Tosh HD-A2 HD DVD - First End User Reports! - Page 177 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #5281 of 5325 Old 02-17-2011, 10:30 PM
joeags's Avatar
The only way you'll be able to get replacements would be to grab them off of a damaged player that has a good panel. Not really worth it for just the panel!!!
That being said, it depends on how they're broken. I had one that I bought that would get locked, and found when opening the case it had just popped out of the socket. Easy fix. Another easy fix would be replacing the spring (I think it has a spring... been a while). If the panel is damaged, as in the "pin" has snapped off, you're not going to have much luck, but you could just remove it, and risk the extra dust getting in through that open panel. You're no doubt well out of warranty, so I wouldn't hesitate in exploring inside to see if you can get it aligned and working.
Originally Posted by hockman4357 View Post
I have 2 HD-A2 players and both have broken flip-down panels. Can these be fixed? If so, where can I locate two flip-down panels? Thanks!
joeags is offline
post #5282 of 5325 Old 02-18-2011, 08:04 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
I've used AnyDVD HD to rip all my HDDVDs "just in case" something happens to either the disc or my player. If something does I can always rip the image to a blu-ray.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #5283 of 5325 Old 02-18-2011, 09:02 AM
hockman4357's Avatar
On both players, the flip-down panel broke off completely. If I can find one off of a broken HD-A2 will I have any problem replacing it? I just like it when everything works like it is supposed to. I'm rather picky in that way.
hockman4357 is offline
post #5284 of 5325 Old 02-18-2011, 03:12 PM
joeags's Avatar
No, it's really quite easy to do the replacement. You could also use the HD-A20, as the chassis is exactly the same. I swapped the power button panel between two, and it really is easy to replace things in it. The hardest was getting a drive out, as I couldn't get a cable disconnected!!
I started doing that myself, but found it was a bit of a pain since I own over 200 discs now. It was much easier, and cheaper through the costs of extra drives, to just buy an extra player as a back-up. Of course now the family owns 8 players, so we're good for quite a while!!! I still do have a computer drive just in case I need to resort to that though!
joeags is offline
post #5285 of 5325 Old 02-20-2011, 09:00 AM
catmother's Avatar
FWIW the Xbox360 external HDDVD drive connected via USB is a good tool for ripping and playing HDDVD. A bit slow but gets the job done.
There are lot of these on Ebay. Bought one about 4 months ago for $25 + shipping. This does NOT require the Xbox console BTW.
Arcsoft TMT3 will decode and play HDDVD, Power DVD from 8 up will not although there is a hack to enable HDDVD play back with PDVD on the AVS HTPC forum PDDVD thread. Have not tried that myself, don't have PDVD.
Certified HDTV junkie and AVS addict
U.S. Army FA WWII
catmother is offline
post #5286 of 5325 Old 03-19-2011, 07:21 PM
ac388's Avatar
Quoted: 79 Post(s)
Liked: 26
I still have the 2.8 firmware. Pls advise the correct setting on Ethernet how to update to 4.0 thru the LAN connected to it. Thanks.
Man see things as they are n say why. I dream of things that never were, n say why not ....... A Perfect PROJECTOR
ac388 is offline
post #5287 of 5325 Old 03-23-2011, 02:33 AM
Blues In Thirds
javry's Avatar
boy, I haven't been on this thread the end of 07 when I sold my HD-DVD player and moved from England to Saudi. Good to see there are still some owners out there.
javry is offline
post #5288 of 5325 Old 03-23-2011, 07:02 AM
Buckeye911's Avatar
^ Yep, still a few of us around, I still play the occasional HD DVD.
RonAlam likes this.
The measure of a man's character is what he would do if he knew he never would be found out.
Buckeye911 is offline
post #5289 of 5325 Old 03-24-2011, 03:50 PM
catmother's Avatar
You are missing the bargains.
I just bought The Bourne Identity HDDVD (brand new) from Amazon for $2.48 via an Amazon affiliate "foggypaws'.
Look at his store, he has hundreds of HDDVD, many at bargain prices and many are brand new and he marks them as new or used.
Most of my ~70 HDDVD are ripped to my WHS and streamed to a NeoTV550.
No more slow loading from the Toshiba D2 and now the video plays at 1080/24p which the D2 can not do.
