Tosh HD-A2 HD DVD - First End User Reports! - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 12-09-2006, 04:48 PM
bfdtv's Avatar
I wonder if it'll be like the PS3's DTS-HD decoding or if it will be the rumored MA upgrade that the PS3 may wind up getting...
The PS3 doesn't do any DTS-HD decoding at this time. The PS3 only decodes the DTS "core" -- which is exactly what the Toshiba HD-A2 does now.
Both the A2/XA2 and PS3 will get DTS-HD decoding in early 2007.
bfdtv is offline
Old 12-09-2006, 04:56 PM
kanefsky's Avatar
Originally Posted by MichaelZ View Post
The differences you will see with HD sources on a 61" is going to be small compared to the differences you would see on a 110" screen. There is a night and day difference. Some broadcast HD is very, very good but most is not quite as good as it should be due to multiplexing at the local station or if it is one of the satellite vendors. I have a descent plasma but it can't touch my PJ, you can see MB, dithering and a lot more artifacts, unless you sit 3-4 feet from your tv! So there is a difference, just depends on what monitor you have.
You can see just as many differences on a 61" display if you're sitting closer. It's about angle of view, not screen size. There are 30" desktop monitors with twice the resolution of a 1080p front projector driving a 110" screen. There's also no difference in resolution between broadcast HDTV and HD-DVD. The only differences (given the same source material) would come from one of them having more compression artifacts than the other. You can easily see that during fast-moving scenes, but during slow-moving scenes where the bitrate is not an issue, there is very little if any difference in quality.
The big difference comes from watching a bad transfer versus a good one. A bad transfer on HD-DVD looks much worse than a good transfer on broadcast HDTV.
Steve
kanefsky is offline
Old 12-09-2006, 04:57 PM
bfdtv's Avatar
First, as others have said, the build quality is nowhere near the A1.
Internally the build quality of the A2 far exceeds the A1. It's these internals that determine performance and reliability, not the external case.
It is faster than the A1, although the A1 really didn't bother me in regards to speed. The major issue I am having is camera panning is not smooth at all. It's noticably jaggey and annoying to watch.
I assume you have the HD-A2 set to 1080i, as everyone should. From what you are describing, it sounds like the video processing in your TV is poor. Or perhaps there is some cinemotion type setting on your display that you must enable/disable?
bfdtv is offline
Old 12-09-2006, 05:03 PM
joffer's Avatar
Originally Posted by gene9p View Post
the xa2 still requires an hdmi receiver or one with analog inputs for all speakers...it wil not pass dd+, dts hd, or dolby true through the digtal outputs
no HDDVD or BD player will
"Why am I Mr. Pink?"
joffer is offline
Old 12-09-2006, 05:41 PM
derekjsmith's Avatar
Liked: 116
Originally Posted by derekjsmith View Post
Does the A2 have a auto native resolution option? What about 480i over HDMI?
All I want it to do is just output what is on the disk and let my VP do all of the work.
Yes it does 480i over HDMI
No it does not have a auto resolution option and to make it even harder you now have to go into setup to change the output res, so close
Toshiba if you are listening please add a auto max resolution option for each disk type SD, HD etc...
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
Old 12-09-2006, 05:58 PM
kanefsky's Avatar
So if you choose 480i for SD-DVD then you also get 480i for HD-DVD until you go into the menu and change it back?
Steve
kanefsky is offline
Old 12-09-2006, 06:10 PM
lastxbr960's Avatar
Originally Posted by nred1 View Post
I am new to HD players but have had a oppo 971 for some time and have been very happy with it.
I wanted to jump into HD for a reasonable cost and the Toshiba was right up my alley. My intention was to replace the Oppo entirely and use the Toshiba for all of my SD DVD's but I am now concerned.
I have the Silicon Optix HQV test disk (evaluates video processing) that I used on the Toshiba, set to output 720p via HDMI into my panasonic 58" 600u plasma and it failed every test while the Oppo via DVI passes with flying colors.
