Tosh HD-XA2 1080p HD DVD - First End User Reports!: USERS ONLY PLEASE! - Page 156 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #4651 of 4673 Old 02-25-2015, 11:40 PM
Rich86's Avatar
Quoted: 128 Post(s)
Liked: 64
Originally Posted by Brian81 View Post
A couple years ago, I was running through testing/watching various WB discs for "rot". Had a high failure rate, around 50%. After going through about two dozen discs, I started to also have problems with other discs, seemingly my Studio Canal titles. Instead of the problems I had with WB titles (same error code ending playback, always at same timecodes, or discs not recognized), things would manifest in different ways. Discs would freeze up during playback occasionally, even during menus. Unlike the WB titles, there were no error codes you could exit out of - the player was frozen. Time codes where discs were locking up were varied (non-repeatable). When discs would lock up, I'd be forced to do a hard reset (holding in power button for several seconds), or unplugging the unit. In nearly all cases, I'd do the hard reset - because once the discs froze up, no number of trying to press 'Stop' would work. No other choice. At one point, I even updated the firmware from 2.7 to 4.0, which didn't change anything.
Eventually, the unit no longer booted properly, and was greeted with a 'Welcome' on the LCD screen and nothing else. It did not ever go away to the disc loading/recognition process, after quite a few tries of hard resets/unplugging. So it's sat unplugged for 2 years now.
Today, I finally decided to take it out of the rack for an A2 I have boxed away (bought first, kept only because it shares parts with the XA2). But first I decide to remove the top casing to see if there's anything noticeably different, like blown capacitors or the like. Nothing visibly cooked. So figuring I wouldn't be swapping parts with the A2 in the near future, I plugged it in and powered it up. Well, now it goes past 'Welcome' and to the 'Loading' and 'No Disc' screens.
So now I'm wondering what may be the case here. Any possibility that running it through many bad discs could have simply worn out the drive? I ask because I remember reading in the past about the 'Welcome' error being a power supply issue? I still think I'm going to throw the A2 into use, but now I'm left wondering if i'd be best swapping both the drive and power supply, or just the drive. After all, if it's the power supply that messed up the drive, I wouldn't want to throw in a good drive to be fried by bad power. But if the 'Welcome' error is actually just a generic error message for a variety of hardware failures, maybe it is just the drive on the fritz. I also wonder about overheating, as the first time I had a SC title freeze it, I didn't notice it because I'd fallen asleep watching the film and woke up to see it frozen mid-film with picture on screen, instead of it being on a looping menu as one would expect after the film finishes.
It is possible that the player simply reset itself after sitting for so long. That is something one should always try when one of these HD players gets weird.
Have you tried playing a disc in it yet?
musicalfox likes this.
A long-time audio/video addict!
Rich86 is offline
post #4652 of 4673 Old 02-26-2015, 02:28 PM
Brian81's Avatar
Not yet. I'm still planning on putting the A2 into use and put wear and tear on that, instead. I'd been using it on a DLP RPTV set that doesn't accept 24Hz input (only 1080p/60Hz) anyways, so it's not like I've been watching discs at their native frame rates, anyways. I still believe there's an issue with it, but at least it is not BRICKED! Quite a relief, as I thought it was after being stuck on 'Welcome'.
Brian81 is offline
post #4653 of 4673 Old 04-25-2015, 08:32 PM
Artstodd's Avatar
Russian xa2
I recently bought a hd-xa2 from a guy in Russia (yeah, I know I took a hell of a risk) but it came when it was supposed to and in perfect condition. I LOVE it-everything on it works and hd-dvds look terrific and sd dvds look great too. The only problem is that the osd, setup menus are all in Russian!! Any ideas as to how I can switch this thing to English??thanks
Artstodd is offline
post #4654 of 4673 Old 04-26-2015, 02:51 PM
UHD Addict
aaronwt's Avatar
Quoted: 5185 Post(s)
Liked: 3097
I would think there is something in the settings. I would need to look mine to be sure.
aaronwt is offline
post #4655 of 4673 Old 04-26-2015, 08:15 PM
shodoug's Avatar
http://support.toshiba.com/support/s...mTOCLink=false
I believe that link will take you to the "hd-ax2_om_e.pdf" owners manual in English.
There is some information on page 53 and then pages 57 and 58.
It might be enough to guide you through the menus to make the change.