U.S. Army FA WWII
post #5290 of 5325 Old 07-30-2011, 03:28 PM
machavez00's Avatar
My trusty Sammy DLP's color wheel finally bit the dust and we purchased an LG 47LV5500. Since my Sammy was 720p, I wasn't concerned that the HD-A2 did not out put 1080p. My question: set the A2 to output 1080i or 720p?
machavez00 is offline
post #5291 of 5325 Old 07-30-2011, 03:42 PM
Jeff_DML's Avatar
1080i, your tv should be able to deinterlace pulldown to 1080 p
Jeff_DML is offline
post #5292 of 5325 Old 07-30-2011, 09:09 PM
machavez00's Avatar
Thanks. I have more HD-DVDs than Bluray at this moment. I buy BR, but if I run across any HD DVDs cheap I get them. I found a new copy of Animal House at Fry's Foods for $6.
post #5293 of 5325 Old 07-31-2011, 08:13 AM
catmother's Avatar
There is an Amazon affiliated Ebay seller (foggypaws) with a large inventory of HDDVD's. I bought the Bourne Ultimatum from him. ~ $ 5.
Meanwhile at least four of my HDDVD's have failed, Casablanca and Phantom of the Opera among them. I will have to scout Amazon for replacements.
Took a look at Amazon and searched for HD DVD, 3358 results, but my choices above are not there.
U.S. Army FA WWII
post #5294 of 5325 Old 08-10-2011, 09:18 PM
BTBuck1's Avatar
funny my Tokyo Drift HDDVD has failed, developed some sort of oxidization. I contacted universal, they offered me the DVD....I bitched and now as a "one time exception" they're sending the blu-ray copy in it's place.
HDDVD owner: 360 add-on, HD-A30, HD-A2, A1
Blu-ray disc supporter: ps3-60gb, Oppo BDP-93
TV's: LN46B750 1080p-240hz LCD/kdl55hx729 1080p 240hz 3D LED
Link:Blu-ray Disc Fan Forum
BTBuck1 is offline
post #5295 of 5325 Old 12-04-2011, 11:59 PM
poiski_duraka's Avatar
Hi everyone, I've been an av fanatic for many years but because I have only just started into semi-retirement I am now posting into the forum. And I'm here because I want to get HD-DVD, especially this Toshiba model. There are people literally giving away the movies with this player on eBay. Will someone please pinch me? I know the format is going going gone but what the hey, the deals are screaming too loud for me to ignore. Have I lost my mind or is this a great deal to pursue?
I'm just on a 'fool's quest'...don't mind me!
poiski_duraka is offline
post #5296 of 5325 Old 12-05-2011, 06:27 AM
StuJac's Avatar
What kid of deals are you seeing? Maybe I can beat it? I have one that I don't use and have a bunch of HD movies also. PM me if you want to discuss.
Pan 46PZ85U, Marantz SR5003, TiVo Premier, TiVoHd + 1tb, A2 (fs), PS3, Pan DMR E-95 (fs), JVC DVD-A, Polk & Infinity, Harmony One
StuJac is offline
post #5297 of 5325 Old 12-05-2011, 11:49 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Depends. If the discs are new then you should be 'ok' but know the tech is no longer supported and the discs scratch fairly easy (I'd never buy used).
We have 3 HDDVD players but rarely use them but I have @80 HDDVDs.
Wryker is offline
post #5298 of 5325 Old 12-05-2011, 04:25 PM
Rich86's Avatar
Quoted: 128 Post(s)
Liked: 64
When DVD came out, and laser disc players and titles started showing up with lower prices, folks would ask me - "should I jump in and grab stuff now?". My answer was always - "if you already have players and titles and are happy with them, enjoy. If not - do not get involved now - buy DVD when you are ready".
I would say the same thing now about HD-DVD . . those of us who have players and titles enjoy them. I have no intentions of giving up my players & titles. But you can get blu-ray players and titles very inexpensively these days, and I would not recommend someone get involved with hd-dvd at this point under any circumstances (short of someone giving stuff to you for free).
A long-time audio/video addict!
Rich86 is offline
post #5299 of 5325 Old 12-05-2011, 04:53 PM
sivartk's Avatar
The most I'd pay for any HD-DVD title at this point would be about $1 (the cost of a rental). Unless, of course, it is some international title that will never make it to the US on Blu-ray. That being said, I still watch what I have on either my HD-A2 or my LG BH200 dual format player.
At no point in your rambling, incoherent post were you even close to anything that could be considered a rational thought. Everyone in this forum is now dumber for having read it.
My Little Theater
sivartk is online now
post #5300 of 5325 Old 12-06-2011, 11:27 AM
catmother's Avatar
My Toshiba D2 (Costco version of the A2) is limited to 1080i and can not reproduce the 24 FPS film rate.