I did not expect this, as everybody has always regarded the Toshiba HD-DVD players as excellent SD players.
Am I missing something?
Do I need a dedicated SD player? or Do I need a stand alone Video processor.
Will setting the output from the toshiba for SD discs to 480i/p help?
any advice will be greatly appreciated.
HD looks amazing, watching Superman returns as we speak!!
Benchmarks are just that ,"benchmarks".
Usually just for a specific function that may be very rarely found or noticed in real world use.
Sometimes the product that benchmarks lower is prefered in real world use(sportscar/family car).
What matters is how it looks to you.
Which upconverts best in your opinion and at what res, try all three 1080i, 720P, 480P?
Enjoy!
lastxbr960 is offline
Old 12-09-2006, 06:36 PM
tsb
tsb's Avatar
What's your source? How about the A1/XA1?
tsb is offline
Old 12-09-2006, 06:46 PM
tsb
tsb's Avatar
Anyone try to take out the A2s drive and put it in the A1 yet?
tsb is offline
Old 12-09-2006, 07:24 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
TSB, it can't be done. You need a specia code when you install a drive. I saw this in the service manual.
rwestley is offline
Old 12-09-2006, 07:43 PM
ac388's Avatar
Quoted: 79 Post(s)
Liked: 26
Does the A2 come with a Toslink cable ?
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
Old 12-09-2006, 07:45 PM
dtsfanoh's Avatar
FWIW, I can't play Nemo either on my A2. It says cant play disc/check disc...
dtsfanoh is offline
Old 12-09-2006, 07:48 PM
lynx's Avatar
Nope.
lynx is offline
Old 12-09-2006, 08:00 PM
J y E 4Ever's Avatar
Liked: 40
Okeedokee, done deal.
XA2 for $899.00 with free 4yr extended warranty plus $14.99 shipping.
I called them and asked if I could pick it up because I lived in the next town over and they said no problem so I saved on the shipping and I receive the product faster, win win if you ask me!
I am so excited especially being Christmas and all! Speaking of which, I want to thank the AVS forum for their early Christmas gift to me which was advising me that VE existed right under my nose (like 15 minutes away) and I had no clue because all I ever did was hit the Bestbuy/Circuit City which are also very close to me.
Excelsior AVS!
J y E 4Ever is offline
Old 12-09-2006, 08:13 PM
ABHD's Avatar
Originally Posted by trich View Post
I just read your post so I put Nemo in my A2 and it is playing ok.
I just tried Nemo widescreen version, and the menu loads up just fine, and the movie itself played without any problems as well... I only ran about 10 minutes of it, but had no problems with it in the A2.
ABHD is offline
Old 12-09-2006, 08:18 PM
swifty7's Avatar
we need some more sd-dvd upscailling tests, I really want to know if the A2 is as good as A1 or better than the Oppo.
congrats to the owners.
swifty7 is offline
Old 12-09-2006, 08:19 PM
Liked: 116
Steve
Yes, which is a PITA because we don't have res button anymore. I did try my remote from the A1 and see if the res button worked, no go . So for now you have to go into setup menu change the res to/from 480i and 1080i for those that want to have outboard scaling. It is nice to have 480i over HDMI.
Derek
Old 12-09-2006, 08:35 PM
Jugdish69's Avatar
I don't think it's the panel......I didn't have this issue with the A1 and the Pioneer Elites have about the best on-board processing on the market (plasma wise). I have the panel in "pure" mode.
Who's your daddy?
Jugdish69 is offline
Old 12-09-2006, 08:41 PM
kanefsky's Avatar
The very maximum bitrate for OTA HD is 19.2 mb/s and that is mpeg2. It is rarely above 17mb/s (video) and usually 12-14mb/s for OTA. HD-DVD is at least 2-3 times more efficent than mpeg (VC-1) and is usually between 12-16 mb/s so it is considerably more dense and as far less artifacts than broadcast HD.
