HD-A1 Multichannel Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-05-2006, 10:39 AM - Thread Starter
Rare1's Avatar
Last night I tried to hook up my HD-A1 with the 5.1 analogs. I hooked them directly to the Onkyo (TX-SR602) multi-channel in with some monoprice cables.
I tried the test tone option within the HD-A1 and ALL of the speaker tones came out of the center speaker.
Everything works fine with optical but this is my first experience with multichannel.
Are there any options within the A1 I need to change to make this output correctly?
Any ideas????
Rare1 is offline
post #2 of 10 Old 12-05-2006, 10:43 AM
JOHNnDENVER's Avatar
It is well doccumented that the A1's internal test tones do not work.
Your best bet is to find an SD-DVD that has the THX optimizer on it and use those test tones as they work like a champ.
JOHNnDENVER is offline
post #3 of 10 Old 12-05-2006, 10:45 AM - Thread Starter
Rare1's Avatar
Excellent, I shall try this tonight.
Thanks for the fast response :cool:
Rare1 is offline
post #4 of 10 Old 12-05-2006, 10:47 AM
Your welcome and it will fix you right up. :)
post #5 of 10 Old 12-05-2006, 11:39 AM
slider33's Avatar
Are you sure the tones are coming out only the center? If you have the receiver set to analog (instead of analog 5.1 multi), they'll come out the front three, but not the surrounds. If it's only coming out the center, something is off.
slider33 is offline
post #6 of 10 Old 12-05-2006, 11:53 AM - Thread Starter
Rare1's Avatar
Yup, all the tones came out of the center. It was very strange.
Rare1 is offline
post #7 of 10 Old 12-05-2006, 12:21 PM
Have you updated yoru firmware?
Update firmware, verify proper operation with the THX optimizer.
Hard to imagine there could actually be something wrong with the A1 causing this.
Re-check your 5.1 cables at the AVR, many are confusing and it's easy to not have it hooked up correctly.
post #8 of 10 Old 12-05-2006, 12:21 PM
slider33's Avatar
What firmware is the A1? I have only heard the tones at 2.0 firmware, and although they did come out the different speakers, they still weren't right. Maybe before 2.0 they only come out the center?
slider33 is offline
post #9 of 10 Old 12-05-2006, 12:27 PM - Thread Starter
Rare1's Avatar
2.0 Firmware, I can test the thx optimizer tonight when I get home and post my findings.
Rare1 is offline
post #10 of 10 Old 12-05-2006, 04:31 PM - Thread Starter
Rare1's Avatar
Looks like it is working now. I tried the thx optimizer and all is well.
Thanks for the help.
Rare1 is offline
Closed Thread HD DVD Players