To overcome this limitation my HD DVD collection is ripped to my WHS using a tool that converts the HDDVD structure to the BluRay BDMV container. The films now stream via a 1Gb network to a Dune Smart H1 at 1080/p24 with bitstream audio to my AVR which decodes DB THD and DTS HD MA audio.
IMO this is the way to go.
My desktop PC has the LG combo (HD DVD/BR) optical drive originally used in the LG BH200 player. No longer available but the Xbox HD DVD external (USB) player is readily available on Ebay for ~ $30 and does the job.
PM me for the (free) tool used to do the rips.
U.S. Army FA WWII
post #5301 of 5325 Old 12-06-2011, 08:19 PM
Splicer010's Avatar
Liked: 39
Grab it. I have around 350 titles on HD DVD and ONE A-35 player and it friggen ROCKS!!! While I do not use it as much lately, (we use streaming ALOT now) when I do, I am so pleased I got it. And IF you can find titles for $1 new? Do not walk, RUN to the checkout. Worth every penny. I have no problem getting (new) $5 titles for what I want...Of course, I am at the point of no return and the titles available that I want on HD DVD are few and far between anymore. While I won't p/u titles on HD DVD that are on Blu, I won't buy on Blu what I already have on HD DVD. Make sense? Does to me.
Splicer010 is offline
post #5302 of 5325 Old 12-07-2011, 07:00 AM
sivartk's Avatar
Maybe I'm getting spoiled with the Blockbuster stores going out of business and picking up previously viewed Blu-rays for $2-$3 each. I think I have most of the HD DVD titles I want already, so that is why I set my $1 limit. I have about 50 or so HD DVD and haven't re-bought any of them on Blu-ray.
My Little Theater
post #5303 of 5325 Old 12-07-2011, 11:47 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
I took advantage of the HDDVD to BD program. I scanned the covers for the HDDVDs and printed them to keep with the HDDVD and got the BDs for $5 and then sold a bunch of the BDs on eBay for profit.
Wryker is offline
post #5304 of 5325 Old 01-01-2014, 07:26 PM
Bujee1's Avatar
I've got an A2 I used a 6 times before getting a dual HDDVD/ Bluray player. I'm thinking of selling my player and 78 HDDVDs . Any chance I can get $200 for the whole bundle? How?
120" Electric Motorized Remote Projection Screen Movie Projector Black Matt 16:9, Elite Screens R115WH1-WIDE ezFrame Fixed Projection Screen (115" 2.35:1 AR)(CineWhite), Onkyo TX-NR616 7.2-Channel THX Select2 Plus Certified Network A/V Receiver(Black), Klipsch Reference Series R-1650-C In-Wall/In...
Bujee1 is offline
post #5305 of 5325 Old 01-03-2014, 07:27 AM
AVfile's Avatar
Quoted: 241 Post(s)
Liked: 126
I have an A2 that won't play discs if anyone wants it for parts (no scratches) they can have it free or I can part it out.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #5306 of 5325 Old 01-28-2015, 01:15 PM
Liked: 0
ventured into this thread out of curiosity. I've got a Toshiba HD-A2 with maybe and i'm talking MAYBE, six hours usage. What are people doing with them still to this date?
djkltg is offline
post #5307 of 5325 Old 01-28-2015, 01:30 PM
DocCasualty's Avatar
Quoted: 194 Post(s)
Liked: 2377
I have ~ 100 HDDVDs and still use it periodically to watch them. Some discs are becoming unplayable and I'll probably replace the worthwhile ones via BD or downloads. Most of the worthwhile ones I've already converted to Ultraviolet via VUDU's disc to digital.
"Dave, this conversation can serve no purpose anymore. Goodbye."
DocCasualty is offline
post #5308 of 5325 Old 01-28-2015, 05:35 PM
TrevorS's Avatar
I use it for playing HD DVDs, a very good player IMO. I've several as well as my original RCA HDV5000. What else would one use it for?
TrevorS is offline
post #5309 of 5325 Old 01-28-2015, 07:57 PM
sivartk's Avatar
Mine in is my living room where I watch the occasional DVD and HD DVD. I have a BH200 (BD & HD DVD player) in the theater room where I watch most of my movies.
My Little Theater
post #5310 of 5325 Old 02-03-2015, 04:53 PM
bradman's Avatar
Quoted: 17 Post(s)
Liked: 26
They make good DVD upscalers and useful CD players.
bradman is offline
Reply HD DVD Players