So what if you had a format with 1Gbps? Would it be "considerably more dense and far less artifacts" than HD-DVD? The answer is no, because once you achieve transparency it doesn't matter what bitrate you use beyond that. For most slow-moving scenes, 19.2Mbps mpeg2 is plenty and you won't notice the difference between broadcast and HD-DVD. It's only when there is fast motion that you really need the extra bandwidth or more efficient codec.
Yes there are 30" monitors that are higher resolution than a 1080p PJ (they too only can display 1080p at best) but you would need to sit inchs away in comparsion. A 110" screen has over 3 times more area than your 61" tv and would be 13 times more area than the 30"" monitor used in this discussion and these are screen widths I am talking about.
I sit about 2 feet from my 30" monitor which is the equivalent of sitting about 7.5 feet from a 110" screen. So anyone sitting more than 7.5 feet from their 110" screen is less likely to notice artifacts than I am on my 30" monitor.
The monitor is 1600p so it can display upscaled 1080p content and it can display my digital still images which are 2900p
Steve
kanefsky is offline
Old 12-09-2006, 08:52 PM
Schlotkins's Avatar
Just a FYI - I contacted Robert about the CUE issue and he indicated that the problem can and WILL be fixed in a firmware update.
Chris
Schlotkins is offline
Old 12-09-2006, 09:06 PM
bigjb419's Avatar
Just tried to play two superbit titles, black hawk down & the patriot, and neither of them will play..... The A2 gives me an error. I wonder if this is with all "superbit" titles. I have about 12 of them.
bigjb419 is offline
Old 12-09-2006, 09:22 PM
tsb
tsb's Avatar
I've read that as well, but without trying we won't know for sure. Perhaps a generic code will be leaked that will work for all players/drives as well. Having the best chance for mods/hacks/AACS bypassing is a big reason I got the A1 and will never get rid of it even after I replace it.
tsb is offline
Old 12-09-2006, 09:26 PM
tsb
tsb's Avatar
Wonder what the hell they changed that's causing all these SD DVD problems.
I'd bet it's easily fixable through firmware though.
tsb is offline
Old 12-09-2006, 09:37 PM
bigjb419's Avatar
Wierd...... After powering down I tried these titles again and now they work.....
bigjb419 is offline
Old 12-09-2006, 09:39 PM
noah katz's Avatar
Quoted: 884 Post(s)
Liked: 304
The A2 is like the A1 concerning BTB/WTW when connected via HDMI>DVI, there is no BTB or WTW.
Is this just a problem with DVI displays, i.e. a newer HDMI display will show BTB/WTW?
Noah
noah katz is offline
Old 12-09-2006, 09:41 PM
djos's Avatar
Quoted: 28 Post(s)
Liked: 24
Yes, it is on DVI displays only, on HDMI displays everything works perfectly.
The impossible often has a kind of integrity which the merely improbable lacks.
djos is offline
Old 12-09-2006, 09:49 PM
jwv651's Avatar
Won't play Finding Nemo...watched 2 other sd disc and there was a huge layer change...I never seen this with my A1.
Joe V.
jwv651 is offline
Old 12-09-2006, 09:51 PM
kanefsky's Avatar
Technically I think it's an issue when the video is sent using 4:4:4 RGB instead of 4:2:2 YCbCr component. That usually happens when you use DVI instead of HDMI, but there are cases (like the Lumagen scalers) where you can send component over DVI and other cases where an HDMI display will negotiate RGB with the player. So it's possible to get BTB with DVI or not to get BTB with HDMI in some cases.
But the important thing to remember is that BTB is just a test signal for calibration, and has nothing to do with "black crush" or any difference in video quality.
Steve
kanefsky is offline
Old 12-09-2006, 10:04 PM
DTV TiVo Dealer's Avatar
Try a cold re-boot by unplugging the A/C power cord and restart the player and try Finding Nemo. Also let us know what the exact error message is and I'll speak with my technical contact at TACP.
-Robert
DTV TiVo Dealer is offline
Old 12-09-2006, 10:28 PM
jwv651's Avatar
-Robert
I beleive it was error message 6..Thanks Robert.
Joe V.
jwv651 is offline