Good Luck,
Doug
shodoug is offline
post #4656 of 4673 Old 04-27-2015, 12:50 PM
Artstodd's Avatar
Good Luck,
Doug
I downloaded the manual and tried to use it to change the settings, but since everything on the setup on the xa2 is in Russian-or some other language-I wasn't able to figure out what I was changing-guess I'm just stuck with it the way it is-or maybe find a Russian speaker to help me with it-thanks anyway.
Artstodd is offline
post #4657 of 4673 Old 04-27-2015, 02:15 PM
shodoug's Avatar
I was hoping the buttons on your remote were in English and could get you to the right spot. Oh well.
There is a free google translator I downloaded on my android that works pretty well for spanish. I did not get to try it much when i was working with Russians.
It even has a feature that you can show a sign or word to the camera and it will translate it for you.
You would need the module for Russian, of course.
Good Luck,
Doug
shodoug is offline
post #4658 of 4673 Old 04-27-2015, 02:32 PM
Artstodd's Avatar
Good Luck,
Doug
ok, I'll try the translator.. thanks Art
Artstodd is offline
post #4659 of 4673 Old 04-29-2015, 09:52 PM
Worf's Avatar
Quoted: 445 Post(s)
Liked: 210
Hrm, you didn't happen to buy it from eBay did you? (I remember there was a xa2 from Russia for the longest time, then it disappeared).
And the manual should have a picture of the remote in English...
Worf is offline
post #4660 of 4673 Old 04-30-2015, 12:06 AM
AVfile's Avatar
Quoted: 239 Post(s)
Liked: 125
Why not get an A35?
I wonder if the Russian XA2 will need a North American firmware change?
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
post #4661 of 4673 Old 04-30-2015, 04:00 PM
shodoug's Avatar
I tried the camera feature for signs with the translator on some work I was doing that was commented in German.
The way it worked was really cool. If I held the camera on a small number of words, the view on my phone replaced teh German words with English ones.
Same thing for a small sign in Italian at a local restaurant.
Of course the translations are not perfect, but they have been very helpful.
Doug
shodoug is offline
post #4662 of 4673 Old 05-20-2015, 12:23 PM
Viking61's Avatar
Quoted: 16 Post(s)
Liked: 26
Try doing a reset to factory setting. If I remember correctly, you should press Display, 7, 0, 1, Display on the remote. The player will then shut down and when you restart it will go through the initial setup. Hopefully you will be able to choose language in the setup.
Are you sure it is an American XA2 and not the European model XE1? If it is the XE1 you can install the regionfree firmware.
Viking61 is offline
post #4663 of 4673 Old 08-04-2015, 07:16 PM
KristinaAlexis6's Avatar
Quoted: 20 Post(s)
Send a message via Yahoo to KristinaAlexis6
Does anyone know if the XA2 has been dethroned in terms of upconversion? I know the Oppo's do a damn good job, BUT... I was thinking of picking one up from eBay, I think the guy wants $100.. I own a few players (Sony, Oppo, getting a new Sony, model 2014, possibly 2015).. Is this worth buying for upconverting? All my HD-DVD's are stored somewhere in a bin, and buried.
Display: Sony KDL-55W802A
Sound Bar: HT-XT1
Players: SONY S1200
Sony BDPS1000ES
Oppo BDP-83
PS4
KristinaAlexis6 is offline
post #4664 of 4673 Old 08-04-2015, 09:31 PM
humbland's Avatar
Quoted: 327 Post(s)
Liked: 78
That's a very good question. We still have our XA2 in the component rack. My Oppo has been acting up as of late, perhaps I should just shift over to the XA2. Back in the day, I compared the upconversion and it was very close. Perhaps a slight edge (DVD humor ) to the Oppo. Now days, we watch mostly Blu-rays anyway. So it's not much of an issue...
I am curious though, is DVD upconversion quality still a "feature" of Blu-ray players? Oppo probably still makes the best, but are there other good choices?
humbland is offline
post #4665 of 4673 Old 08-04-2015, 09:53 PM
Quoted: 20 Post(s)
I actually still own an XA2, it's been put away in a closet (long story short, right now I'm living somewhere else without a LOT of my stuff, until I get a uhaul to get it all back)
Oppo problems, huh? I had that same exact thing happen to me! I had an Oppo-93? I think the model is. It was somewhat of a disaster for me.. I remember AT LEAST 10 blu-rays NOT playing! I updated FW, etc.. NOTHING worked, and I was forced to watch 'em on a different player (sony) They also froze a LOT!
