Swapping Tosh drive for the Add-on drive... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-25-2006, 01:48 AM - Thread Starter
rover2002's Avatar
Is this possible? Could i pull out the NEC drive in the tosh & put in the Tosh drive from the Add-on, or would the drivers on the Tosh drive throw a fit?
ta.
rover2002 is offline
post #2 of 16 Old 11-25-2006, 04:00 AM
UxiSXRD's Avatar
Try it and let us know.
The service manual for the HD-A1 mentions needing an encryption code or some such...
-- "No matter where you go, there you are."
SXRD/Denon/Polk/PS3/360/WiiU
Blu-ray bliss
SXRD Owner's Thread
PSN: Uxi
UxiSXRD is offline
post #3 of 16 Old 11-25-2006, 09:53 AM
RAFABAMAD's Avatar
I would like to know the answer to this as well. Would someone who has both please try this? If the result was positive, I would happily buy the add-on.
Robert
RAFABAMAD is offline
post #4 of 16 Old 11-25-2006, 01:02 PM
RAFABAMAD's Avatar
From what I've read, it's faster and has better error correction to start with. According to the add-on owners poll, these guys have both. One of them has got to be curious enough to try it. Please?
DVD add on drive/s and standalone player/s
arlrch, AZHTGeek, b.ramos, BassTek, BenDover, Blasst, Blippy2005, BLK 04, bobgpsr, bruce can, calikarim, candyrocket786, CaptDS9E, Category 5, Chako, Cichlid, cws_kahuna, DaBigKahuna, dago2727, darinp2, Darkmatter, DarthJedi, dauthum, denile, Desert Heat, directorpaul, DJWikiera, DocX, Dwight2001, efranzen, Ezra, Farris214, Forest Fan, gas_leak, GizmoDVD, Glen911, gt9450, hammer99, hmuller, HomerJay, huntaar, jay07059, Jeff Williams, John Welch, Jonathan Hickey, JonMarsh, justmeandher, kiomon, kiwichev, MadPerry, madpoet, mimason, nataraj, NavNucST3, Norgoth, Packman1999, paulbh, pedra12, puddy77, Rasczak, rdjam, Reedy, RickW, Ron Lee, Rouser, rudyusmc1980, rxman, shine5555, SOWK, Soycrema, species_8472, stacks42, StrykerSTI, talman, tdhps1, tivodoctor, tmackie, tomr, TomsHT, trgraphics, Vasim Pathan, vwbeetlvr, wewantflair, WiFi-Spy, Wilda, winstonb, xue891
Robert
post #5 of 16 Old 11-25-2006, 01:11 PM
homerx's Avatar
I don't think it would work as the software is depend on the drive. If it does work it would only work as hard as the software would allow so I don't think it would work any better.
It may be worth a try, but if the new drive hurt the toshibias software you may be out 400 bucks for a player. I'd not even try. My A1 works perfect with very little flaws. I will get the HD add on but don't plan on doing that.
Would the cabling be the same?
homerx is offline
post #6 of 16 Old 11-25-2006, 10:10 PM
azmodien's Avatar
I think the A1 load times are mostly hindered by the processing hardware and not the ROM drive.
azmodien is offline
post #7 of 16 Old 11-25-2006, 11:38 PM
UxiSXRD's Avatar
That was the generally opposite conclusion in the A1/XA1 service manual thread, which put most of the blame on the drive IIRC.
Blu-ray bliss
SXRD Owner's Thread
PSN: Uxi
UxiSXRD is offline
post #8 of 16 Old 11-26-2006, 12:03 AM
Kosty's Avatar
It would probably work if you had the right software driver but that would have to be already installed into the firmware, on the silicon already or somehow flashed there.
You never know, its Toshiba firmware and the 360 HD DVD addon is a Toshiba drive (the drive in the HDA1 was a NEC) maybe the 2.0 firmware has a generic Toshiba HD DVD driver in it?
It would be fun if it worked. I'd put the odds at 10% or less.
"A lot of good arguments are spoiled by some fool who knows what he is talking about." - Miguel de Unamuno
follow me on Twitter
Kosty is offline
post #9 of 16 Old 11-26-2006, 11:00 AM
PeterS's Avatar
Quoted: 124 Post(s)
Liked: 41
Don't know about that. I would guess it would indeed work.
Yes, the speed of the original HD-A1 is due to the drive primarily.
The HD-A1 is more of a general purpose PC than a CE device. I would assume they developed it to accepts whatever drive was ready when they were.
The HD-A2, coming in a couple weeks, uses the new drive - same as the Xbox 360 add-on.
What the dirves do is almost identical. Very interested if this indeed works, but would not be surprised.
"Read Less, More TV." - Dr. Gregory House
"That which can not be questioned, can not be trusted." - Me
The Metropolis Home Theater
Blue Smoke Entertainment Systems - Affiliated
PeterS is offline
post #10 of 16 Old 11-26-2006, 12:56 PM
bobgpsr's Avatar
I'll bet not.
As post #2 on this thread mention the service manual says you have to contact Toshiba for a new AACS encryption number when you change/replace the drive - even with the exact same part. More like a ethernet MAC number than anything else -- except the number must be exactly right for the individual drive
Bob
bobgpsr is offline
post #11 of 16 Old 11-26-2006, 06:00 PM
Blkout's Avatar
Correct.
Blkout is offline
post #12 of 16 Old 11-26-2006, 06:01 PM
Blkout's Avatar
Incorrect.
Blkout is offline
post #13 of 16 Old 11-26-2006, 06:36 PM
UxiSXRD's Avatar
You've stated your opinion. Now offer some corrobration for your conclusion...
Blu-ray bliss
SXRD Owner's Thread
PSN: Uxi
UxiSXRD is offline
post #14 of 16 Old 11-26-2006, 08:50 PM
ShagMan's Avatar
The load time for the HD-A1 is certainly NOT the drive. For one thing, the boot time and the disc load time is mostly with the drive NOT spinning... just listen to it, sheesh.
...On swapping the drive from the add-on, that would be a no go just because there's no way to mount the drive at all. I've taken apart my add-on, and it's a "chunk" of metal and not a standard laptop or 5.25" format case.
Just think about it, it looks like a laptop drive, but it's motorized, that should tell you it's a bastard chunk of hardware by itself.
-Josh Murrah
ShagMan is offline
post #15 of 16 Old 01-12-2007, 11:35 PM
williamtassone's Avatar
dumb question, but what are those USB ports for on the XA1??
Could a 360 add on work as a drive for skipping first gen units connected by USB?
williamtassone is offline
post #16 of 16 Old 01-13-2007, 07:47 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
I want to know about those USB ports too! On the RCA's rebadged version of the HD-A1, they label them as "game port".
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is online now
Reply HD DVD Players
