-2006, 11:31 AM
Hank527's Avatar
Sorry about that the noise its the same as playing an xbox live game. No disc spinning in the Xbox
Hank527 is offline
post #52 of 2184 Old 11-10-2006, 11:34 AM
emmonsh's Avatar
Quoted: 18 Post(s)
my 360 from oct 2005 doesnt run hot or loud. a heck of a lot quiter than my computer, by far.
emmonsh is offline
post #53 of 2184 Old 11-10-2006, 12:19 PM
cstmstyle's Avatar
Quoted: 14 Post(s)
Will be using it for games too but more for the media extender capability. I'll buy a standalone player during the 3rd or 4th gen.
Xbox Live- DragonsLee
"I'm not in this world to live up to your expectations and you're not in this world to live up to mine." - Bruce Lee
cstmstyle is offline
post #54 of 2184 Old 11-10-2006, 12:19 PM
blackmax2k1's Avatar
He meant the A2 not the A1. Everybody knows the 360 and A2 have faster load times than the 1st Gen A1.
blackmax2k1 is offline
post #55 of 2184 Old 11-10-2006, 12:22 PM
Jinx's Avatar
Hahaha i find it amusing.. Now there's complaints about movies looking to fake becuase the detail is soo good you can actually tell now.. its almost like you wana go back to DVD..
next people will complain porn is TOO gross in HD becusae you never saw all the details before!
Would you actually go back to DVD to make those computer gen'd scenes look more realistic (blurry)?
Jinx is offline
post #56 of 2184 Old 11-10-2006, 12:23 PM
WirelessGuru's Avatar
How are you getting DD+ from your 360 HD-DVD add on. Without HDMI or Multichannel analog, the DD+ soundtrack is being downsampled to 640 kbps DD bitstream. Hardly the same as DD+.
Edit: Duh, I guess I should read ALL the posts before posting. It looks like this information was already covered.
No offense, the 360 HD-DVD add on is a great value. But saying it is equal to the standalone players is misleading.
Last Watched 3D: Oz the Great and Powerful
It should be called Violet-Ray
WirelessGuru is offline
post #57 of 2184 Old 11-10-2006, 12:43 PM
DarthJedi's Avatar
Guys! I just recieved my pre-ordered 5 HD DVD drives for the Xbox today!
I opened the box and was simply amazed!
Quickly plugged it in, and put in MI-III after the upgrade disc had finished its job and voila! It is every bit as spectacular as my HD DVD standalone!
They definately have a winner here. I'm gonna have the best presents for Xmas.
I have taken the liberty of posting links that would better explain my first impressions...good reading!
http://xbox360.themanroom.com/news.php?id=1360
This link shows you the actual size as compared to the HD-A1 and the PS3, this baby is small!http://www.engadget.com/2006/11/09/x...-dvd-hands-on/
I thought I was greedy with my 3.
May HD be with you always
DarthJedi
XBOX LIVE: ForceFields
DarthJedi is offline
post #58 of 2184 Old 11-10-2006, 12:46 PM
Hank527's Avatar
I soo want to see a porn in HD
In the older titles you'll probably see herpes and sores you didn't see before
No I think its just King Kong the film look in the theatre masked its imperfections. Now you've eliminated the haze with most film and it looks different. Some shots look incredible other well look fake. Its a great title to include, but I would have like to have seen Harry Potter 4 or something like that to show off HD. Kong doesn't do HD justice except the first boring 45 minutes
Hank527 is offline
post #59 of 2184 Old 11-10-2006, 12:47 PM
rexdigital's Avatar
Quoted: 30 Post(s)
Liked: 25
Thats true right now!
rexdigital is offline
post #60 of 2184 Old 11-10-2006, 12:55 PM
DarthJedi's Avatar
Well Well......it looks like we have a spoil sport here. The add-on is more versatile than the Blu-Ray in the PS3 which is not even out yet. I can use it on a pc currently(read cd/dvd only right now) and when Windvd 8 HD-DVD addition comes out; I will be able to watch HD-DVD cheaper than buying an external Blu-Ray drive. Just get over it. HD-DVD is here to stay.
DarthJedi
Reply HD DVD Players