I ended up losing patience and eventually sold on eBay, and saying it had problems with discs, but the unit was in excellent shape and functional etc, it sold for around $300 some. Not bad at all
I think DVD upconversion is still pretty important for me, I own TONSSS of DVD's, so I'd like 'em to look the best possible
Sound Bar: HT-XT1
Players: SONY S1200
Sony BDPS1000ES
Oppo BDP-83
PS4
post #4666 of 4673 Old 08-05-2015, 04:38 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
It does not even matter. They are all better than you can see.
Gary J is offline
post #4667 of 4673 Old 08-05-2015, 11:48 AM
Smarty-pants's Avatar
Quoted: 747 Post(s)
Liked: 621
The XA-2 is a very good player for DVDs. The Oppo players will be better though.
It's not just about the upconversion, and doing a quick comparison to other players doesn't always reveal the whole picture.
Other factors are to be considered, like deinterlacing, especially on some discs that have odd cadences.
If you aren't going to play HD-DVDs, I wouldn't bother with an XA-2 or any other player.
I do still have mine in my a/v rack, but not sure why since I haven't played any HD-DVDs in a long time.
As for how the Oppo players operate... if you ever have issues that you can't resolve,
there are owner threads for every model of Oppo player right here on AVS where you can get help.
You can also always contact Oppo customer support which is known for being very helpful and proactive.
If one of their player's is in need of service and under warranty, just send it in and it's fixed fast.
Even if the player is out of warranty, they have low flat-rate fees for fixing their players too.
Of course if you really feel you have to sell it off, they do have great resale value too.
I'm sure there are other players out there that also do a decent job with DVDs,
but Blu-ray has taken over the market so much, that no one ever talks about how to get the most out of your DVDs.
Now of course we also have UHD on the horizon too.
Smarty-pants is offline
post #4668 of 4673 Old 08-05-2015, 08:28 PM
Quoted: 20 Post(s)
But the XA2 is a such a sexy piece of machinery, lol. Seriously, I wish more companies would build players like an XA2, built like a tank, metal brushed aluminum, and feels sturdy/heavy! I guess the Oppo's come close in build-quality, but I just LOVE the build of the XA2. I doubt we'll ever see another player built like that. All Sony blu-ray players feel like really cheap plastic, extremely light, i'm afraid if it drops it'll shatter!
Sound Bar: HT-XT1
Players: SONY S1200
Sony BDPS1000ES
Oppo BDP-83
PS4
post #4669 of 4673 Old 08-06-2015, 04:26 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
That build came at a VERY HIGH PRICE.
Gary J is offline
post #4670 of 4673 Old 08-06-2015, 05:12 AM
UHD Addict
aaronwt's Avatar
Liked: 3097
Look how ancient the XA2 is. Today it is very unusual to have an electronic device built that way.
aaronwt is offline
post #4671 of 4673 Old 08-06-2015, 07:19 PM
Quoted: 747 Post(s)
Liked: 621
I would say the newest generation of Oppo players are on par with the build quality of the XA-2.
They do not skimp on quality and use a metal faceplate and metal housing too.
Of course not all players are built to such high standards, but not all cheap players are junk either.
Using a plastic face and housing gives it a cheaper feel and makes it lighter and cheaper to build too,
but the quality of inner parts and software engineering is what matters.
Many times though a lot of small things add up, and with the Oppo players, they check so many boxes and are so full of features<
including build quality, that is why they are known to be the best players on the market.
Of course they don't play HD-DVDs which is unfortunate.
That is very true when it was first released, it was not close to cheap, and the high quality came at a high price.
Another thing some people might say, is that the HD-DVD players and Blu-ray players that were released in the
first couple years when those formats came to market, were built to very high standards since both formats were
competing for the public's approval and money. If you make a cheap product that breaks easily, it would not look good for your cause.
Of course there were cheaper players like the HA-1, HA-2 etc, that were not built to as high of a standard,
but even those players were very solid.
I think yes and no. For the most part most players aren't built to the same standards I describe above,
but there are still higher end players that a built pretty well.
However the number of "cheap" players far overshadows the number of high quality players.
post #4672 of 4673 Old 03-19-2016, 10:04 PM
Quoted: 72 Post(s)
Liked: 44
Does anyone have firmware 4.0 on a disc need to upgrade my XA2 from 2.7 thanks.
jsil is offline
post #4673 of 4673 Old 03-20-2016, 05:31 PM
Rich86's Avatar
Quoted: 128 Post(s)
Liked: 64
download it and burn it to a cd-r following the instructions.
http://support.toshiba.com/support/home
enter HD-XA2 in the model # box.
the link above acts a bit flaky, but the pages and files are there.
Rich86 is offline
Reply HD DVD Players
